Old 09-18-2018, 07:18 PM   #113
StraightOuttaCanadaEh
Wes
haha loving the obsession!
Instagram: @gt86ws
The Following User Says Thank You to StraightOuttaCanadaEh For This Useful Post:
SuperTom (09-18-2018)
Old 09-19-2018, 06:06 PM   #114
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
Another round of weight reduction today. Since I have a one piece drive shaft Ive been wanting to remove the stock mount underneath looked like a healthy chunk of metal.
This is the Culprit
Got a few of these to help
This job was a pain in the ass. Had to remove center of exhaust and driveshaft to begin with. My drill was too big to get into the upper corners, had to use a dremel to grind down the hard to reach welds.
All that work its only 1.75lbs
Worn out and putting the car back together something hit me. The gas tank shield really only covers the middle as the sides are exposed. Anything that would fly up would hit my Borla muffler (in front of tank) or the drive shaft so that sucker is good as gone! Just put the sides of the tank under floor jacks and removed the straps holding the shield and the tank to the car.
Now today was worth it 3.75lbs!
Total loss Today 5.5lbs for Free!
New weight 2466.25 LBs
SuperTom is offline   Reply With Quote
Old 09-20-2018, 01:45 PM   #115
SuperTom
SuperTom's Avatar
Had some leftover white coroplast and used it to fill the tunnel area and used clips in the stock holes
Front pipe area, as you can see the frame starts to curve upward so that was about as far forward as I could go.
Have it all the way back meeting up with my Borla muffler which fills in the rest of the tunnel void
It is up against the pipe as it gets close to the Borla so some of it will melt
Old 09-20-2018, 06:59 PM   #116
SuperTom
SuperTom's Avatar
Also today was able to make the Vac Motorports seat mount a pound lighter since I don't use the back part of the mounts.
I need to take brighter pics but its really for me to keep track
So I lost 1lb modifiying the seat mounts and gained a 1/2 lb with the coroplast plate
New weight 2465.75 LBS
Sneak peak for tomorrow stared getting the tar out of the car this stuff is really heavy already have about 5lbs out but will have a final tally when I get it all out, and some heavy foam under the carpet will go!!!
Old 09-21-2018, 02:25 PM   #117
SuperTom
SuperTom's Avatar
Major weight reduction breakthrough!
Got all the Tar and under carpet foam out of the interior today
No need for dry ace a few seconds with torch and it turns to goo. Easily scraped up. Also allows you to get the horizontal areas
Tar locations:
Trunk
Behind Rear Speaker
Under Rear passenger foot
Under front seat feet
Side or Radio console
Behind the rear speakers first
rear seats floor and you can see the heavy under carpet foam
side of stereo console
More heavy rubber backed foam
Passenger side done
Foam weight
Tar weight
Heavy chunks
Back together like nothing happened
Final Weight Tally
Under foam = 6.25lbs
Tar = 6.5lbs
New Car weight 2453lbs
The Following User Says Thank You to SuperTom For This Useful Post:
Clipdat (10-06-2018)
Old 09-21-2018, 02:41 PM   #118
Wes
You keep coming up with new ideas. Start swiss cheesing the chassis now
Instagram: @gt86ws
SuperTom (09-21-2018)
Old 09-21-2018, 07:57 PM   #119
new2subaru
Weight Weenie
Drives: 15 FR-S
I would like to see some of this
Old 09-21-2018, 08:32 PM   #120
SuperTom
SuperTom's Avatar
whats that? is it lighter than something I can replace
Old 09-21-2018, 08:33 PM   #121
SuperTom
SuperTom's Avatar
Also cut off the Japanese tie downs. Not a lot of weight and a PIA to cut off but incase anyone was wondering the weight. 1.5lbs for both
Had to cut in pieces to get off easier
Painted everything after cutting the welds
only 1.5lbs
New weight
2451.5 LBS
Old 09-21-2018, 08:36 PM   #122
new2subaru
Weight Weenie
Drives: 15 FR-S
Dimple die for making very strong holes
Old 09-21-2018, 08:47 PM   #123
SuperTom
SuperTom's Avatar
oh yes the Opera S2000 had that done. I would seriously have to look into the proper way to do it. Maybe next year...
Old 10-02-2018, 07:52 PM   #124
SuperTom
SuperTom's Avatar
Scraped out the sound deadening out from underneath the wheel wells. Waste of time as I only got .75 lbs out of both front wheel wells
Old 10-02-2018, 08:05 PM   #125
SuperTom
SuperTom's Avatar
Huge Preview of some awesome lightweight parts will be installing soon
just got in some DRY Carbon parts from Seibon. I got the doors and trunk lid as they should give the most weight loss per $.
Weights did not disappoint
Doors 10.75lbs each
Trunk 7.5lbs with the center piece included
Doors
Looks like all the stock mounting points inside
10.75lbs !!!
Trunk - Was very happy it came with the center piece, It didn't show that in the pictures and I though I would have to use stock or buy separate
7.5lbs
The Following 2 Users Say Thank You to SuperTom For This Useful Post:
Clipdat (10-06-2018), new2subaru (10-02-2018)
Old 10-05-2018, 10:07 PM   #126
SuperTom
SuperTom's Avatar
Got the trunk installed today. Hardest part was getting the clips out for the licence plate seriously shit took a half hour for 2 clips. Everything fit great had to cut hole for backup camera though carefully with a Dremel.
Made a little template for the camera cut
Didn't take pictures during the install it was starting to rain but I persevered and got it done
Driver side had slightly more gap than passenger but both were close
And of course the weights now Stock trunk, wing and shocks were 18.5lbs
11lbs weight loss, Vehicle new weight 2439.75 LBS
Clipdat (10-06-2018), Raven86Project (10-06-2018)
mothespaceman: 14' Satin White BRZ Build! mothespaceman Member's Car Journals 25 09-19-2014 06:30 PM
White BRZ Limited Build Thread NoFlush Member's Car Journals 4 05-10-2014 03:04 PM
white trd 2013 build Pcharliep04 Member's Car Journals 0 04-24-2014 02:25 AM
Build-thread White Wasp FR-S by Mit_Peid mit_peid Member's Car Journals 7 01-05-2014 08:47 PM
White GT manual Jan Build availlable 86•BRZ AUSTRALIA 2 01-02-2013 12:45 AM
