Old 09-13-2018, 03:19 PM   #1261
steverife
Drives: 2016 Scion FRS
Originally Posted by chkltcow View Post
Did you not hear me yell at you about binding? I saw you guys under the car and it looked like someone was pulling REALLY hard to get the endlink out of the bar. Been there, done that... it's because everything was clamped down to the point that it was all bound. And that made the car evil.
Loaded or unloaded?
steverife is offline   Reply With Quote
Old 09-14-2018, 05:24 AM   #1262
chkltcow
Drives: 2013 FRS White w/ cone marks
Originally Posted by steverife View Post
Loaded or unloaded?
Both. Like... got the endlinks out and tried to grab the bar and rotate it a bit and it didn't move at all. Loosened the bolts on the brackets by about 1/4 turn and the bar moves like it should.
chkltcow is offline   Reply With Quote
Old 09-14-2018, 07:24 AM   #1263
M0nk3y
Just from my experience, the Whiteline bar I had prior on the car, the bushings were too large and caused the bar to bind when tightened down. The proper thing to do would be to shave the bushing so it could secure correctly.
I know it's not "spec" but it's a pretty common occurrence on how to make a bar bind
Kyle H. - #89 STX
Old 09-14-2018, 03:02 PM   #1264
Imp
Bring out your dead
Drives: '14 BRZ (SSC), '00 S2000
The bar was moving, don't get me wrong. But it was probably tighter than it should have been. We did the same 1/4 turn and it was a little more free.
K. Casey | NER SCCA | SSC - '14BRZ For Sale
Imp is offline   Reply With Quote
Old 09-24-2018, 11:32 AM   #1265
Open Loop
2013 FR-S Whiteout / SSC
Anyone want to speculate on what the SSC pax will be next year? .795? .785?
Open Loop is offline   Reply With Quote
Old 09-24-2018, 12:04 PM   #1266
steverife
I think it will likely be between ES and DS.
I think on most courses, I would be faster in an ES car.
Also, if PAX isn't fixed, I'm pretty much out. Locals are 0 fun.
Old 09-24-2018, 12:13 PM   #1267
M0nk3y
Just saying, Adam didn’t do you guys any favors with helping you out on PAX.
And while Nats isn’t totally considered, I’d think that has to be in the back of Ricks mind.
That and the fact locally, some people have been doing decent enough, might impact you guys negatively
Kyle H. - #89 STX
Old 09-24-2018, 12:28 PM   #1268
steverife
Bartek still had a faster scratch in ES, in conditions that were debatably comparable.
I do think it is going to be a tough car to PAX. Keep the car in its powerband and have an open course that doesn't force blended inputs and it is probably a second faster than ES. ...but most of the time, ES seems to be right there, if not faster.
edit: Comparing west times, Scroggs ran a 62.4, Bartek ran a 62.2, and Adam ran a 62.6. I don't think there is really anything out there than doesn't put SSC in that neighborhood unless Rick thinks the class is collectively terrible at our 2 adjustments..... or we get a new tire.
Old 09-25-2018, 04:15 AM   #1269
Open Loop
I have a question for those of you that track your SSC car on the Falkens. How much lower are you setting cold pressures for a 20 minute session vs. autocross pressures? Assuming 65 - 75 degree dry weather.
Old 09-25-2018, 10:52 AM   #1270
Imp
Bring out your dead
Not really. Many of the classes were effected by weather this year at Nats (and he usus multiple regions to calculate), so SSC at Nats appears better on PAX than it really was - and was one of only a handful of classes that ran 2 days in the dry.
--kC
Old 09-25-2018, 10:59 AM   #1271
Imp
Bring out your dead
Scroggs wasn't fastest on day 2. Finch had a 62.304. 0.37 is quite a bit of time. I would bet that SSC is softer than both ES and DS.
--kC
Old 09-25-2018, 01:09 PM   #1272
steverife
Oops.
Also fun fact: At our local Sunday, I would have had to have the top door slammer raw time by 7 tenths to win my PAX class.
Old 09-25-2018, 03:45 PM   #1273
14stu
14stu's Avatar
Drives: 2014 Subaru BRZ
I ran Falkens on an STX BRZ at the track and they were pretty happy with a wide range of pressures. I kept them at around 35psi hot and would typically see about 4-6psi gain over a 20min session. I'd start them off in the 26-30psi range cold and bleed between session as necessary (I like my fronts 1-2psi higher than the rears with my setup, so I'd typically start with 27-29psi front and 26-28psi rear).
This was for 255/40-17's on 17x9 wheels, but I would bet the same works for your spec wheel and tire sizes.
14stu is offline   Reply With Quote
The Following User Says Thank You to 14stu For This Useful Post:
Open Loop (09-25-2018)
Old 01-07-2019, 10:21 PM   #1274
imhereforthecar
Drives: FRS
Thoughts on 2019 PAX? .806 to .801 while pretty much everyone else got bumped up. Better....
imhereforthecar is offline   Reply With Quote
Upgrading brakes on the lower spec GT86 (the standard spec outside of US market) OnionTou Suspension | Chassis | Brakes -- Sponsored by 949 Racing 55 07-01-2016 01:36 AM
what's the difference between twin screw, centrifugal, single turbo and twin turbo? warplane95 Forced Induction 86 04-17-2014 02:36 PM
my twin RWDGUY Mid-Atlantic 2 04-08-2013 09:23 PM
JDM Spec-C V9 Twin Scroll VF36 complete Nico TURBO Engine, Exhaust, Bolt-Ons 0 12-05-2012 11:20 AM
