CANADA Canada
Old 12-02-2018, 03:09 PM   #1
PaoloJR
Drives: 2017 Subaru BRZ Sport-tech WRB
Eibach Prokit Lowering Spring Combo
Hello ft86 fam,
I just recently purchased the eibach pro kit. I will be installing it next year before summer. I wanted to get ahead and plan of what good wheel/tire spec that will come close to looking flush with the eibach pro without rubbing. I know I cant fully acheive flush without coils but I wonder if anyone has any recommended setup.
thanks in advance everyone!
PaoloJR is offline   Reply With Quote
Old 12-14-2018, 01:40 AM   #2
rmr
rmr's Avatar
Drives: FRS 10-series
Originally Posted by PaoloJR View Post
Hello ft86 fam,
Theres a few threads on this exact topic with pictures.
https://www.ft86club.com/forums/showthread.php?t=25028
From what I remember most people are running 20-25mm in the rear and 15-20mm spacers in the front with the pro kit if you are using stock wheels.
rmr is offline   Reply With Quote
Old 12-14-2018, 01:58 AM   #3
Leonardo
Country Boy 4 Life
Leonardo's Avatar
30mm rear and 25mm front for stock wheels. 25mm and larger will bolt on. And are much simpler to install than 15mm or 20mm spacers.
I was running 25mm spacers on 18x8 +45 wheels. IMO they were flush.
Coils dont have as much to do with being flush as wheel offset and camber adjustment. Camber bolts are good for the front. You will get -2 ish rear camber from lowering on prokit.
I would now recomend a bumpsteer kit. I got a whiteline kit. it replaces the tie rod ends and the ball joints in the front. It corrects your suspension geometry from lowering 1". It made a big difference IMO.
I ran prokit springs for 70000 miles. They are great for DD.
I LIKE TIRES!
Old 12-16-2018, 11:49 AM   #4
Skurj
Drives: SOLD...
I ran several different wheels with the pro-kit. 18x8.5 + 18x9.5 ET38 sat nice and flush as is no need for spacers. BUT... staggered sucks for handling. 17x9 +35 on all 4 corners fit nice too.
WRB MT BRZ Sport Tech Delivered March 21 2013 Its mine now!!
Paid for Mar 2018
and its gone... Sept '18 tho I am sure I will miss it
Replaced with 18 50th edition ND
Skurj is offline   Reply With Quote
The Following User Says Thank You to Skurj For This Useful Post:
Leonardo (12-16-2018)
WTB: Eibach Prokit fuga Want-To-Buy Requests 0 12-24-2014 05:26 PM
Eibach Sportline Lowering Spring front and rear camber bolts WallsAndFoundations Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 08-20-2014 11:09 AM
Cost of spring swap - Eibach ProKit krulux Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 04-10-2014 05:27 PM
WTB: Eibach sportline lowering spring. bhbnuckle Brakes, Suspension, Chassis 1 03-11-2014 01:05 AM
