Old 11-01-2018, 01:11 AM   #183
Tristor
Tristor's Avatar
Originally Posted by GrandSport View Post
No other thoughts on price/value of the track car?
If you believe the modifications that are already done to the car are to your liking and standards, then $17k ready to go is not a bad deal. It's mostly a question of whether the setup will work for you, since a track vehicle setup is somewhat of a personal preference.
Tristor is offline   Reply With Quote
Old 11-01-2018, 03:58 AM   #184
CSG Mike
CSG Mike's Avatar
I think he said it was 2550lbs. No AC but still has power windows.
As far as coilovers, they're not the best, but honestly, shocks don't make THAT big of a difference.
When my magnetic ride controller overheated and failed mid day, and I was riding on all 4 at their softest setting, I was < 1 second slower. That's going from an electronic, dynamic/on the fly suspension controller that adjusted every tenth of a second or something like that based on loads and acceleration, etc to having full soft. I definitely made some adjustments (and then more adjustments when I got a new one) but once I made them, I was fine.
If this was supposed to a super competitive race car, sure, there are many reasons to spend big bucks. But for HPDE, I'm not concerned.
They make a HUGE difference, when your lap time is mainly made up by cornering faster, rather than optimizing your corners for powering out the exits.
Heck, even on your Vette, I'd put good money that while you only lost 1 second to a failed controller, you'd gain many seconds with a nice set of Penskes, JRZs, Ohlins, or similar.
Joesurf79 (11-01-2018)
Old 11-01-2018, 10:30 AM   #185
GrantedTaken
Are you looking for a pure track car?
Or a trackable street car?
That is your answer.
GrantedTaken is offline   Reply With Quote
Old 11-01-2018, 10:58 AM   #186
GrandSport
GrandSport's Avatar
Drives: 13 Viper; 14 BRZ; 90 Miata; 18 AMG
Man, I don't know. The difference from street tires to slicks is like 2.5 seconds. Super Sports to Cup2 was a bit under 2 seconds for me. You ask any racer would they rather run slicks and crappy shocks or the best shocks and street tires, and the answer will be very unanimous.
2014 BRZ: WRL Build (GP2) MCS, AP, Motec, race wiring harness, blah blah blah
2014 FRS: Similar WRL Build. Back up / parts / practice race car.
2013 Viper GTS : Tractive Coilovers, ACR sway bars, aero, carbon, exhaust, etc.
1999 NB Spec Miata: 1.8 w/ all the goodies.
2022 CT5 Blackwing: Stock.
GrandSport is offline   Reply With Quote
Old 11-01-2018, 11:31 AM   #187
tony_r
tony_r's Avatar
Drives: '15 STX
A proper set of shocks make a huge difference, particularly at tracks with aggressive curbing and/or fun bumps. That said, you do not need to go as expensive as Penske to get that.
tony_r is offline   Reply With Quote
The Following User Says Thank You to tony_r For This Useful Post:
Old 11-01-2018, 11:37 AM   #188
fatoni
You're right. I quit eating healthy, because while healthy food isn't that beneficial, any person knows that drinking water is more important
Drive upgrades. Don't buy them.
Old 11-01-2018, 11:49 AM   #189
GrandSport
GrandSport's Avatar
huh? I said I don't think shocks are as important as slicks, and slicks are only about 2 seconds above street tires. Therefore, good shocks to mediocre shocks won't be "many seconds" faster- not that you shouldn't upgrade suspension at all. You'd really be surprised how little difference shocks make on lap times. They matter, but not nearly as much as stuff like weight, power, and most important- tires.
Old 11-01-2018, 12:09 PM   #190
Lynxis
Lynxis's Avatar
Drives: 2013 WRB BRZ 6MT
Something to consider is cost to repair if you end up colliding with something which is not a matter of if, but when. I've had a few destructive off-track excursions now and I personally had a very hard time finding used parts in decent condition for these cars that were close enough to bother with and pray you never need a quarter panel repair.
Edit: The point I nearly forgot to make is to just consider what it might cost you to fix damage caused on track. I spun once and ended up ass end first into a concrete barrier that ended up costing me about $6000 to fix and that was with me doing all of the work I could do by myself which was basically anything but cutting and welding.
Lynxis is offline   Reply With Quote
Old 11-01-2018, 12:11 PM   #191
tony_r
tony_r's Avatar
Drives: '15 STX
You cant quantify the difference shocks make like that, since what they add is control and consistency. It's the difference between an upset and unruly car, and a stable, predictable car you have confidence in.
I will always be faster lap over lap with a proper set of shocks.
Old 11-01-2018, 12:26 PM   #192
GrandSport
GrandSport's Avatar
Agreed. The laps with the shocks out (or their controller anyway) were definitely more white knuckle, but I was one of 3 cars on track that day. Overall difference was only about a second (which is an eternity in a race) but yeah, I wouldn't want to race wheel to wheel like that. I just don't see gaining 2 or 3 seconds on shocks alone. Like I said, it was <1 second difference from an awesome (for OEM) electronically controlled setup to those shocks at full soft running (effectively) solo laps. I can't see one aftermarket coilover system to another being some sort of massive jump.
One of the many reasons for FRS/BRZ over the Grand Sport. My splitter alone is $2k.
The Following User Says Thank You to GrandSport For This Useful Post:
CSG Mike (11-01-2018)
Old 11-01-2018, 12:45 PM   #193
Racecomp Engineering
One of the first questions I have when looking at a track car listed for sale is: Who built the cage? Is it good?
- Andrew
Old 11-01-2018, 12:55 PM   #194
GrandSport
GrandSport's Avatar
- Andrew
I have pictures and it looks (lol) to be pretty good. It was professionally installed by a reputable shop. Nothing about this build makes me think corners were cut in the sense of half assing it. Obviously, you can always buy more expensive parts, but it's not like the guy was using dry wall screws to mount stuff.
Assuming done well and clean (and I'd verify in person), what do you think it's worth on the market? I'm a bit new to this FT world and this is anything but a generic stock car.
Thanks!
Old 11-01-2018, 12:57 PM   #195
Thanks!
Can you PM a link? I promise I won't buy it lol.
- Andrew
Old 11-01-2018, 01:05 PM   #196
cjd
cjd's Avatar
Drives: 2017 BRZ
If the shocks (spring rates/damping/etc) can't handle slicks, you're in for a rough time either way.
Maybe I'm in the minority, but I'd take a well tuned suspension setup over stickier tires any day.
Contemplating Fix bumper or buy aftermarket. Earlier than expected choice Heat Sinker Cosmetic Modification (Interior/Exterior/Lighting) 1 05-30-2016 04:34 PM
Contemplating LS swap, brakes to suit the package? hayden55 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 03-07-2016 03:42 PM
Contemplating new ARP studs ... anyone with bad experiences? donoman Tracking / Autocross / HPDE / Drifting 20 06-02-2015 12:50 PM
Contemplating buying used BRZ with tons of mods but is it worth it? Sebaru BRZ First-Gen (2012+) — General Topics 48 07-19-2013 11:25 AM
Contemplating Raven Purchase Please Advise steve87j Scion FR-S / Toyota 86 GT86 General Forum 27 11-29-2012 10:44 PM
