| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
#15 | |
86 Challenge
Drives: 2017 BRZ
#16 |
It's like rubbernecking past an accident. If it's bad enough we might loop around for a second look.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | JD001 (12-29-2018) |
#17 | |
Drives: Subaru BRZ
"just keep it between the holes". (Does not apply when having sex).. LMAO!!! |
| The Following User Says Thank You to JD001 For This Useful Post: | Ultramaroon (12-29-2018) |
#18 | |
Lets go back to the old days and use the KISS method. Pull out the dipstick (anytime the engine is not running) and take a reading. If the oil doesn't show up on the dipstick, add a quart of oil. If the level does show up anywhere on the dipstick, you're good to go. If the level shows over the full mark, don't worry about it (especially if it's a Ford) because the engine will either burn off or leak out the excess. There ya have it, now just drive the fucking car and don't worry about it. Oh my, it's ma med/pain killer pill time - ![]() humfrz |
| The Following 5 Users Say Thank You to humfrz For This Useful Post: | finch1750 (12-31-2018), JD001 (12-29-2018), soulreapersteve (12-29-2018), spike021 (01-01-2019), Ultramaroon (12-29-2018) |
#19 |
Drives: FRS 2013
Check the dipstick first thing in the morning, make sure you are on level ground. The "Wait at least 10 minutes" is for the oil to drain back into the drain pan to give you the most accurate reading, however this is dependent on a lot of factors (Oil life, temperature, viscosity, what oil you used, some people using 5W30, etc). If you check after leaving it overnight then you know for sure all of the oil is there. I change my own oil and always drain out exactly what I put in (5.5L) and it reads exactly on the MAX dot when I check in the morning.
I swear some people around here need torque specs for the license plates |
| The Following User Says Thank You to highway7 For This Useful Post: | humfrz (12-29-2018) |
#20 | |
Drives: Subaru BRZ
#21 |
About 35 inch pounds.
#22 |
Now, hold on just a cotton picking minute. My license plate bolts have a slot for a screwdriver and a head that will accommodate a wrench or socket.
So, is your 35 inch pound torque measurement correct for either method of tightening the bolts down??? Now, jest chew on that cud for a spell while I drag my aching body into the bedroom for a looong nap. ![]() humfrz |
#23 | |
Drives: Subaru BRZ
| The Following User Says Thank You to JD001 For This Useful Post: | humfrz (12-29-2018) |
#24 |
#25 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
Three ugga duggas
"I gotta rock." -- Charley Brown |
| The Following 2 Users Say Thank You to bcj For This Useful Post: | finch1750 (12-31-2018), Ultramaroon (12-29-2018) |
#26 |
Drives: FRS 2013
#27 |
Rust bucket enthusiast
Wobble extensions reduce overall torque applied - what do I do?
| The Following User Says Thank You to DarkPira7e For This Useful Post: | Ultramaroon (12-29-2018) |
#28 | |
Contract? /人◕ ‿‿ ◕人\
I miss my first car. Wish I still have it. Too bad one of my relatives trashed it and its in car heaven now.
| The Following User Says Thank You to soulreapersteve For This Useful Post: | humfrz (12-30-2018) |
| OFT CAL confusion? | Madara | Software Tuning | 5 | 08-04-2018 12:20 PM |
| Replacement Key Confusion | pwest | BRZ First-Gen (2012+) — General Topics | 7 | 10-25-2016 04:08 PM |
| Exhuast confusion | xsnapshot | Engine, Exhaust, Transmission | 10 | 06-30-2015 03:21 PM |
| Exhaust Confusion | Strife26 | Engine, Exhaust, Transmission | 8 | 05-03-2015 08:42 PM |
| Alarm confusion | Fugazi | BRZ First-Gen (2012+) — General Topics | 9 | 07-12-2012 01:20 AM |
