#141 | |
Drives: 2017 toyota 86
The trumpets/velocity stacks makes sense, but does the GReddy system utilize this? Once the ITBs are all open it seems like it is functioning pretty much the same as a normal manifold just different runner lengths for shifting power band not really increasing. Also If the stock system flows more then enough air already, would it matter if some cylinders had more access to air then others if none are still getting less then they utilize? Which seems to be the case if larger TBs and bigger manifolds haven’t shown any gains. |
#142 | |
can flow =/= does flow, just how a 80mm exhaust doesnt offer gains over a 63mm exhaust, on a stock car. The unfortunate part of all this testing is that it's taking far longer than expected; it seems I will not have ITBs on my car for SLB this year
| The Following 2 Users Say Thank You to CSG Mike For This Useful Post: | Barefootdan (10-29-2018), RayRay88 (10-29-2018) |
#143 | |
Drives: 2017 86 860 Special Edition
I've never once heard of ITB tuning that goes as planned. I imagine Ecuteks flash tuning doesn't help with the speed. I guess there's a reason the Zerobreau went Motec. Will you be running the manifold style adapter that Greddy provided? Will you try open stacks/individual filters and or dyno with different stack lengths? Still can't wait to see the results, whatever they may be. |
#144 | |
You're right; Ecutek definitely doesnt hurt with speed, although we know some ways to slightly mitigate that. |
| The Following 4 Users Say Thank You to CSG Mike For This Useful Post: |
#145 |
Drives: none
Heya, just wondering if NA testing with ITBs is still a thing or not, as this thread hasn't been active for awhile now :S
#146 | |
Drives: 2014 BRZ
If you want to make a comparison, look at the Honda K-series, which has been out since 2001. Tuners and engineers didn't make substantial NA power out of them until the 2010's. And that's in spite of the fact that there was much greater demand because Honda stuck them in all of their most popular models (Civic, RSX/Integra, CR-V, Accord). Compared to our cars, we're dealing with an engine that's found in literally one vehicle that's sold in very low volume, to a market that doesn't really have deep pockets to begin with. It's going to be a slow-moving process to say the least. I'm just glad there are tuners out there who are continuing to spend time and money to develop these parts despite the fact that they'll likely never see a big return from their efforts. AND they're being transparent about the process. |
#147 |
StreetKart
Drives: 2014 Scion FR-S Monogram
Right now this is a hype thread... if csg and their tuner aren't going to follow up they should say so instead of letting the hype monster 5000 spin it's wheels.
I've found one guy with the sard unit and he said it made big mid-range gains. Matt Busby at national corvette museum is putting the GReddy set on his BRZ track car now and from what I've seen in his posts about it the instructions are garbage and he's had to make runs to the hardware store for missing bolts from the kit. Sent from my Pixel 2 XL using Tapatalk
TRD|Verus Engineering|Titan7|DEZOD Motorsports|JDL Auto Design
#148 |
StreetKart
For those curious about Matt's experience with the GReddy units. He's been posting to his Instagram https://www.instagram.com/the.matt.b...=103okhbjkk5v7
#149 | |
How is it hype when both people that have them up and running are making very decent mid range hp/tq bumps? I think people are mistaking these for FI alternatives. ITB's are never big power-getters. The only time I've seen them make huge power numbers are on motors where the valvetrain/heads are built to the point where it starts out flowing traditional manifolds or had trash manifolds to begin with. |
#150 | |
Drives: A Hot Mess
there are 2 setups that will benefit greatly from this, built high compression motor that redlines at 8k+ with cams and uses e85... the e85 allows the motor to run cooler and with the increase of air at lower RPMs and the more aggressive cams and high redline will widen the spread of the ITB midrange gains, but even then you wont get any "peak gains" over say a ported 2017 manifold and a grams throttle body. forced induction, having the 4 throttle bodies with a turbo and e85 with allow the compressed air to flow in at an even greater rate and colder due to the e85 than the stock plastic manifold and pump gas. i think that jade_350z has a dyno showing this on his car with the gt2867r kit as well... gushi also ran his car with the itb and t518z set up but both only used pump gas. if someone buys a stock frs and throws these one and expects to get their moneys worth, they will be severely let down... if you tie in the rest of the mods to actually use the ability for the ITBs to be put to use... then it can be worth while.
one of the first people to ruin the frs.
#151 |
Drives: 2013 frs red
Everyone is looking for the next big na power mod.
#152 | |
Keep in mind now, the engine will be ingesting measurably warmer air. |
#153 | |
Not necessarily, the benefits of ITB's can still be had with a plenum attached. It's hard to tell but there have been Cam threads that show the gains were minimized due to flow restrictions in the intake manifold. |
| The Following User Says Thank You to RayRay88 For This Useful Post: | Tokay444 (02-12-2019) |
| In for the long haul Ultimate NA build thread. | celek | Engine, Exhaust, Transmission | 669 | 06-07-2020 06:26 PM |
| TOG ULTIMATE TOYOTA 86 GT86 FT86 SUBARU BRZ FA20 STAINLESS STEEL EXHAUST HEADERTOG UL | Andrew666 | AUSTRALIA | 8 | 11-19-2018 04:24 AM |
| RallySport Direct's Ultimate Drivetrain Thread! ***New Website*** | RallySport Direct | Transmission and Driveline | 92 | 09-01-2015 12:17 PM |
| RallySport Direct's Ultimate Interior Thread! | RallySport Direct | Interior Parts (Incl. Lighting) | 45 | 03-25-2015 01:12 PM |
| Ultimate coilover thread, What do you run on your car? got REVIEWS post it up! | THMotorsports.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 12-11-2013 05:25 PM |
