Old 10-16-2018, 09:40 PM   #1
MJones_RB
MJones_RB's Avatar
Drives: Scion FR-S Series 10 #2462
The hell did the dealership do?
I took my FR-S into the local Toyota dealership for a 27k service (the last service on my ToyotaCare deal). Just wanted an oil change and a fluid check before the big 30k comes around. They also suggested a mass air sensor cleaning (?) and a de-carboning of the engine intake area (hmm...)
They also suggested a brake fluid flushing which I turned down, since I was going to install braided brake lines soon in the future.
When I got the car back, everything seemed okay. While I was driving, I noticed that when I came to a stop, if I pushed in the clutch with the shifter still in gear, the engine would slowly rev up to 2000 rpm, then slowly reduce to idle at 500. If I pushed the clutch in and put the shifter in neutral, the revs would simply go to idle without the odd climbing.
At first I thought it was something to do with the mass air sensor cleaning, but now I'm thinking they did some kind of software update to combat the famous "low idle" issue these 2013 models had. There's nothing in the receipt about a software update but maybe it was a Service Bulletin kind of thing. It almost seems like some kind of "rev match" feature.
I'm going to call the dealership to ask what the deal is, but I thought I'd ask here first. Any info would help.
Needless to say that's my last trip to the dealership for service, now that the ToyotaCare deal is over.
MJones_RB is offline   Reply With Quote
Old 10-16-2018, 10:51 PM   #2
HKz
Reformed
HKz's Avatar
Drives: '23 GRC, '11 Prius, '04 RAV4
I doubt anything happened. I've always noticed my car revving/idling a little funny after every dealer visit but after a bit of a drive it goes back to normal. Always thought it was due to maybe the dealer disconnecting the battery and the ECU having to relearn..got a video clip? 2 k RPMs is a big jump..
HKz is offline   Reply With Quote
The Following 3 Users Say Thank You to HKz For This Useful Post:
humfrz (10-17-2018), Spuds (10-16-2018), why? (10-17-2018)
Old 10-16-2018, 10:52 PM   #3
MJones_RB
MJones_RB's Avatar
I will make one.
Old 10-16-2018, 11:25 PM   #4
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
don't know about your specific situation. But I would unplug the battery then let the car idle for about 5 mins before touching the gas pedal
SuperTom is offline   Reply With Quote
The Following User Says Thank You to SuperTom For This Useful Post:
MJones_RB (10-17-2018)
Old 10-17-2018, 12:26 AM   #5
Originally Posted by MJones_RB View Post
I took my FR-S into the local Toyota dealership for a 27k service ….
Oh, I wouldn't worry about it. The car is just giving you a sigh of relief that they didn't mess it up -
If they messed with the MAF, your car's ECU is most likely just adjusting. I'd suggest you give it a couple hundred miles to settle down.
Old 10-17-2018, 01:05 AM   #6
Chimera
Drives: FRS
I agree with Tom, If they cleaned the maf sensor, I'd pull the battery lead. Fyi, when you do this it resets the ecu including the throttle position learning.. it will feel like dead peddle, this is normal, it'll fix itself.
The Following 2 Users Say Thank You to Chimera For This Useful Post:
MJones_RB (10-17-2018), SuperTom (10-17-2018)
Old 10-17-2018, 01:45 AM   #7
Decep
Drives: 2013 FR-S Series 10
imo next time if it aint broke dont fix it. maybe they used too much cleaner and it needs to burn off/dry off.
Old 10-17-2018, 10:26 AM   #8
It is the MAF cleaner. Well documented symptoms. Also totally unrequired. Same as the "de-carboning of the engine intake". If you have carbon build up in your intake you have bigger issues!
DandoX (10-17-2018), MJones_RB (10-17-2018)
Old 10-17-2018, 01:56 PM   #9
I'd suggest you check the maintenance guide that came with your car. For my 2013 FR-S, the 30,000 mile maintenance is no big things.
But, your dealership may try to make big things out of it ….
MrDinkleman (10-18-2018)
Old 10-17-2018, 02:34 PM   #10
Face_Plant
Face_Plant's Avatar
Drives: 2015 Scion FR-S
... and a de-carboning of the engine intake area...
Why did they do this? The FA20 in the FR-S/BRZ/86 doesn't have carbon build up issues like other Subaru direct injected engines, such as the FA20 in the 2015+ WRX. Our engines have port injection along with direct injection, which helps keep the intake ports and intake valves clean, so "de-carboning" shouldn't be necessary.
Face_Plant is offline   Reply With Quote
The Following 4 Users Say Thank You to Face_Plant For This Useful Post:
Chimera (10-17-2018), MJones_RB (10-17-2018), sato (10-18-2018), Tcoat (10-17-2018)
Old 10-17-2018, 02:50 PM   #11
Not to mention that no mater what injection system they use there should be no combustion nor carbon build up in the intake.
Dadhawk (10-17-2018), MJones_RB (10-17-2018), strat61caster (10-17-2018)
Old 10-17-2018, 03:47 PM   #12
MJones_RB
MJones_RB's Avatar
All good points. Just goes to prove that dealerships RARELY suggest things that are actually needed for specific cars.
The Following 2 Users Say Thank You to MJones_RB For This Useful Post:
Chimera (10-17-2018), Tcoat (10-17-2018)
Old 10-17-2018, 04:26 PM   #13
Just proves THAT dealership does. Not all are like that.
Old 10-17-2018, 05:06 PM   #14
Face_Plant
Face_Plant's Avatar
There shouldn't be, but on directed injected engines it's pretty tough to avoid unless you delete the EGR (if it has an external EGR valve and isn't done through camshaft timing like our engine) and install an air oil separator. The build up on the intake ports/valves in my friend's WRX wasn't exactly carbon. It was more of a thick, black, oily goop.
The Following User Says Thank You to Face_Plant For This Useful Post:
What the hell is this? husker741 BRZ Photos, Videos, Wallpapers, Gallery Forum 27 04-20-2014 04:15 PM
The hell is BMW doing? dem00n Other Vehicles & General Automotive Discussions 39 01-27-2014 12:15 PM
Does your FR-S shock the hell out of you when you get out? ortizwyld Scion FR-S / Toyota 86 GT86 General Forum 58 03-10-2013 12:00 PM
Hell yea!! _F-R-S_ FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 1 11-23-2012 09:46 PM
What the hell is this? Wesley Off-Topic Lounge [WARNING: NO POLITICS] 14 10-31-2012 01:49 PM
