go_a_way1, MisterSheep
Old 10-29-2018, 09:33 PM   #19867
Ashikabi
Ashikabi's Avatar
Originally Posted by Impureclient View Post
I would do satin or even glossier. Higher sheen = longer lasting and easier to clean. My current wheels came in a matte finish and that's the only thing I'd change is do a gloss clear on them if I ever refinished them.
The only good thing is the matte finish hides the brake dust better but that's on a matte black finish and you are doing silver.
Matte black wheels hide brake dust because they already look like they are 100% covered in it
The Following 2 Users Say Thank You to Ashikabi For This Useful Post:
Impureclient (10-29-2018), Leonardo (10-29-2018)
Old 10-29-2018, 09:42 PM   #19868
Impureclient
Drives: 2015 FR-S
Yep, when it's time to clean them I just have to trust I actually did so because they always look "clean" or "dirty" depending on how you think matte black looks on a wheel.
The Following User Says Thank You to Impureclient For This Useful Post:
Old 10-29-2018, 09:51 PM   #19869
Decep
Drives: 2013 FR-S Series 10
Originally Posted by ELLSSUU View Post
Refinished TRD wheels for my son. Two were slightly curbed. All had paint chipping that is apparently common with these. Sanded, scuffed, filled, cleaned and painted with a General Motors GunMetal color that was close as I could find. Just a bit lighter than the OEM TRD color. Still need to paint the barrels, apply the red to the sunken TRD center cap emblems and clear coat all.
I have not decided wether to clear them with a Satin or Matte clear. Suggestions?
no suggestions just want to say those wheels are awesome! best OEM wheel imo. wanted those but ended up going with cheaper rpf1s.
Old 10-30-2018, 06:05 PM   #19870
Face_Plant
Face_Plant's Avatar
Drives: 2015 Scion FR-S
Today I completed my Rexpeed convex heated mirror install by installing the relay for the heated mirrors and tested them out. Both mirrors got warm after about a minute with no blown fuses, burning electrical smells, etc. Needless to say I was quite pleased that the effort I put into adding the proper wiring to the factory harness was worth it.
I also installed the windshield adapter for my auto dimming compass mirror, fed the wire through the headliner, installed the wire cover, and installed the new mirror. I'm still waiting for my wiring harness to arrive so I can plug it into the connector hiding under the headliner.
The last thing I did was order a new clutch slave cylinder with a 3/4 bore as outlined in a thread by @Ultramaroon that I stumbled across last night. I can't stand this clutch anymore and everyone who drives my car complains about the clutch, so this slave cylinder will supposedly solve all of my problems.
Edit- to add to our debate about the 86 Speed hood struts from the other day: the shiny stickers that say "86 Speed" have begun to peel off of both struts after owning them for a few days. The struts themselves still work fine, but the stickers seem pretty cheap.
Face_Plant is offline   Reply With Quote
The Following User Says Thank You to Face_Plant For This Useful Post:
Ultramaroon (10-30-2018)
Old 10-30-2018, 06:44 PM   #19871
Ashikabi
Ashikabi's Avatar
Shoulda spent the extra $45 for the Grimmspeed stickers
The Following 3 Users Say Thank You to Ashikabi For This Useful Post:
Face_Plant (10-30-2018), Impureclient (10-31-2018), Leonardo (10-30-2018)
Old 10-30-2018, 07:33 PM   #19872
Face_Plant
Face_Plant's Avatar
Maybe I should have. The shiny stickers on the shocks were the main reason I bought them and now that the stickers have fallen off I have no reason to like them anymore...
The Following 2 Users Say Thank You to Face_Plant For This Useful Post:
Impureclient (10-31-2018), Ultramaroon (10-30-2018)
Old 10-30-2018, 07:47 PM   #19873
Ashikabi
Ashikabi's Avatar
What if... You got different stickers?
Old 10-30-2018, 08:15 PM   #19874
Face_Plant
Face_Plant's Avatar
It wouldn't be the same as having the originals
Just to make sure we're all on the same page here, I'm being sarcastic. I don't care about the stickers.
Old 10-30-2018, 08:33 PM   #19875
Ashikabi
Ashikabi's Avatar
Indeed
Old 10-30-2018, 08:35 PM   #19876
Rican_D
Rican_D's Avatar
Drives: Asphalt FR-S
Just a good ole wash and wax
Sent from my Pixel 2 XL using Tapatalk
Rican_D is offline   Reply With Quote
Old 10-30-2018, 08:38 PM   #19877
I need to get off of my ass and do this. I've had the OEM heated mirrors in a box under my coffee table for 3 years. :/
Old 10-30-2018, 08:44 PM   #19878
I would die a little inside every time I saw them.
Old 10-30-2018, 09:15 PM   #19879
Face_Plant
Face_Plant's Avatar
Adding the wiring to the door harnesses isn't hard if you have the right tools. It took me a day to do both sides, including adding the wiring to both mirrors, all without proper tools (I used weed whacker line to pull the wires through the cableways in the doors instead of a fish tape).
I'm going to see if I can reattach them with some glue before removing them entirely.
Ultramaroon (10-31-2018)
Old 10-31-2018, 12:02 AM   #19880
johan
Drives: '14 981CS, '99 NB1
You install the hood struts yet?
johan is offline   Reply With Quote
