Old 04-18-2017, 01:57 PM   #267
driftking9
Drives: Scion Fr-s
How much for the oem intake shipped to 80917? Thanks
driftking9 is offline   Reply With Quote
Old 04-30-2017, 04:34 PM   #268
Thatdudesteveo
Thatdudesteveo's Avatar
Drives: 2014 Firestorm Monogram Scion FRS
How much for just tpms sensors, no wheels?
Thatdudesteveo is offline   Reply With Quote
Old 05-02-2017, 09:11 PM   #269
MicheleAbbate
MicheleAbbate's Avatar
Drives: Grr Racing FRS & BRZ
Send a message via AIM to MicheleAbbate
bummmmmp
www.GrrRacing.com - Won Scion's first Road Racing Championship in 2011. Raced the Grr Racing Scion FRS from 2014-2018. Have lots of OEM Part FS. lol Check my thread. Now I race in Trans Am TA2.
MicheleAbbate is offline   Reply With Quote
Old 05-03-2017, 06:58 AM   #270
wrb
frank
wrb's Avatar
Drives: Subaru BRZ WRB
Hey Michele,
Do you have front door window seals? black rubber strips that goes around the door area.
2013 SUBARU BRZ WRB LIMITED M/T
Los Angeles, CA
Build Photo Album - http://bit.ly/brz_wrb
SoCal LA 86 Club Member
wrb is offline   Reply With Quote
Old 05-06-2017, 10:11 AM   #271
PhoenixGT86
PhoenixGT86's Avatar
Drives: Firestorm red
Looking for a dashboard, any condition brz or FRS.
PhoenixGT86 is offline   Reply With Quote
Old 05-10-2017, 02:02 AM   #272
JDD 86
Drives: 2017 86
Hello, I am interested in the little trim piece that has the trunk button/ light dimmer on it if no one has asked for it yet. Can I get a price(including shipping to 91605)? Thanks!
JDD 86 is offline   Reply With Quote
Old 11-06-2018, 08:03 PM   #273
MicheleAbbate
bump.
heres some more parts for sale.
TPMS Sensor
Greddy Radiator Cap 127kpa
Throttle body
Wix Filters
New Winmax W4 Rear pads
Used W4 Front pads
Used W4 Rear pads
pulley cover
new style edelbrock water reservior
oem water pump
hard fuel line
motor mount bracket
oem idler pulley
water pump pulley
crank pulley
crankshaft keyway piece
raceseng idler? pulley
oem alt pulley
oem plastic idler pulley
oil cap
driver side fuel rail
pass side fuel rail
fuel cross over line
rear abs sensor
used ACT Lightweight flywheel
raceseng water pump pulley
used ACT 6 Pad unsprung clutch
used ACT pressure plate
new tc105n 17x8 +42
used tc105n 17x8 +42 unmounted
tc105n w/ new fz201 235/45/17
tc 105n w/ used A7
coolant passage
oil control valve
valve shims
oil pump
raceseng ac delete bracket with pulley
misc. o rings
raceseng idler pulley
oem idler pulley
motor mount
high pressure fuel pump
coolant line
camshaft bolt
crankshaft hub and gear
motor mount bracket
crankshaft position wheel
crankshaft pulley
alt. brackey and tensioner
gutted t-stat
hard fuel line
coolant line
timing chains
hard coolant line
chain tensioner guides
gates belt
oem headstuds
chain tensioner
hoonigan oil cap
antigravity battery
mishimoto catch can
hood prop
throttle body
timing cover
engine cover plastic
rear axle
oem rear lower control arm
rear axle
red head gas filler jugs
used wilwood front rotors (need to be cut)
accumsump
new motoIQ block
heads with cams
berk dual exhaust muffler delete
vvt cam gears
o2 sensor and sc harness
new MAF sensor
abs sensor
coil pack
sc harness
o2 sensor
oil control valve
MAP sensor
crank position sensor
radiator cap
used header gaskets
new header gaskets
oem fuel rail set
axle seal
axle nut
gtspec rear toe arm
swaybar end link
new oem front axle boot
new oem taillight bumper bracket
used mishimoto radiator
new apr mirrors
dba rotors
broken rear axle
oem rear axle
sa10r with fed rsr rr
ace header
new mishimoto water overflow
oem final drive gear
oem taillights
raceseng pully crank?
