Old 11-09-2018, 03:16 PM   #20049
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Cleaned the engine bay! Not 100% but much better than it was.
Old 11-09-2018, 03:41 PM   #20050
eastendraceshop
eastendraceshop's Avatar
Drives: '13 Scion FR-S & '17 Toyota 86
That engine bay is looking great!
eastendraceshop is offline   Reply With Quote
Old 11-09-2018, 04:03 PM   #20051
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Looks great!! Are you painting your bars?
I LIKE TIRES!
Old 11-09-2018, 04:05 PM   #20052
Grady
Grady's Avatar
Drives: BRZ Yellow, Ranger, Evora, WCM S2K
Except the missing factory strut bars, and that oil cooler line needs to be rotated down. But yes it is nice and clean looking.
Old 11-09-2018, 10:15 PM   #20053
DarkPira7e
DarkPira7e's Avatar
No, when I bought the car they were missing, haven't replaced them yet! I have been looking for a good price for some used, but they never come up
Yeah the lines Mishimoto sent me were a little too tight, so I went with this setup until I can get a couple new lines and AN fittings to replace these for better fitment.
Old 11-10-2018, 10:10 AM   #20054
Grady
Grady's Avatar
You can shorten that line yourself. It is not hard PM me I can walk you thru it.
Old 11-10-2018, 10:18 AM   #20055
Ashikabi
Ashikabi's Avatar
I agree with the guy below. I dunno what style fitting mishimoto is using but if it doesn't use an olive (like a normal compression fitting) then you can just remove the hose end, cut the hose, and reinstall
Old 11-10-2018, 12:01 PM   #20056
DarkPira7e
DarkPira7e's Avatar
I could, but I'm re-doing the lines when I put the turbo in anyway, I think I'm going to move the oil cooler a bit. I'm just thankful it doesn't leak and I'd like to leave it that way until I make my changes
Thanks to @Ashikabi I'll have strut braces soon too! Now I can stop saying I've removed them for ice racing, weight reduction, etc
Old 11-11-2018, 01:01 AM   #20057
eastendraceshop
Washed and oiled my VERY dirty TRD intake air filter, as it has been long overdue. Noticed a nice improvement in induction noise, exhaust noise, and throttle response.
Old 11-11-2018, 01:37 AM   #20058
Good show.
Thanks for the reminder, I should do that someday, it's been about 3 years now.
I do believe that I have some coal oil and 30 weight, non-detergent oil around here some where.
Oh, screw the MAF, if it can't take a joke!
Old 11-11-2018, 03:45 AM   #20059
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Good show.
You have a TRD intake?
Old 11-11-2018, 03:46 AM   #20060
Sapphireho
Famous Potatoes
Sapphireho's Avatar
I took the blue tape off the new windshield.
Old 11-11-2018, 10:03 AM   #20061
littlezav
Drives: b
Originally Posted by Hypnocracy View Post
Went to the Autozone to buy something to remove hard water spots or wax steaks from my windshield...they didn't have the RainX goo remover or 0000 steel wool I was after...they did have two 9011 Bulbs...
The streaking on the windshield is madding...in the morning after the dew has been hit with the wiper blades...the remaining moisture has to air dry...no amount of wiping removes it and in the dark of early morning an oncoming car or street light illuminates the moisture where it is as opaque as frost until the light source moves past...so...checking the internet for ways to clean my windshield.
1. White Vinegar. My wife keeps a gallon to add to the wash or use as a natural cleaner. Soaked a hand towel and started rubbing...cleaned with water and still see the same pattern. No improvement
2. Dawn Dish soap. Rinsed the hand towel...liberal amount of liquid soap...rub in circles...horizontal strokes...vertical strokes...rinse....ugh...
3. Really frustrated at this point...so I go with the brillo pad...Wet the glass and start to do circles...this feels promising...as I work to new areas the pad grabs on the first stroke and the following stroke feels easier...once the entire area has been worked I rinse and dry...pattern is still there but maybe...just maybe faded.
Cleaned windshield wiper blades
I give up. Waiting til my next early morning dew-commute to see if it has improved...on to the high beam bulb modification.
Last week I modified the low beams using a H11 bulb...It is noticeably better...at the time there was only one 9011 bulb for the high beam mod...so I put it off til I found two...different Autozone and $50 later I pull out a hack saw blade and needle nose pliers...compare existing bulb to new one and see I have to remove a heavy 1/8 of top tab. Make cut with hack saw (holding blade in my hand) and break away the waste with needle nose pliers. They install without issue.
Night comes...grab a 32oz cup of water...splash on the FR-S windshield...hit the windshield wipers and pray...promising results blades seem to cut the moisture...I'll have to wait til the morning dew point is close to the actual temperature to see if there is improvement.
Head to the country two lanes to get away from street lights...hit the high beams...I'm pleased with the improvement of the bulb swap-mod compared to stock...Easy no pulling off the front clip to remove headlight buckets and putting them in the oven etc. etc.
clay bar.
littlezav is offline   Reply With Quote
Old 11-11-2018, 10:29 AM   #20062
mrg666
pessimistic skeptic
mrg666's Avatar
Winter checkup complete, battery, tires, oil, brakes ... ready!
