Old 10-15-2018, 09:45 PM   #1
Rai-zero
Drives: Legacy
tS no winter package on Tire Rack?
I have a tS and was curious if the wheels/tires that work for PP would also work for the tS?
Also is there any wheels that TR sells that don't require alternate lug nuts?
Rai-zero is offline   Reply With Quote
Old 10-16-2018, 12:45 AM   #2
J1Avs
Drives: 2018 BRZ tS
Also curious about this!
J1Avs is offline   Reply With Quote
Old 10-16-2018, 01:19 AM   #3
churchx
churchx's Avatar
Drives: 2014 GT86
try brz with PP package, if brembo fitment you are after.
Twins stock lugnuts are of very common for aftermarket wheels 60dg taper conical seat. In most cases stock lugnuts will do.
Leonardo (10-16-2018)
Old 10-16-2018, 05:28 PM   #4
Rai-zero
Drives: Legacy
Is there a Tirerack rep who can give advice?
Old 10-16-2018, 06:17 PM   #5
kch
Senior Misanthrope
kch's Avatar
Yes; anything that will fit the PP should also fit the tS. The biggest issue will be the brake calipers, which are the same between the two trims.
The Following 2 Users Say Thank You to kch For This Useful Post:
Rai-zero (10-16-2018), Stang70Fastback (10-16-2018)
Old 10-16-2018, 08:05 PM   #6
Rai-zero
Drives: Legacy
I was going to park it for the winter and drive my beater car but then I’d be missing out on driving the BRZ so much.
Old 10-16-2018, 08:15 PM   #7
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
The tS has the same brakes as the Performance Pack vehicles. Just select a PP variant, and you should be fine.
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos!
You can also find me on Instagram, and on Facebook.
Stang70Fastback is offline   Reply With Quote
The Following User Says Thank You to Stang70Fastback For This Useful Post:
Rai-zero (10-17-2018)
Old 10-19-2018, 03:22 PM   #8
jflogerzi
jflogerzi's Avatar
Most wheels that fit the twins will probably clear with small 5mm spacer.
2013 Series 10 FRS #553
Old 10-19-2018, 08:51 PM   #9
Rai-zero
Drives: Legacy
I don't want to mess with spacers, do you think wheels certified for PP would work with tS?
Old 10-20-2018, 12:01 AM   #10
jflogerzi
jflogerzi's Avatar
as others said yes as they use the same brakes
Old 10-20-2018, 03:03 AM   #11
ZionsWrath
Thanks
ZionsWrath's Avatar
Let me tell you, you won't miss the rust. If you have a car to DD and not drive your BRZ in salt I would recommend it.
It was a lot of fun working on my BRZ with mininal rust. Mine was exposed the first year but after that it was off the road for winter. It did start rusting the exhaust and some fasteners but not too much.
Anyway that is my opinion. I tracked and had track parts on my car so may be different for you.
Tire rack giving me a hard time on tire size, so please help! NOI Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 09-03-2017 07:27 PM
DIY - Tire Rack KDad2 DIY (Do-It-Yourself) Guides 13 11-11-2016 02:30 PM
Eibach Pro-kit from tire-rack Z86 AUSTRALIA 0 07-13-2012 07:14 PM
Brz limited on the rack at tire rack Nate219BRZ Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 07-06-2012 04:01 PM
Tire Rack still needs a BRZ! Lonewolf Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 06-12-2012 03:35 PM
