Old 09-24-2018, 06:06 PM   #4733
GrandSport
GrandSport's Avatar
Drives: 13 Viper; 14 BRZ; 90 Miata; 18 AMG
It isn't enough camber, your Corvette double wishbone suspension needs much less static camber than the MacPherson Strut suspension on the 86. I've run -4 and seen/heard others with more for street tires.
Normally, I'd agree but his temps show the outside being very cold (or at least cold, depending on ambient). It looks like he's running too much. Am I reading that right? Inside temps are hot and outside are cold?
GrandSport is offline   Reply With Quote
Old 09-24-2018, 06:23 PM   #4734
tony_r
tony_r's Avatar
Drives: '15 STX
I can't tell much from the tire temps he posted, for a few reasons. When were the temps taken? Straight off a hot lap or after a cooldown? Directly after getting to pits or was there time in between? How were the temps checked - with a probe or surface IR sensor?
Based on what is here, I can make general assumptions. Seems to me like this is a CW, primarily right hand turn course, so the LF is taking a lot of the load and the inside tires are cooling down. Either that or the final corner before coming off the track is a right hander.
Session 1 has no reasonable data to pull from since it's apparent the car wasn't driven as hard as the later sessions. Later sessions were better. Yes, there is a general trend that the outer edges are not as hot as the rest. Answer the above then we can come to a conclusion about camber, pressures, etc.
I would expect even more heat from the tires with a 250whp 86 on 245s. I would expect maybe 160-180 or so. I believe the RS4 optimal range is around 170? I know the Rival S 1.5 is 160.
tony_r is offline   Reply With Quote
Old 09-24-2018, 06:40 PM   #4735
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Tony beat me to it.
I don't really trust tire temps any more, I think you have to adjust to the outer limit, actually find what 'too much' is and then dial back otherwise you're just hoping you're in the ballpark. I've done it a few times now "pyro says we're good, no more camber" *try more camber* "oh shit look at all this grip!"
Tires do not respond linearly, that's true on many many levels.
His tire temps are inconsistent, 20 degrees hotter on one edge on one session, then 15 degrees colder on a different session, I'm not sure what's what.
I think tire pressure is another indicator that the front tire is not being used effectively, and again here's another spot where a probe pyrometer has misled me, I've swung +/-5 psi into the same set of tires, while 37 psi looked great on the probe, 32 psi was faster and felt better on that cold day, I've gone down to 27 psi on that same tire and it performed way better than 37.
Tellingly I don't think I know anybody who has the freedom to set the suspension and alignment as they please on an 86 and runs more than 2 psi different between front and rear tires.
ineedyourdiddly
Old 09-24-2018, 08:25 PM   #4736
CSG Mike
CSG Mike's Avatar
Originally Posted by Turbo View Post
I'm fairly new to this, so I would say I really don't know. But after saying that, the gears in my head are turning.
Would video help assess this? This video is of my 2 fastest laps (1:15.82 & 1:15.9) from that day, both occurring during run #5. I would also welcome constructive criticism and tips to pick up time:
The RaceChrono laps times during that day said I was very consistent in each session, which is a plus. Watching my driving, though, I do believe I need to get smoother, and be more aggressive on the brakes.
Top speed on the back straight was 172km/hr or about 108MPH.
For reference, a former National Formula Ford champion laps this same configuration in a Hayabusa-powered Radical SR3 in 1min 3 seconds.
Your car has a pretty good amount of static push built into the setup. You also don't trail brake into corners, and tend to either be fully off throttle, or a minimal amount of maintenance throttle through the corners.
You can alter your driving style to match the car better, or change the setup to rotate more.
The only instance of rotation I saw was power-oversteer, which indicates to me a setup problem first, followed by a relative hesitance to get on throttle.
CSG Mike is online now   Reply With Quote
Old 09-24-2018, 10:32 PM   #4737
Turbo
Drives: FR-S Turbo
where are you feeling understeer? Can you give us a time?
0:37;
1:14;
1:18;
1:53;
1:55
ya, I saw a hint of oversteer if anything coming out of some turns.
When I'm into the throttle a bit early or a bit aggressively, yes.
Yes, you are reading that correct. My inside edges are always equal to or (in almost all cases) greater then the outside temps.
Sorry, I should have given more complete background:
-> Temps taken right after leaving the track. Maybe 400 meter (1300 feet) cool down?;
-> Readings taken using a Joe's Racing tire pyrometer w/probe;
-> Temps always taken in the order: LF, RF, RR, LR THEN pressures measured in the same order.
According to the Dynapack it makes 250 WHP @ 6750 RPM, although I was shifting at 6500 all day.
I'm running 255/40R17's (not 245's) on 17lb 17x9 rims.
Correct - we were running clockwise. 2nd last corner is the long right-hander at end of the straightaway, then the dog-leg left then we pit.
The start/finish line is between the dogleg and pit entrance - I normally push right until I cross the finish line, then brake hard and dive into the pits. We were running the "Technical" layout in the top left. Map isn't entirely accurate. It looks like 1 long sweeping turn to go onto the back straight - in reality it is 2 corners and the pavement between them is a bit rough.
