Old 09-22-2018, 03:40 PM   #1
ilovetheabel
Drives: 2016 Subaru Brz Limited
Best Abs Code reader
What is the best Abs Code reader that would work on a 2016 brz, not too expensive tho. Been trying to diagnose an abs light that doesn't seem to turn off.
ilovetheabel is offline   Reply With Quote
Old 09-22-2018, 04:24 PM   #2
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Have you done anything to the car?
Old 09-22-2018, 09:23 PM   #3
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
You mean an just an engine code reader? If you want the best that's going to run you over $200.
If you just want to know what code it is you can buy one at autopart store or amazon for $50-60.
Old 09-23-2018, 11:35 AM   #4
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
you can get ones on amazon even cheaper if you just want to read codes. i think mine was like 18$
Old 09-23-2018, 12:47 PM   #5
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Regular obd code readers do not always pull ABS and other diagnostic codes. They are not the same as a check engine light.
Old 09-23-2018, 03:36 PM   #6
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Breadman and Mr.ac you guys kinda misunderstood the question as finch1750 mentioned. Most obd2 code readers DO NOT read ABS/SRS codes. Unless it's something like a laptop loaded with techstream which reads everything.
Also important question ilovetheabel, do you even have the technical ability to fix an abs issue if you do read the code? Some of the codes can be caused by either a really simple wheel sensor fix or a hard, abs actuator replacement.
Also to get those capabilities you must spend a minimum of $100, but in return you get a OBD2 reader that not only reads CELs but also ABS and SRS codes:
https://www.amazon.com/gp/product/B0...SRDMB5RO&psc=1
I've been eyeing that ML619 one for awhile personally.
Anyone in southern Orange County with a code reader? bdanisi Southern California 3 08-08-2015 11:34 AM
Code reader recommendations? FLYFISHR Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 08-01-2014 10:01 AM
Obd ii reader Jhon19lopez Electronics | Audio | NAV | Infotainment 1 06-03-2013 11:12 AM
is CarMD a good code reader? chenshuo Engine, Exhaust, Transmission 3 04-04-2013 10:32 AM
Check engine light code reader FRSCoupe Engine, Exhaust, Transmission 14 06-13-2012 05:06 PM
