Old 10-20-2018, 12:15 PM   #1
stlgrym3
First oil change on BRZ runs E85
My car currently at 3200 miles. Last 500 or so miles were using E85 by the way of flex fuel kit. I know the first oil change is at 5000 miles, do I need to do it earlier since I’ve started to run E85? I’ve read running E85 burns oil quicker?
What grade of oil and how many quarts our car requires? I assume I can purchase the oil filter from dealer. Is there a good place to buy these stuff cheaper than dealer?
stlgrym3 is offline   Reply With Quote
Old 10-20-2018, 12:41 PM   #2
Lantanafrs2
Drives: 2013 frs red
Why not let dealer change it? You re supposedly getting rid of the car anyways. Why all the questions?
Lantanafrs2 is offline   Reply With Quote
Old 10-20-2018, 12:57 PM   #3
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
here is 2750 miles on e85 which include 4 autocrosses. i used synpower 0w20. you can make the call
Old 10-20-2018, 01:50 PM   #4
Tristor
Tristor's Avatar
There's tons of information on here about oil and oil changes in the stickies... If you're planning on doing oil changes yourself over the long haul it's worth it to get a Fumoto oil drain valve.
Beyond that, you should use 0W20 full synthetic oil from whatever your preferred brand is if you're primarily daily driving and you live anywhere where the average temperature in the summer doesn't exceed 100F. If you're in a hotter climate or you beat on the car a lot, you could consider running 5W30 instead.
Any brand of oil will do as long as its full synthetic. In the US, Mobil 1 is a good option since it's easily available at a reasonable cost (Costco has 6 quarts for $27 right now). The engine fill is 5.7 quarts, but I find it's closer to 5.5, with my oil cooler installed it's basically bang on at 6 quarts. Give it 5.5 and then take a dipstick reading after letting it settle for a bit and it'll let you know if you need to add more. Oil filter is the same deal. The OEM oil filter is pretty good, but you can also use any of the quality brands of filters without any issue. I was previously using OEM filters and Mobil 1 and I've switch to AMSOil w/ AMSOil filter, I honestly can't tell much difference even on my used oil analysis.
Even though this car is "slow" and is inexpensive, it's still a sports car, a performance vehicle, as such it has different tolerances than a vehicle designed for typical consumer usage. You need to be regularly doing maintenance checks on the car so you can find, identify, and correct any possible problems before they happen. This includes things like correctly checking your oil level, checking your coolant level, and checking your tire pressure. I do all of these things every single time I fill up with gas. It takes 5 minutes at most, and lets me keep track of whether I'm burning any oil, evaporation loss of coolant (woo Texas), and maintaining even tire pressure with changes in temperature, humidity, and road conditions.
If you don't yet, you should be doing these things. I recommend you keep a tire pressure gauge, a tire tread depth gauge, a small flashlight (useful for checking coolant levels and checking brake pad wear through the wheel if you have open back calipers), and a roll of paper towels or a stack of napkins in your glove box. We're talking an investment of 5 minutes when you fill up gas and maybe $20 in "tools". It's shocking to me how few people do this sort of basic stuff.
Tristor is offline   Reply With Quote
The Following 4 Users Say Thank You to Tristor For This Useful Post:
Busybee (06-24-2022), humfrz (10-20-2018), Impureclient (10-21-2018), MugsBRZ (11-25-2018)
Old 10-20-2018, 01:57 PM   #5
stlgrym3
I decided to keep this car and sell the other family car instead. I just can’t let the time energy and money I’ve spent on Tuning this car go by the waste side.
The Following User Says Thank You to stlgrym3 For This Useful Post:
chaoskaze (10-30-2018)
Old 10-29-2018, 01:29 PM   #6
tyler_win_photo
tyler_win_photo's Avatar
Drives: 2014 Scion FRS (Asphalt)
0w 20 or 5w 30 whatever floats your boat.
5.5 to 5.8 quarts.. depending on how much comes out and your level after you fill back up. Technically the capacity is 5.8.
Yes you can get an oil filter from the dealer. Amazon or eBay can sometimes be cheaper.
tyler_win_photo is offline   Reply With Quote
Any runs to recommend? anchovy619 Southern California 1 04-11-2016 08:49 PM
One of my runs at the autocross today. MountainManFR-S FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 0 02-23-2014 09:16 PM
My car runs differently now vs. new. Does yours? empower-auto Issues | Warranty | Recalls / TSB 2 07-08-2013 06:26 PM
My Dyno Runs Crewzern AFRICA 4 10-30-2012 04:52 PM
RTR BRZ runs ABQautoxer Tracking / Autocross / HPDE / Drifting 8 10-17-2012 03:33 PM
