Old 10-06-2018, 02:05 PM   #15
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
For FI I always thought backpressure wasn’t an issue because there is FI, so larger the better was the idea. Size restriction came down to fitment limitations, budget limitations, and desired sound.
Old 10-06-2018, 10:32 PM   #16
Kolwala
Drives: 14 Argento FR-S
There is also this exhaust by counterspace garage and mxp:
https://www.counterspacegarage.com/c...tition-exhaust
It's a 2.75 inch exhaust that is supposedly quiet.
Kolwala is offline   Reply With Quote
Old 10-06-2018, 11:13 PM   #17
FRS Justin
Drives: 2013 Asphalt FRS
2.5 is good at that level no worries in making that goal.
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
Old 10-06-2018, 11:39 PM   #18
86TOYO2k17
Drives: 2017 toyota 86
I’ve got the CSG mxp touring86
Pretty quiet considering aftermarket header and no cats. Good crisp deep tone.
I had same setup but with stock exhaust and it just sounded terrible. The CSG exhaust was same volume maybe even a little quieter but really cleaned up and deepened the tone.
The Following User Says Thank You to 86TOYO2k17 For This Useful Post:
CSG Mike (10-08-2018)
Old 10-08-2018, 02:17 PM   #19
tyler_win_photo
tyler_win_photo's Avatar
Drives: 2014 Scion FRS (Asphalt)
Originally Posted by RedRez86 View Post
Okay I will not be doing any internals at all. Only injectors and fuel pump would be only other things I might do to add some HP. I Definitely don’t want to mess with internals. Well I don’t want it “quiet” I want it to roar and growl just not be stoned out or so loud I can’t hear myself think inside the care and waking neighbors lol. Maybe Perrin 2.5 catless?
Injectors and fuel pump are unnecessary if you're only planning on using pump gas. They will not net you any more power. The limitation will be the high compression of the engine combined with boost causing knock... which is why many people lower compression when building the bottom end of the fa20 or go with e85 which has a higher knock resistance than 93 or 92 octane.
tyler_win_photo is offline   Reply With Quote
Old 10-08-2018, 04:11 PM   #20
RedRez86
RedRez86's Avatar
Drives: Red Scion Frs
So you’re saying if I get better injectors it won’t give me any extra HP? Couldn’t a tune help with the knock and maximize the HP gains after injectors are put it in?
RedRez86 is offline   Reply With Quote
Old 10-08-2018, 04:16 PM   #21
CSG Mike
CSG Mike's Avatar
It will not for your proposed setup.
RedRez86 (10-08-2018)
Old 10-08-2018, 04:42 PM   #22
tomm.brz
Drives: brz 2017 hksv2
if you spend time on the tune, you could even use totally stock injector and stock pump (on petrol only of course) with a supercharger hks v2 with 44mm restrictor instead of the 39mm stock... talking about more than 300bhp so listen to CSG Mike, they are useless
Old 10-08-2018, 04:44 PM   #23
RedRez86
RedRez86's Avatar
I was actually looking into the HKS v3 is that power still possible with that? I’m listening bud I’m just asking questions lol. Knowledge is power! Thanks btw fellas. What do you mean by the 44 mm restrictive, Where would I get that. Is that the supercharger Pulley?
Old 10-08-2018, 06:53 PM   #24
tomm.brz
a bit OT, anyway the hks v3 has no restrictor but bigger pulley, no problem using stock fuel system at all
if you put the v2 pulley you could pass 300bhp and you (or the tuner) should tune very good the PI/DI ratio and pay attention to the opening times of the injections and to how close is the end of DI injection to the spark
Old 10-08-2018, 11:48 PM   #25
RedRez86
RedRez86's Avatar
Okay so would you recommend EcuTek to do this accurately or OFT?
Old 10-09-2018, 03:04 AM   #26
tomm.brz
i like to use a Wideband aftermarket sensor to tune FI sothat s why I prefer ecutek
Old 10-09-2018, 03:46 AM   #27
RedRez86
RedRez86's Avatar
EcuTek got it. Wide band sensor as in air fuel ratio measurer? Sorry I know about cars but not all the details.
Old 10-09-2018, 03:50 AM   #28
tomm.brz
with racerom v10 you could use a wideband in the open loop and it autocorrects afr based on it, but i meant that you can connect the wideband using a custom map so that you always log the wideband too
i m not aware of a method of this with OFT so with OFT the best would be a dyno tune so that you have also a wideband connected to your car
the stock lambda is pretty inaccurate when you go under 11.5-12
Forced Induction OMJM Want-To-Buy Requests 1 12-01-2015 10:21 PM
Forced Induction HELP! surfuxalot Forced Induction 22 06-20-2015 01:56 PM
3" Exhaust Options for Forced Induction Chad86 Forced Induction 23 04-24-2015 12:45 PM
Forced induction for ATs? Lokutus Forced Induction 10 02-26-2013 04:42 PM
6AT (+) Forced Induction RYU Forced Induction 18 09-10-2012 12:14 AM
