Drives: 16' BRZ
Radium surge tank
Who has a surge tank setup? What has your experience been? I'd like better fuel filtration and to be able to track with less than half a tank.
#2 |
Are you ready to wear a fire suit every time you're in the car? Are you boosted? Ethanol?
A stock car on NA power with gasoline can run quite low. |
#3 |
Drives: BRZ 2017 Pure Red, MT
If you don't already have the Verus fuel flapper door, you could try it.
https://www.verus-engineering.com/pr...tarvation-door There is a thread somewhere on this forum about it. |
| The Following User Says Thank You to nico_rsx For This Useful Post: | DarkPira7e (10-31-2018) |
#4 |
Drives: 16' BRZ
Car is far from stock it will have an LS3 crate motor running on MoTeC. I’m walking a fine line between street and track car for now. Eventually if California doesn’t want to let me drive it anymore it will be caged and towed to and from the track. You really think I can’t drive it without a fire suit? I’ve found the stock fuel filter to be inadequate so aside from being able to run hard down to empty I’d like some more peace of mind when it comes to the fuel being filtered.
#5 | |
Drives: 16' BRZ
#6 |
Drives: 2016 White Pearl BRZ Premium
I still fuel starve towards the end of a session with the velox fuel flap door installed if I go out with less than 2/3 tank
![]() It's not a cure-all. |
#7 |
Drives: 16' BRZ
That’s what I’ve heard. Thanks for your input. I’ll probably be going through half a tank in a 20 min session. So it sounds like a surge tank would almost be mandatory.
#8 |
yep. I go through a little more than a 1/4 tank per session. If I go out with a half tank or a hair more, I'll starve before the session is over.
#9 |
Well I think it works on NA+tune, but if you're swapping the engine for something that will use that much fuel, then no the flapper isn't going to be enough.
#10 | |
To put it in perspective, I would consider a fire suit to be higher priority over a HANS type device, or even air bags, with a surge tank. Imagine if someone hit you on the road, and a link just barely got kinked and springs a small drip. Things involving fuel and a lot of hot surfaces (and a car has a LOT of those), can get ugly very quickly. |
| The Following 5 Users Say Thank You to CSG Mike For This Useful Post: | byun (02-27-2019), CatDaddysBBQ (11-06-2018), ka-t_240 (02-27-2019), norcalpb (04-22-2021), Tristor (02-27-2019) |
#11 |
Drives: 16' BRZ
What about Radium's fuel pump hanger? Anyone have this?
#12 | |
Drives: 16' BRZ
#13 |
Drives: FR-S Turbo
#14 | |
Drives: FR-S Turbo
You sure it's installed correctly? No problems with your fuel pump? I'm boosted and can practically run down to vapours without issue. I see close to 2G's cornering and consistently hit 1.4G's braking on the track. |
| DIY : Draining the gas tank - Methods to empty fuel tank | Mermoz | DIY (Do-It-Yourself) Guides | 13 | 10-09-2025 03:56 PM |
| JUN GT SURGE TANK FOR FT86/BRZ | scubie.brz | Engine, Exhaust, Transmission | 60 | 11-23-2020 08:48 PM |
| Radium Engineering developing dual in-tank pump hanger | slicktop | Forced Induction | 18 | 06-13-2017 03:42 AM |
| SARD Surge Tank Kit w/ ITB from TAS 2017 | mav1178 | Engine, Exhaust, Transmission | 50 | 05-12-2017 11:50 PM |
| Moto East / Deatschwerks Drop-in Surge Tank - tech & discussion | Xero-Limit | Engine, Exhaust, Transmission | 42 | 04-27-2017 10:16 PM |