used whiteline front toe arm
front caliper
pfc full set of race pads - like new
used portfield r4 front pads - like new
used winmax w3 rear pads
rear toe arm with parking brake mount
altenator bracket with tensioner
motor mounts
altenator
engine cases
mishimoto 19 row oil cooler
misc mishimoto hoses
new gtspec rear sub braces
driveway labs diffuser
namless header with header wrap
apr gt250 wing
front bumper with apr splitter and 5AD kit
seibon dry carbon 2 vent hood
seibon dry carbon oem hood
sa10r with nitto nt01
oem used front rotors
front LCAs with whiteline bushings
used front dba rotors
intake sound tube
engine fuel diapers
direct injection ecu
both rear strut top hats
rear carpet brace and hardware
hood latch
oem brake lines and hardware
oem horn
oem pedal assembly (no gas)
oem rad shroud fans and reservoir
oem jack
oem spare
oem intake snorkel
whiteline swaybar kit
act clutch
fender
back seat (back)
pass side triangle window
front seat with head rest
brake booster
oem muffler
oem rear LCA
OEM rear trailing arm
oem rear crash bar
driver side door
lower rad core support
oem fan shroud and fans
oem mid pipe
oem header
oem over pipe
oem intake manifold
winjet opened headlights
ignition cylinder with key
oem studs
oem ac control
window tracks both sides
new ac compressor
power steering column
rear speakers
airbag module no codes
fog light bezel
shifter bezel trim
spesker trim for dash
oem amp with hardware
jdm ac delete
l and r front amber corner bumper lights
drivee side clear corner light
door harness
window controls
new kdt921 bushings
used 5AD front lip
dash trim
oem grill
sparco evo seat
takata belts
front suspension
front custom bashbar
oem taillights
transmissions
oem driveshaft
Old 11-12-2018, 04:49 PM   #274
alfakarl
Drives: 2013 Scion FR-S & Subaru BRZ
Any chance you have the passenger side Xenon headlight wiring for a BRZ?? Need the plugs and about a foot of wire.
alfakarl is offline   Reply With Quote
Old 11-13-2018, 02:30 PM   #275
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
How much for the dash trim shipped to 22191?
kmbkk is offline   Reply With Quote
Old 11-15-2018, 02:32 AM   #276
pjp
Drives: frs
seats
Have you sold both front seats?
Thanks
pjp is offline   Reply With Quote
Old 11-15-2018, 02:35 AM   #277
pjp
Drives: frs
Plastic
Drivers side Plastic that raps around door piller going to rear sear area?
Old 11-15-2018, 03:59 PM   #278
ENVJFRSH
Drives: 2013 Scion FRS
Hey any chance the mid console area where cupholder/shifter is still available its a pretty big piece im looking for i checked the list but couldnt see it
ENVJFRSH is offline   Reply With Quote
Old 12-11-2018, 04:03 PM   #279
MicheleAbbate
no sorry
all dash trim are sold.
Thanks
i still have the passenger front seat
the B pillar? sold sorry.
sorry this was sold a while ago
Old 12-13-2018, 09:46 AM   #280
vladniko86
vladniko86's Avatar
Drives: FRS
Did you guys get the rubber thing that the top of the window rubs against? The seal that holds out water
vladniko86 is offline   Reply With Quote
(Nearly) Complete 2013 Subaru BRZ Limited interior part out DatApex Interior Parts (Incl. Lighting) 79 01-22-2014 03:46 PM
Scion frs interior part out Jhon19lopez Interior Parts (Incl. Lighting) 29 08-14-2013 08:22 PM
Full FR-S Interior Part Out Evasive Motorsports Interior Parts (Incl. Lighting) 22 01-06-2013 12:17 AM
FS: Full factory interior PART OUT (headliner, rear seats, covers, etc) NRG x FRS Interior Parts (Incl. Lighting) 44 11-28-2012 01:24 AM
2013 Scion FR-S Full Test... brz_guy Scion FR-S / Toyota 86 GT86 General Forum 1 04-25-2012 04:28 AM
