go_a_way1
Old 09-14-2018, 07:26 PM   #4691
cruizin01
cruizin01's Avatar
Drives: 13' BRZ
They're designed around stock rears, which can also be swapped with the Brembo 2 piston rear. In theory, you could also use the Brembo 2 piston rear with the stock front, although I don't think anyone would actually do this; the system is designed to retain stock bias, regardless of how you "lego" the system together.
If you're used to driving properly bedded race pads on the street, the included pads with the CSG Brembo GT kit will be no problem for you. You'll get minor squeaks here and there at very low speeds, but no banshee howl. If you'd prefer, you can exchange those pads for pure street pads at no cost, to reduce noise and dust further.
Pads for the CSG Brembo GT are shared with every major 4 piston Brembo caliper on the market, including OEM.
I would expect to see a substantial pad use drop with this kit compared to Wilwoods, as well as superior braking feel, modulation, and consistency, as well as much lower temperatures for the same amount of braking stress.
Any OE replacement rotor can be used, as well as OEM, but due to the sheer capacity of this kit, you will not be needing rotors very quickly. Brembo replacement rotors are $330 each, but I've never seen them needing replacement with less than 30+ days at this time, and pretty much everyone with a CSG Brembo GT kit is tracking their cars seriously with nice race pads.
Thanks for the detailed response. Ill be pulling my wilwoods before too long and will be replacing them before next season. I had planned to run AP as that seemed to be the recommended setup but now I see your brembo setup that comes in a little cheaper with hopefully similar performance aside from weight.
cruizin01 is offline   Reply With Quote
Old 09-14-2018, 09:23 PM   #4692
CSG Mike
CSG Mike's Avatar
Originally Posted by Pat View Post
Capacity? That makes me think of the ability of the rotor to absorb and shed heat. Is that what you're referring to? If so, how is this kit any different than OEM if it can use OE replacement rotors? I'm missing something here.
The Caliper is significantly different from the OEM PP Brembo. Rigidity and capacity are on a while different level.
If you want to get into more technical details, it's shared with a Ferrari F40 and Lamborghini Gallardo. The piston sizing is changed to match this platform.
Seriously not kidding about the above.
Old 09-15-2018, 12:46 AM   #4693
Pat
Pat's Avatar
Drives: 2023 BRZ
Thanks, Mike. What do you mean by "capacity"?
Old 09-17-2018, 04:15 AM   #4694
CSG Mike
CSG Mike's Avatar
Ability to absorb heat and maintain rigidity.
Old 09-17-2018, 09:07 AM   #4695
n0thing
Drives: Subaru BRZ
By installing the Crawford manifold spacer, the powerband is shifted to the left by about 500rpm. Along with an UEL (not EL/Ace) and OFT tune adjustment, it'll probably improve the mid range. Would this make sense on the track though? The mid range should help corner exit, but at the cost of top end. Also, for straight line acceleration, would you now shift earlier, say 7k or even 6.5k, instead of redline?
Or would it be better to install the new red manifold?
n0thing is offline   Reply With Quote
Old 09-17-2018, 02:09 PM   #4696
Takumi788
JHerbert Racing
Takumi788's Avatar
Drives: 2013 Scion FRS
I am looking for some sway bars and was wondering what you would suggest for my car. Looking for a set with full track use in mind as 95% of my driving is on the track. I was about to pull the trigger on the RCE sways but figured I would ask you guys first.
2800 lbs full tank and me in it
I run 255/40/17 RE71Rs (200tw)
Custom valved Coilovers w/Front 400, rear 450 lbs/in Swift springs
Check my build thread in my sig if you need other info.
- #813 2013 Scion FRS Build Thread
- JHerbert Racing Website
Takumi788 is offline   Reply With Quote
Old 09-17-2018, 04:15 PM   #4697
CSG Mike
CSG Mike's Avatar
It would not, unless you have a specific need to shift early.
Old 09-17-2018, 04:16 PM   #4698
CSG Mike
CSG Mike's Avatar
The better question is why do you want, or think you want, sway bars?
Old 09-17-2018, 04:39 PM   #4699
kch
Senior Misanthrope
kch's Avatar
How do I determine when my AP CP8350 calipers need to be sent in for rebuilding? After my first winter up here I've found some small rust spots on the pistons, but everything is still functioning properly with no change in feel.
edit: calipers have maybe 30k miles on them, with roughly 25 days on track.
Old 09-17-2018, 04:40 PM   #4700
n0thing
Drives: Subaru BRZ
So improving mid range, or shifting the power curve earlier, is no good for tracking?
Old 09-17-2018, 04:44 PM   #4701
kch
Senior Misanthrope
kch's Avatar
I'm no expert, but I find myself very rarely under 4500 rpm on track.
The Following User Says Thank You to kch For This Useful Post:
CSG Mike (09-17-2018)
Old 09-17-2018, 04:47 PM   #4702
kch
Senior Misanthrope
kch's Avatar
my caliper pistons are very stiff to retract, even when using the spreader tool, but braking operation feels fine...
Mine too. I really have to crank down on them with the spreader, even with the reservoir cap open.
Old 09-17-2018, 04:47 PM   #4703
Takumi788
JHerbert Racing
Takumi788's Avatar
Great question.
Over the weekend I participated in both a track day and an autocross with brand new RE71Rs. Previously, I have been on a set of maxxis rc1s for the past 35+ track events. With the RE71Rs installed, I found myself stiffening the suspension quite a bit more than usual to get the car to behave as I like.
When I got to the point to where the car felt right I noticed I would loose grip (rather violently) mid-corner on flat corners. The only thing I can think to compare the violent loss of grip to would be like trying to slide a piece of tape across a table. It grips for a little bit, then abruptly lets go. But then it grips again, until it lets go.
It was minimal at the track but at autocross it seemed to be more of an issue. I talked to my teams engineer and he suggested that I continue stiffening the rear, run a stiffer spring rate or swap the sway bars. So I figured I would try the sway bars first because they are still stock.
Old 09-17-2018, 04:50 PM   #4704
n0thing
Drives: Subaru BRZ
at the track, I was never under 4500, but 4500-6000 (mid range) seems to be where most corner exits are at, so I figure it should help with exit speeds.
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 07:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 01:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 08:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) — General Topics 11 05-31-2012 08:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) — General Topics 20 01-10-2012 10:54 AM
