Old 07-27-2018, 06:07 AM   #71
gpvecchi
gpvecchi's Avatar
Do you know if this unit provides guide lines for rear camera and if you can turn them off?
Stock camera already have them, so this will make a mess...
Old 07-27-2018, 10:56 AM   #72
wolffbite
Just the tip
wolffbite's Avatar
Drives: 2017 DGM BRZ
Yes you can turn off the parking guidelines on the DDX917WS and I would imagine it's the same on the DDX918WS as well. I had the exact same thought when I first started it up and had a bunch of overlapping lines.
wolffbite is offline   Reply With Quote
Old 07-27-2018, 11:45 AM   #73
el-guapin
el-guapin's Avatar
Drives: 1949 UFO
^^ I can confirm this as well!
el-guapin is offline   Reply With Quote
Old 08-17-2018, 08:47 PM   #74
azonic
Drives: 17 BRZ
Looks like this unit has just recently received a firmware update. Has anyone tried it yet?
https://www2.jvckenwood.com/cs/ce/mm...2017l/eng.html
(09.08.2018)
Improved Apple CarPlay Function.
Improved Android Auto Function.
Improved Radio function.
Improved stability of performance.
azonic is offline   Reply With Quote
Old 09-12-2018, 02:44 PM   #75
gpvecchi
gpvecchi's Avatar
I just discovered that the 86 misses the Bluetooth steering wheels keys that BRZ has. Do these keys work with DDX917/18?
Old 09-18-2018, 06:23 PM   #76
wolffbite
Just the tip
wolffbite's Avatar
Just to clarify your question, are you asking if the stock 2017+ BRZ steering wheel controls can be programmed to work with the DDX917WS? If so, then yes they are easily programmed through the headunit.
I see that some versions of the 86 have quite limited steering wheel controls, and they are not even buttons but just placeholders (can't press them). Now I'm curious if you would be able to swap in that part from the BRZ and gain use of these controls...
Old 09-19-2018, 12:54 AM   #77
gpvecchi
gpvecchi's Avatar
Yup, that’s exactly what I’m asking... I’m planning to buy the BRZ buttons, if the plug is the same they should work flawlessly...
Old 09-19-2018, 04:57 PM   #78
wolffbite
Just the tip
wolffbite's Avatar
Hope it works for you. If it does, definitely post here so people know it's possible to make the swap!
Old 09-20-2018, 02:50 AM   #79
djezlee
Drives: 2017 BRZ Limited
Originally Posted by azonic View Post
Vanilla, those cables are not 100%, I have gone through two - the second having the same problem as you described, the first not at all. A bit disappointing, but at least they make everything else really easy.
Grab a 12v-6v voltage dropper and hard wire it in, it's what I did and it works great now. Bonus being that I can then change the headset to reverse camera display at anytime.
This is the one I used; i'm sure you can find something similiar in Dublin https://www.jaycar.com.au/dc-to-dc-s...odule/p/AA0237
Which wires did you splice to hard wire it in?
djezlee is offline   Reply With Quote
Old 09-23-2018, 03:10 PM   #80
gpvecchi
gpvecchi's Avatar
Guys, urgent please: which bracket did you use to fit the DDX? TAS400 ones seem not correct...
Old 09-24-2018, 03:19 AM   #81
azonic
Drives: 17 BRZ
From memory off of 12v accessory power. You don't want to do it off 12v constant, as it will drain your battery. You will need to test to confirm.
I run the matching dashcam for the unit, which also required hard wiring both accessory and constant, so I just piggy backed off the wiring I did for that.
Old 09-24-2018, 03:27 AM   #82
azonic
Drives: 17 BRZ
FYI for you guys running this head unit and car play the following thread may be of interest:
http://www.ft86club.com/forums/showthread.php?t=126106
Old 09-24-2018, 03:52 AM   #83
djezlee
My bad, I thought you were using the Carbon Car System wiring harness.
Old 09-24-2018, 10:32 AM   #84
el-guapin
el-guapin's Avatar
Drives: 1949 UFO
That’s exactly what I did!.
Kenwood DDX916WS head unit -- any installed? willimusk Electronics | Audio | NAV | Infotainment 39 07-27-2017 10:47 AM
Kenwood DDX630WBT Toyota-spec head unit w/ nav install in US GSX-R35 Electronics | Audio | NAV | Infotainment 17 05-26-2015 03:37 PM
Anybody know ... what head unit this is? chaoskaze Electronics | Audio | NAV | Infotainment 3 12-21-2014 06:44 PM
Soo i installed a new head unit....gaps Sniper2606 Electronics | Audio | NAV | Infotainment 2 01-16-2014 05:12 PM
Toyota sized Kenwood Navigation unit Laurie Electronics | Audio | NAV | Infotainment 36 09-26-2012 12:07 PM
