Drives: Boosted
2018 Brz issues?
Hey guys, just picked up a new brz from a dealership and I'm not sure if this is common with these BRZ's or it's just mine in particular.
1) When I reverse out my RPM's are stable around 800-1000 depending on how much gas I give but occasionally my RPM would spike up to 1400 without a change in throttle and goes back down to whatever RPM I was at. 2) After shifting from the initial gear to the next, my throttle is like super sensitive like it jerks car even if I softly touch the throttle after letting go of the clutch completely(kinda like a RPM spike), I'd have to slip it into the next gear for it to not jerk. I haven't had this issue with any other car. 3) Really bad transmission noise; sounds like chains pulling when I'm in 2nd gear below 1200 rpm. |
#2 |
Professional Mechanic
Drives: 2017 86 6MT Oceanic
It's kind of hard to picture your backing up rpm thing...
It can be jelly on upshifts at lower rpms. Take out the clutch assist spring to improve clutch feel and thus smooting upshifts. Also, if you're landing your shifts around the mid two thousand revs, yeah it can feel weird and take some practice, there's a big torque bump around there and it gives the throttle an unnatural feeling. Yeah, the trans is def built loose. If you pay attention, idling hot in neutral you can sometimes hear the gears chattering. |
#3 |
Drives: 2017 Brz
Just test drove a limited brz and a Ts last saturday...The Ts was making clunking noises in 1st/2nd when the normal brz was smooth and great to shift. Try out a couple on the lot and see if they do the same thing.
#4 | |
Drives: 2017 BRZ
Opposite cause, but the noise is definitely a thing. The manual transmission is built to rather close tolerances, which can make for finicky shifting when cold. And it always makes it a bit noisier (paired with the fact the car lets through a lot of road/transmission/wind noise to start... weight savings instead of sound deadening) If you're used to a mechanical throttle, this car takes some getting used to in my experience. Also, if the A/C is on, the engine can seem to surge now and again as the compressor engages. That said, the OP symptoms sound off - can't tell if the description or the car is what's off though. Video could help.
#5 |
2018 Brz issues?
After an ECU reset the throttle response is super inconsistent for at lest 200miles (no that isn’t an exaggeration) while the ECU is in its learning phase. Sometimes the slightest throttle input leads to a big surge and other times it’s as if it’s ignoring your input completely. Makes it very difficult to drive smooth. I’ve never driven one off the showroom floor but I’ve always wondered how they could ever sell them brand new if they haven’t completed the learning phase yet.
Everyone complains about the clutch feel but every car has a slightly different feel to the clutch. The clutch is at least mechanical and therefore consistent so you adapt to it after 10 miles or so. It’s the erratic throttle response that messes with me the most on this car. Trust me, 200 miles in and it will settle down and driving smooth will not be an issue. The tranny noise is a combination of virtually no sound deadening and the boxer engine sending pulses into the gear box. Boxers are vary rough at low RPMs due to their firing order which causes lots of chatter in the gear box. Throw a light flywheel on the car and it gets much worse. If you’re bothered by it then try to avoid anything under 2k unless you are very light on the throttle. Nothing is wrong with the engine/tranny though. |
| The Following User Says Thank You to ermax For This Useful Post: | humfrz (10-09-2018) |
#6 |
Drives: '18 WRB BRZ Limited w/ PP
I think 3) is normal. My 2018 Limited and my friend's 2017 Limited both do that. As did my old 2006 NC Miata actually. On the Miata forums, some people were actually speculating that the noise is from the Limited Slip Diff. I am not sure what it is, but I don't worry about it.
#7 | |
Drives: Boosted
#8 | |
Drives: Boosted
#9 | |
Drives: Boosted
#10 |
No it’s just a spring that makes the clutch pedal a little softer and also helps it return to the very top. Most modern manuals have them these days. A lot of guys remove it to make the pedal stiffer. The spring has a pivot point where it goes from pushing the pedal down to pushing the pedal up. It’s this transition that makes it hard to feel the bite point. So a lot of guys remove the spring. I’ve run my car both ways and really don’t have a problem driving with or without the spring. Rev hang is a software thing that lets the revs drop just enough for the next gear and then hang there for a sec. Thank god the BRZ doesn’t have this aid. |
#11 | |
Drives: Boosted
I see, maybe I've been too used an nd miata that shifting in this brz feels weird and sluggish in comparison. Probably too used to having that super light weight fly wheel so it feels that the brz has rev hang. |
#12 | |
OEM is 21lbs but aftermarket tunes can have a lot of influence on how fast the revs drop. Also the revs drop crazy slow at 2k and bellow and I think that has to do with idle control. It’s really annoying. |
| The Following User Says Thank You to ermax For This Useful Post: | incutebus (10-09-2018) |
#13 | |
The Fail Boat
Drives: CWP S.B.
I think you should find another ppl with the 86 & have them drive your car so they can just tell you if there is anything wrong. Everything you mention seem to be one of those things that ppl do complain about when they don't know what they are getting into. |
#14 | |
Drives: Boosted
| Android Auto Issues 2018 BRZ starlink infotainment system | iff2mastamatt | Electronics | Audio | NAV | Infotainment | 19 | 10-03-2018 03:38 AM |
| 2018 BRZ tap to turn | norcalpb | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 07-13-2018 09:26 PM |
| AVO Turbo Kit issues in 2018 | brianzlive | Forced Induction | 8 | 04-08-2018 11:37 PM |
| 2018 BRZ STI | raven1231 | FR-S / BRZ vs.... | 19 | 06-26-2017 12:39 PM |
| Where are the 2018's ??? | ~el~jefe~ | FR-S / BRZ vs.... | 41 | 05-24-2017 01:03 PM |
