Old 11-08-2018, 09:43 AM   #29
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
It really depends on your area. Where I live the rain gutters and crowns on the road are so bad my sister scrapes her Chrysler Pacifica backing out of her driveway unless she does it absolutely perfect.
It is the lip though, I have a series.blue and even being as careful as I can the front lip broke in six months. Others in the area have done the same. But that lip is total garbage, if you get a strong enough one it should be able to deal with minor scrapes.
why? is offline   Reply With Quote
Old 11-08-2018, 10:50 AM   #30
Rampage
Senior Member/Old Fanboi
Rampage's Avatar
Drives: 2000 2ZZ-GE MR2 Spyder HT
Give this thread a read. http://www.ft86club.com/forums/showthread.php?t=67345 The guy knows of what he speaks. It may give you some insight into the compromises that you must make when you make changes to your car (and every mod is a compromise of some kind).
Remember that every scrape does some damage to a part of your car. If it is a plastic lip then it is not that big a deal. That is just aesthetics. If it is a pinch seam then it is removing paint and exposing bare metal which will eventually begin to rust. If it is the exhaust then it will eventually lead to a hole which will leak. If you care about the longevity of your car then you want to avoid scraping.
I installed RCE yellows on my son's FR-S which gave a .75 inch drop. I run coilovers and a 1.25 inch drop on my MR2 Spyder. Both cars looks a little better IMO. The FR-S never seems to scrape. The Spyder almost never scrapes anything unless going into or out of a steep drive where the front lip may touch. Both drops are modest enough to not mess up the suspension geometry and both cars were properly aligned after lowering.
So many modders have more cents than sense!
Rampage is offline   Reply With Quote
Old 11-08-2018, 01:03 PM   #31
Gunman
Drives: 2019 Mazda Miata RF
Ditto.
Under specific track conditions, three times until the mis-aligned CV joints explode.
Lowering reduces suspension travel.
But did it handle better, prior to the failure? lower Cg is rarely, if ever, a bad thing, in regards to handling.
Reduced suspension travel needs to be compensated for in the spring rates, dampers, and/or the bump stops, depending on your goals.
Old 01-01-2019, 02:02 AM   #32
Dreamzqt
Drives: 2014 limited BRZ
lower it and buy a solid splitter mines like a black sexy sheet of metal
Dreamzqt is offline   Reply With Quote
Old 01-01-2019, 02:09 AM   #33
Dreamzqt
Originally Posted by Will BRZ View Post
Thanks man. What lip do you have and would you recommend having one? I love the look of them especially on white, but I can imagine it being a pain having to be extra careful everywhere you go.
https://www.aeroflowdynamics.com/col...nt=15917573251
super thin sheet of metal
I've hit shit and this splitter was bent 90 degrees
took it off and beat it with a mallet and its back to normal lol
The Following User Says Thank You to Dreamzqt For This Useful Post:
Will BRZ (01-01-2019)
Front bumper scrape raxman Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 1 11-30-2013 09:30 PM
Scrape much? Andrew360 BRZ First-Gen (2012+) — General Topics 54 12-05-2012 07:50 PM
Paint scrape fixes? karbon Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 1 09-19-2012 02:36 AM
Best way to repair this scrape on my FR-S jflogerzi Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 3 08-11-2012 08:14 PM
Nooo, first scrape :( ubersoph Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 0 06-12-2012 12:07 PM
