#19671 |
Drives: 2015 Scion FR-S
Yesterday I helped my buddy replace the sparkplugs in his 2015 WRX. This wasn't exactly my FR-S, but it's close enough since it also has the FA20 with a few minor differences. This goofball was still running the original plugs at 95,000 miles. I guess he didn't get the memo that they're supposed to be replaced every 60k...
I managed to do it without jacking up the engine and only got one bent fingernail and two bloody knuckles. To be honest the FA20 in the WRX sits up a bit higher than the FA20 in the FR-S/BRZ/86 (probably due to the AWD system), so that's probably why lifting the engine wasn't required. It was good practice for when I have to replace my sparkplugs in about 9,500 miles. |
| The Following User Says Thank You to Face_Plant For This Useful Post: | humfrz (09-30-2018) |
#19672 |
Drives: GTS 86 auto
While you are at it, shield your battery too.
GTS86 Auto (Australia)
#19673 |
Drives: GTS 86 auto
It does look classier. Makes you wonder why it was in 2 pieces originally.
#19674 | |
Drives: GTS 86 auto
#19675 | |
Drives: GTS 86 auto
#19676 | |
Access panels or holes would probably comprise the rigidity of the front of the car. I haven't looked at my engine in a while, but from what I remember the cylinder heads are right in line with the frame rails, whereas on my friend's WRX the engine sits up an inch or two higher, making the sparkplugs easier to access. I know it's possible to change them without lifting the engine, but unbolting the engine mounts is as simple as removing two nuts, then you're free to lift the engine a few inches for easier access. This is probably the route I'll take for less cursing and fewer bloody knuckles. |
#19677 |
Country Boy 4 Life
I added a drop light with 6 foot cord that is fused and has a switch. It is a small strip of LEDs that I put in a piece of 1/2 pex tube. I can look under hood, under the car, and waive it around if I need help. (let's hope I don't)
And, NO its not on while I'm driving.
I LIKE TIRES! |
#19678 | |
But could it be?
#19679 |
Country Boy 4 Life
Sure, I used a cord like pictured below. So, you would have to pop the hood, turn the light on, shut the hood, and then drive around. The light will stay on till you spin the switch again. Shutting the car off won't shut the light off.
I thought about wiring it to a pressure switch, so it would turn on if the hood opened. But flipping the switch is easy, so I wired it with a standard switch instead.
I LIKE TIRES! |
#19680 |
Hypnocratic Missionary
Visited the Toyota Dealership to program my OEM replacement key....$250ish for key & $110 service charge...
Found a second set of rims on Craigslist local...Picked up these Kosei K1-TS wheels $250 (CHEAP) ![]() Went to Discount Tire for Conti's...mounted them on said Kosei wheels...while busting one center cap $600+![]() Found the last two refurbished Kosei Center caps on the interwebs for $18 each.
#19681 | |
Drives: C5, GT-86, '24 Colorado TrailBoss
good find id love to find a set of those. Cheap, Light |
#19682 |
Drives: FR-S 10 Series
Dropped 10 Series off with Cadillac dealership bodyshop to fix a ding (PDR) and a scratch from some Hyundai owner suddenly losing a part from his POS on the Long Island Expressway.
#19683 | |
Well, Leonardo, that's nice - but what do you use it for - ![]() humfrz |
#19684 |
Drives: Raven FRS
Canards
| The Following User Says Thank You to _kongzilla_ For This Useful Post: | LeonardoDaVinny (10-14-2018) |
| Tags |
| :popcorn:, :popcorn: funny tags, nsfc, rice rice baby |
| Saw My First FR-S Today | Marrk | Scion FR-S / Toyota 86 GT86 General Forum | 26 | 05-15-2013 12:40 PM |
| Got My Car Today!!!!! First 86!! #81 | Juanito08 | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 05-22-2012 04:54 PM |
| If my FRS was here already, today I would... | bestwheelbase | Scion FR-S / Toyota 86 GT86 General Forum | 101 | 05-12-2012 06:20 PM |
| Sat in a FRS today!! | Ladnerd | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 04-30-2012 01:48 PM |
| Got my VIN today... | Enemies | BRZ First-Gen (2012+) — General Topics | 63 | 04-12-2012 10:19 PM |
