Drives: 92 lexus sc300 > whiteout MT FRS
Value spring recall and TOB clutch issue
I took my Frs to the dealer for the TOB clutch TSB and was told my extended warranty will not cover the premature wear on my clutch and have to shell out 1k to replace my clutch. Since the recall requires the engine to be lifted do you guys think the dealer will cut me some slack n the clutch labor? I think that Toyota dropped the ball on this clutch issue.
#2 |
I had the TOB chirping issue come up right before the extended warranty ran out. I talked to the dealer, they were able to recreate the issue and said that the TOB replacement would be covered under warranty. They did offer to replace the clutch since they would have it apart and it would "save on labor", but they still wanted $1k for the clutch, pressure plate and resurfacing the flywheel. It sounds like they are cutting you some slack on labor, but it can't hurt to ask.
My clutch hasn't been slipping, so I decided to hold off on the replacement. |
#3 | |
Talk to them if it will save some costs. We can't guess what they will do.
#4 | |
| The Following User Says Thank You to Tcoat For This Useful Post: | Bonburner (11-02-2018) |
#5 |
Yea, I took my FRS to the dealer 2 months ago when I noticed the clutch grinding when I engaged the clutch. I told them that I saw a TSB on the TOB but they cannot do anything till I can replicate the issue. So I kept driving it till it got worst and I complained to Toyota about it. Maybe If they would have fixed the TOB then I would not have to replace the whole clutch assembly.
#6 | |
Wheels for Brains
#7 | |
Drives: '13 BRZ Limited
Get this : Dealer quoted me $2500 for the clutch job. Wanted me to authorize $750 for teardown now to get started. They apparently gave Subaru of America the $2500 quote as the work that needed to be done when they were contacted about my case to verify the problem. I don't feel they are helping me out any there... From what I can tell - list price on everything would be about 780 (Flywheel, pressure plate, disk, TOB, clutch fork, pivot, 8 flywheel bolts, 6 pressure plate bolts, clutch fork spring, 2 TOB retainer clips) - How do they get $1700 in labor? #@&*!)$ Get all the parts from an online source and resurface the flywheel and it's closer to $400. Probably a little less if I get an exedy vs Subaru. Kind of doubt I need a clutch fork, but it's $20... Called 2 local shops and they want about $800 in labor. Happy Holidays!
#8 | |
If just the TOB is bad they do not need to replace anything else. If it blew and took out the clutch than $2500 is still way high. I don't remember what I paid for the whole works but it wasn't that much.
#9 | |
Drives: 2017 Subaru BRZ PP WRB
| The Following 3 Users Say Thank You to NCtoBRZ For This Useful Post: |
#10 | ||
I thought I'd just try as this is a known issue with a defective part and I've seen a couple of people who had luck getting it covered under the powertrain warranty. Kind of feel like it should be covered - 35,000 miles for a TOB failure is way too early - had several other cars go > 70,000 before trading them with the original clutch and TOB working fine. Odd that the Subaru Clutch disk is $170 retail, while the Totyota is ~90. TOB is similarly cheaper $21 vs $55. Rest of the Subaru parts seem to be cheaper than the Toyota ones. |
| The Following User Says Thank You to 86league For This Useful Post: | Tcoat (12-04-2018) |
#11 |
[insert cool phrase here]
Drives: BRZ Premium
Holy shit, that is price rape.
I did the tob with a bad back, on the floor with basic tools, and a beer in one hand. I did have a friend help pull it out and put it in but that was due to my limited back strength. If I had a lift and air tools/stands I bet I can do that in an hour. Sounds like your best bet is to take it to some local auto mechanic. At best maybe $600ish with parts included
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged Last edited by Mr.ac; 12-04-2018 at 02:15 AM. |
| The Following User Says Thank You to Mr.ac For This Useful Post: | funwheeldrive (12-05-2018) |
#12 |
Good luck with that. When I needed to do mine last summer the best price I could come up with anywhere in the extended NY Metro area (hundreds of good shops) was ~$1200.
#13 | |
Drives: 2017 BRZ
That's your angle then, of they refused to repair because they couldn't replicate till 2mo later and xyz miles, to can makea case that it contributed to the clutch issues you now face. May not help, but be nice about it, and be consistent and reasonable in what you're asking for.
#14 | |
Subaru of America offered $600 toward the TOB replacement. Trouble is all of the dealers around here quoted around $1200 for the job (SoA had this quote). I didn't have a good feeling that they wouldn't find a clutch that needed replacement, then I'm paying list (or over) for parts and $165/hr for labor. AllData shows 6.5 for the TOB job, +0.4 for clutch disk and flywheel. A lot different than the #s shown in the TSB. Going to do it myself. |
| Possible recall on the 86 regarding valve spring | tanner | CANADA | 84 | 11-28-2019 10:32 PM |
| VALVE SPRING WORLD - PRESS RECALL | Trap63 | Issues | Warranty | Recalls / TSB | 85 | 03-13-2019 12:38 AM |
| Worldwide Power Steering Issue Safety Recall | nzer | Issues | Warranty | Recalls / TSB | 27 | 08-08-2016 07:14 AM |
| Clutch engagement issue. Possible clutch cylinders upgrade? | wu_dot_com | Engine, Exhaust, Transmission | 42 | 04-05-2016 01:11 PM |
| FS: MTEC Shifter Spring Kit + Clutch Spring Kit BRAND NEW $59 shipped | susko | Transmission and Driveline | 2 | 01-21-2016 04:42 AM |
