Drives: 1993 RX7, 2004 VW R32
2013 BRZ Consumer Reports problem areas
I'm doing research on the BRZ/FR-S and am really interested in a 2013 BRZ for sale nearby but Consumer Reports lists body integrity and the fuel system as poor for 2013 but for 2014 the fuel system has their highest rating and body integrity has improved but still not the best(later years get the highest rating). Was there specific issues with the 2013 fuel system and body integrity that can be easily/cheaply fixed(I recently learned that ceramic coating a car is a thing) or are these issues being overblown by CR?
Thanks for all the responses |
#2 |
6/22/12-2/6/24
Few people had issues with the fuel system and had to get it replaced. There was a bulletin to get it optionally replaced (different part number) .. pretty much only if you had an issue in the vehicle. I don't think most people had the issue though. And it costed a pretty penny.
I don't know what body integrity issues CR is talking about. There was a plug that was forgotten that led to potential water accumulation but that was taken care of w/n the first month of release. All in all, I think it's overblown. If you can, pick a "newer" '13 model over the ones that were earlier in product. If possible '14 or later is ideal. But there really weren't any major issues with the 1st gen.
#3 | |
The fuel issue was the noisy fuel pump commonly referred to as crickets. It was (is) annoying but not really a problem. This link has all the Service Bulletins for the most common issue. Don't let it scare you since not all cars had all or even any of the list. If you can get the car's VIN number you can look and see what would apply and check if it was done http://www.ft86club.com/forums/showthread.php?t=21868
| The Following 3 Users Say Thank You to Tcoat For This Useful Post: |
#4 | |
6/22/12-2/6/24
Leaky tail lights were pretty common too .. but its mostly been light fogging up for most people ~
| The Following User Says Thank You to Bonburner For This Useful Post: | Tcoat (09-20-2018) |
#5 | |
Oh and the crickets was and still is an issue for many, many people but the latest updated pump seems to work about half the time. Not really worth the trouble and 13s are out of warranty anyway.
#6 |
6/22/12-2/6/24
I also recall some complaints about the occasional window switch control for the passenger window from the driver's side sometimes not working. The fully automatic scroll wouldn't work even after the pulling the switch up all the way, but a second attempt usually made it go up all the way pretty consistently.
#7 | |
That was a seal issue and a window control issue, it would be exacerbated in freezing weather and required the window control reset trick. The TSB involved a newer seal design as well as replacing effected window parts
#8 |
I have droopy bumper syndrome. Whatever...
#9 | |
humfrz |
#10 |
Drives: 2017 BRZ
I suspect the direct injector seal problem was the main "fuel system" problem. Fixed with an updated tune. It makes me vaguely uncomfortable recommending a 13, but probably shouldn't.
#11 |
And it worked well. I never had an issue again after I had the TSB done.
| The Following User Says Thank You to Tcoat For This Useful Post: | FRSBRZGT86FAN (09-21-2018) |
#12 | |
Not sure if it was due to this thread but suddenly the fender issue thread reappears after being dormant for 4 years! https://www.ft86club.com/forums/show...72#post3135772
| The Following User Says Thank You to Tcoat For This Useful Post: | Bonburner (09-21-2018) |
#13 | |
Thanks for your help, I really appreciate it. |
#14 | |
At this point in time I would guess that any 13s either didn't have the issues in the TSBs or the work has been done already.
| Consumer Reports | White64Goat | Other Vehicles & General Automotive Discussions | 0 | 09-28-2013 08:04 PM |
| Consumer Reports | TRD-X | Scion FR-S / Toyota 86 GT86 General Forum | 2 | 05-06-2013 05:55 PM |
| Consumer Reports 2013 | Dorb | BRZ First-Gen (2012+) — General Topics | 0 | 02-27-2013 05:07 PM |
| Consumer Reports Top Picks 2013 - Sports cars | motofan | Scion FR-S / Toyota 86 GT86 General Forum | 6 | 02-27-2013 11:13 AM |
| 2013 Subaru BRZ first look from Consumer Reports | Sonex51 | BRZ First-Gen (2012+) — General Topics | 8 | 07-20-2012 06:45 AM |
