Old 10-18-2018, 08:57 AM   #15
DaBoBo21
Brett
DaBoBo21's Avatar
Drives: ‘94 Supra
Originally Posted by cat94 View Post
I guess rattle isn't really the best word, but it definitely sounds metallic, and not a normal souding buzz.
I find that when the sound does happen, and I'm rolling onto the throttle gently the sound is actually louder. However, it is easier to reproduce when jabbing the throttle.
This is a clip of my BRZ from over a year ago. Excuse the exhaust, but is this the noise you're referring to?
DaBoBo21 is offline   Reply With Quote
Old 10-19-2018, 02:08 PM   #16
cat94
Drives: '17 86
Not quite, it sounds exactly the sound in this video 1:00 & 1:40.
cat94 is offline   Reply With Quote
Old 10-19-2018, 03:26 PM   #17
DaBoBo21
Brett
DaBoBo21's Avatar
Drives: ‘94 Supra
I can faintly hear it at the 1:40 mark, but I'm not sure what that could be. Sorry!
Old 10-19-2018, 03:47 PM   #18
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
Isn't that the sound of the LSD?
Old 10-20-2018, 10:38 AM   #19
Jordanwolf
Rice King
Jordanwolf's Avatar
Hello,
I have a 2017 stock 86, and I've noticed in the last couple of months a rattle that's starting to concern me.
When cruising at around 2.5-2.8k rpms completely off the gas, the moment I start accelerating there is a brief (<0.5s) metallic sounding rattle/grinding noise. The sound is louder when the windows are down. Also, it doesn't always happen. Sometimes it is extremely noticeable, and I can consistently reproduce the noise. Other times it is very quiet, or doesn't happen at all.
Every gear will cause the rattle, but I've noticed that higher gears are worse. My guess is because higher gears take slightly longer to leave the RPM range of the rattle.
I'm planning on taking the car in under warranty for a squeaky clutch, and want to explain this problem too. Has anyone ever experienced something like this?
This sound exists in every single 2017+ manual 86/BRZ I have driven. Toyota Canada, as far as I know is deeming this a non-issue until further....very, very casual investigation finds it, or a customer can pinpoint the issue with evidence.
Source, going to Toyota basically since I've gotten my car over and over and calling head office over and over.
Glorious Honda.
Jordanwolf is offline   Reply With Quote
Old 10-20-2018, 01:42 PM   #20
Tristor
Tristor's Avatar
From listening to your video, it sounds more like a crunching than a rattle. Does it feel different when it occurs as well? Sounds like it might be diff or gearbox... but I'm not sure.
Tristor is offline   Reply With Quote
The Following User Says Thank You to Tristor For This Useful Post:
DaBoBo21 (10-20-2018)
Old 10-20-2018, 05:20 PM   #21
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
Nice to know they're waiting for me. I'm not in a huge hurry, but I'll find it.
How do you think a torsen lsd works?
Old 10-21-2018, 02:07 AM   #22
626reppin
Drives: 2018 Toyota 86 GT
I just found this thread. My 2018 Toyota 86 has this noise as well
626reppin is offline   Reply With Quote
Old 10-21-2018, 04:23 AM   #23
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
[ame]https://www.youtube.com/watch?v=JEiSTzK-A2A[/ame]
Quite a bunch of spinning gears for a potential for brief rattling when spur/worm wheels when suddenly locked?
Old 10-21-2018, 08:14 AM   #24
RZNT4R
That's a torsen type a that does have a bit more gear lash than the type b used by the 86, but it would never be this loud, heck, a G80 locker isn't this loud
Old 10-22-2018, 03:02 AM   #25
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
we have no sound deadening besides 1 pad on each side of the rear quarter panel. I hear rock rattles in this car. I hear the transmission gear rattling, why not the LSD rattle?
[ame]https://www.youtube.com/watch?v=5WdySzQtSSA[/ame]
Ultimately same situation. Gears in standing motion until sudden input causing adjustment in torque transmittance which may be causing the rattle.
At least for me, that's the direction the noise seems to be coming from.
Old 10-22-2018, 06:13 AM   #26
RZNT4R
If you'd've been reading what I posted, you'd know the sound is resonating in the engine block because I've been using a DSO on the knock sensors to pick it up.
If you're telling me rattle from the gear lash in the diff isn't getting lost in the super soft diff bushings, is making it's way up the driveshaft, through the transmission, through the sprung clutch hub and is showing up on the knock sensors clear as day,
Fine, but do more than just throw the idea out there, test and investigate. At least I'm doing real tests to find it.
Old 10-22-2018, 06:41 AM   #27
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
1) I don't have interest in purchasing equipment for something that I think is not an issue
2) my results would hold little value as my vehicle is not the same as your & equipment would be different - my results would be moot to you with various confounders.
3) you could easily slap on your sensors near/on the diff and check the peak sound wave oscillation. If its higher/highest near/on the diff, you're closer to the source.
4) dif bushings aren't as soft as you're putting it; if the sound is able to reach your ears, those very vibrations would be able to be picked up in the engine which is connected by solid metal pieces (vibrations travels better through metal than switching through air, metal, air, fabrics, and whatever materials it goes through to get to your ear)
grinding, rattle
E85 specific oil Reaper Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 157 08-09-2016 05:37 PM
Help!! Can't find specific look... cfarris87 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 01-26-2015 03:27 AM
Anyone know where to get FR-S specific key chains? mmieszanek Scion FR-S / Toyota 86 GT86 General Forum 4 02-26-2013 04:28 PM
Specific iso bdanisi Engine, Exhaust, Transmission 1 02-12-2013 09:31 PM