Turbo is offline   Reply With Quote
Old 09-24-2018, 11:16 PM   #4738
Turbo
Drives: FR-S Turbo
First- thank you ALL so much for your help and input. I really do appreciate it.
Other than the small pressure adjustment after session 3, I was running the EXACT same cold pressures I did the last 3 times I was at this track. On those days, I was seeing 34-35 psi hot all around - but running in the 1:19's/1:20's. Never saw anything near 39 psi before. But I also haven't been this fast before. I will say I was cautious getting up to speed as I was driving the car after the pedal dance on ALL runs, so no driver aids at all.
Given this car doesn't really get driven on the street, I had just left the pressures where they are when I leave the track. I figured this would (likely) give me the same hot temps next outing.
This was the first time I've ever taken tire temps as I just got the meter. I adjusted the probe depth properly too.
One thing that really struck me was how high my (hot) front pressures were. I had read on this forum that the RS3/4 like to run ~34psi hot and I was pushing 40psi! I didn't drop my pressures because the tire temps I was seeing were fairly even across the left front.
Should I try running lower hot pressures on the front? If that gives the front end more bite going into corners, it may fix what I am thinking is 'entry understeer'.
And is there a target tire temp to aim for with RS4's?
I could also take some roll-bar out of the rear (It has 4 settings and I'm on the second softest). Doing so would probably increase the outside rear temps as the rear end rolls more. But it would also likely move the car towards understeer as it rolls more and picks up grip.
Old 09-24-2018, 11:54 PM   #4739
Turbo
Drives: FR-S Turbo
I KNOW you are only supposed to adjust one thing at a time, to properly quantify the changes.
But after carefully reading all of your replies, and thinking the feedback I want to take a stab at the big picture answer-
Leave camber where it is for now;
Lower my (hot) pressures in the front to match the rear approx 34-35 psi all around;
Move the rear bar to the softest setting;
Trail brake into corners to help rotate the car which will now have more rear end grip;
Get on the power earlier -while in the corner or earlier at exit- applying lock as needed as I wind out of the corner.
A lot easier to write about then actually do -but still have to ask- Am I getting close?
Old 09-25-2018, 01:40 AM   #4740
GrandSport
GrandSport's Avatar
If anything I think you were getting on the gas early, not late, because you weren't trail braking. Remember, when you get on the gas, you're going to push the car wider. This is especially true with closed rear diff. How much will vary from car to car, but on throttle will push the car wide (understeer). Unless you light up the rear tires or something, you're not bringing the ass end around with gas. You're doing it with brakes.
I really don't see much understeer where you're saying you have it, but it's hard to tell from video if it's subtle. It looks well sorted if anything.
Old 09-25-2018, 02:22 AM   #4741
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
What gas cans do you all recommend to carry e85 to the track?
Any work better then the rest? Or just get whats cheap-ish?
Old 09-25-2018, 07:13 AM   #4742
cruizin01
cruizin01's Avatar
Drives: 13' BRZ
I have 3 VP cans i got from Amazon. Remember you need at least 1 nozzle.
Sent from my SM-G930V using Tapatalk
cruizin01 is offline   Reply With Quote
Old 09-25-2018, 01:07 PM   #4743
tony_r
tony_r's Avatar
Drives: '15 STX
Be careful with trail braking. Done properly it can help with entry rotation. Done incorrectly it will understeer. This car is not mid-engine, so the rear wont rotate that much on entry without a bit of rear rebound. Remember that the front tires have only so much available grip for braking and turning.
On tire temp reading, think of the tire mold and how it deals with heat. The inner and outer blocks of the RS4 are large and retain more heat, the middle block is small and dissipates heat faster. I'm willing to bet that the middle block was actually hotter than what was measured on the track so lowering front and maybe rear pressures does make sense.
As far as operating range for the RS4, I remember something like 160-180(?) but I don't totally remember. Would have to talk to a Hankook tire engineer since they don't publish.
I would mess with the pressures before anything, I think.
Old 09-25-2018, 03:03 PM   #4744
kch
Senior Misanthrope
kch's Avatar
Second on the VP cans. Doesn't matter what color, really, even though some say not to use for fuel. I ordered a 4-pack of the yellow ones off amazon.
Old 09-27-2018, 05:05 PM   #4745
mistople
mistople's Avatar
Drives: 2017 BRZ (Sold), 2023 GR86
Are you finding e85 up here?
mistople is offline   Reply With Quote
Old 09-27-2018, 05:25 PM   #4746
kch
Senior Misanthrope
kch's Avatar
Nope, I gave up on E85 up here. Unplugged my flex sensor and everything. Back in TX I had a trailer so I could bring along 6 jugs, but the trailer stayed home when I moved up here.
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 06:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 12:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 07:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) — General Topics 11 05-31-2012 07:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) — General Topics 20 01-10-2012 09:54 AM
