#4775 |
#4776 |
#4777 |
Drives: 2017_86 2016_frs 2007_335i
how someone can help me getting faster on the track my question is about trail braking i think i did trail braking in my video can someone point out am i did the trail braking in the video or not here is video link [ame]http://www.youtube.com/watch?v=nZVoOEvoeLk&t=411s[/ame] by the way i will take anything for me to be faster thx
YouTube Video:http://www.youtube.com/channel/UCBXFeelPFI8XzGese8Eug-g
ins:zayliu.jiayu Build Journal:http://www.ft86club.com/forums/showthread.php?t=136068 "if in doubt flat out" |
#4778 |
You're not often trail braking, as your inputs are very punctuated, but there are some moments where you are definitely using the brakes to help balance and rotate the car on entry.
Have you considered hiring yourself a driving coach? You have a pretty good level of confidence in your car, and you'll pick up time by cleaning up the fundamentals and focusing on clean, rather than fast. The electronics are definitely interfering with your driving here and there. |
#4779 |
Drives: White BRZ
I'm guessing 3 to 5 per season for 10-15 track days after the car is set up correctly. That would be tires, brake pads, rotors and fluids. I would like to go the e46 route. Am I in the ballpark? Do you have other options that might work better? Thanks again for sharing your experience.
#4780 |
Drives: FR-S Turbo
What hot pressures/temps do Hankook RS4 tires like to see?
Here is the pressure and (outside/middle/inside) tire temp data from my last session on the (predominantly right turn) track layout. All data from Joe's Racing gauges: Run 5/ 1:15.82 fastest lap / 1:14.30 RaceChrono optimal LF 154/156/160 39.6 psi RF 130/140/151 39.2 psi RR 124/139/142 34.7 psi LR 132/139/140 34.7 psi Temps measured in the order above, then pressures done in same order. Measured right off the track after a 1/4 mile cool down, tops. 1) Will running lower front "hot pressures" increase front end grip? 2) If so, will this also translate to more initial bite on turn in? |
#4781 | |
With equal tires, a 86 will cost you less than half the running cost of a E46. |
#4782 | |
More likely, your setup/driving is front loaded. |
| The Following User Says Thank You to CSG Mike For This Useful Post: | Turbo (10-06-2018) |
#4783 |
Drives: FR-S Turbo
I'm not sure I know what you mean by this, Mike. Could you expand, please? Are you referring to the overall handling balance of the car? Or maybe 'rake' of the car? I believe the rear fender-lip-to-ground distance is set 1/4" higher then the front (with me in the cockpit). Should I maintain a level ride height? And if so would you advise lowering the rear or raising the front to get there? I believe I'm -26mm from stock all around with HKS SP IV coils. Also, I have Hotchkis bars on the car front & rear. Front on the softest setting, rear on the second softest. |
#4784 | |
thx for point out!! currently waiting for the racing seating with 6 points harness get install this video was my first track day with re71r 245 40 17 was using stock tire for last 4 track day so i need work on trail braking for now right ? and disable the traction control fully by hold the left button right ? or should i do a pedal dance thing ? i dont know if the track has the driving coach for this track but they do have a $1000 per one track day with instructor should i try that ? and what kind of question should i go with if i take that deal i get group which we rent a track for one day and share the price 500 per day with 5-6 section with 20 min per section
#4785 | |
| The Following User Says Thank You to CSG Mike For This Useful Post: | Turbo (10-08-2018) |
#4786 | |
You should be using the pedal dance. First, explore the limits in a safe area. If you are renting an entire venue for the whole day, I can accomplish a LOT with you in one day. I can go a full 8 hours of seat time, if you can. |
#4787 |
Undisputed El Presidente
Drives: Zenki 37J ZN6
Figure here is the most likely place anyone has done it.
Looking to refresh my brakes and want to replace the guide pins and bolts. Already have seals. Has anyone found any solid OEM alternatives for the slide pins? Or do I just bite the bullet from Subaru? |
#4788 | |
You could do what I do, and just buy junkyard calipers. It's very easy to see if a caliper has ever gotten hot by inspecting the outer dust boot and caliper coloration. Most have never gotten hot, and are in great shape for very cheap. I replace my calipers regularly due to the extreme heat they see. |
| The Following User Says Thank You to CSG Mike For This Useful Post: | finch1750 (10-26-2018) |
| Simple question, hard to find answer... | Mango22 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 05-16-2013 07:23 PM |
| Silly question about protecting track rims | sw20kosh | Tracking / Autocross / HPDE / Drifting | 16 | 04-25-2013 01:34 PM |
| Asking the question that I already know the answer to. Are the engines the same? | Bigmaxy | Engine, Exhaust, Transmission | 10 | 01-19-2013 08:47 PM |
| Random dog-related question for those who have their BRZ | GMU-BRZ | BRZ First-Gen (2012+) — General Topics | 11 | 05-31-2012 08:48 AM |
| Got my answer - BRZ comes with HID headlights as STD | Z_Rocks | BRZ First-Gen (2012+) — General Topics | 20 | 01-10-2012 10:54 AM |
