#1205 | |
Drives: dark grey Scion frs 2013
Beside maybe some couple brass upgrade, I hardly see how to fit a strut bar. Even if you try to make one that follow the back of the Sc, there s a lot stuff in the way. the hood is in the way for top mount too. https://imgur.com/a/wDaMXpT Last edited by Greacemonkey; 09-14-2018 at 03:48 PM. |
#1206 | |
Drives: 2017 BRZ
#1207 | |
Drives: 2016 Cosworth 2.2 BRZ
I like it better now. Seems easier on the engine to start and let the rpms build while oil pressure stabilizes. |
#1208 | |
Drives: blue - Cosworth SC stage 3.0
however as you say if its really cold then yes it would be wise to switch to a 50/50 mix in winter |
| The Following User Says Thank You to Matt@Cosworth For This Useful Post: | Greacemonkey (09-17-2018) |
#1209 | |
Drives: UK GT86
.: Stealth 86 :.
| The Following User Says Thank You to Kodename47 For This Useful Post: | sly (09-17-2018) |
#1210 |
I may have found the source of my EVAP codes. The brake vacuum booster hose had slid forward and was barely attached. The hose is almost too short and has constant tension against it. I'll look for a longer hose.
#1211 | |
Drives: 2017 BRZ Premium
Sent from my SM-N960U using Tapatalk |
#1212 |
Drives: GT86
Hi guys,
So i got a package last week ^_^ Big thanks for @Matt@Cosworth for replying for all my questions and superfast delivery. Hoopefully i will find some time to get it installed until winter and crappy weather arrive for good. Few pics ![]() ![]()
| The Following 5 Users Say Thank You to eMCee For This Useful Post: | ajc209 (09-17-2018), Greacemonkey (09-17-2018), Seba (09-17-2018), sly (09-17-2018), weederr33 (09-17-2018) |
#1213 | |
Drives: BRZ Cosworth SC MY16
![]() Witaj w klubie! Welcome to the club !
| The Following User Says Thank You to Seba For This Useful Post: | eMCee (09-18-2018) |
#1214 | |
| The Following User Says Thank You to Greacemonkey For This Useful Post: | eMCee (09-18-2018) |
#1215 |
Drives: 2023 BRZ Limited/Manual
Nameless failures...
Hi just wanted to post an update on the Cosworth Stage 2.3 parts at 30K miles.
Have gone through two Nameless cat backs - both developed severe cracking in the area of the resonator - the first one lasted about 6k miles, the second about 5k. The first one was replaced free of charge but i was unable to get any meaningful reply from either Nameless or Cosworth at the time of the second failure. I replaced the Nameless cat back with the Perrin one and so far all is good after about 10k miles - it's also not as obnoxiously loud - I understand some folks like that. The cat tube is hanging in there but about to be yanked and replaced with a resonated ceramic coated unit from JDL. It will go to recycling unless anyone wants to pay to have a used but functional Nameless cat tube with resonator shipped to them - I would ask nothing in return. My coated Nameless headers were fine until about two months ago when a crack developed near one of the welds in the merge - this is about 20k miles total on the header - not bad I suppose but, considering a factory header would likely last the life of the car, not so good either. The other issue with the Nameless header (which is also featured in some other designs) is the unfortunate loop up into the engine bay just inches under the air duct - this effectively cooks the underside of the intake duct and raises intake temps significantly. When an intake duct in the area over the header is too hot to touch after driving around there is a design fault - why add heat to a system that depends on removing it? Wrapping the intake duct with thermal blanket helped but it's a poor design IMO. Car is a daily driver and has never been tracked. I'm replacing the Headers with the venerable ceramic coated Ace 350 unit on Friday and never looking back - this design resides entirely under the engine and, as many have seen, has some seriously well-documented figures in terms of performance on NA cars. The rest of the system is fine and without fault - I still think Cosworth makes the best supercharging option for the BRZ/86 - too bad they are seemingly no longer available in the US. Not sure if Nameless is still making the exhaust parts either - I suggest anyone looking to pony up thousands for the Nameless parts think twice or if you see some on eBay keep looking. The Gates belt is also very hard to find in the US... but I was able to find one and replace it at the recommended 25k. -john
2023 Silver BRZ Limited/Manual |
#1216 |
I ran a standard gates belt with no issues. Available at Orilley's aito parts. I ran the aramid belt with the smaller pulley. Also available at Orilley's.
#1217 |
I've been running the axle back and midpipe exhaust (0.1 and 0.2) for over 20,000 miles now. No issues at all. I had some light surface rust on the exhaust tips and just polished them last weekend. They cleaned up perfectly. I picked up a spare complete exhaust (minus the header) off eBay for $400 in case I ever need it. Haven't even taken it out of the box yet.
I never drive my car in the snow. That's what the WRX is for. Maybe that makes a difference. So far I have had 0 reliability issues other than those caused by myself (loose hoses). I've been running almost 5,000 miles on the supercharger and everything is running great. Getting about 30mpg actual when calculated at the pump. Gauge says about 32-33 but it's actually 30. Good system. I predict it will be as reliable as OEM. |
#1218 |
Just picked up a set of Michelin Pilot Sport 4S tires. Noticed right away that the ride was much smoother and quieter than the OEM Prius tires it came with. All the very slight vibrations in the steering wheel are gone but I can still get feedback from the road. The grip is much better and feels more predictable. These had good reviews on wet roads which I why I got them. So far they feel almost as grippy on a wet road as the old Prius tires felt on dry roads. A much needed upgrade if you are going to run a supercharger. I noticed that with these new tires, the car is much more nimble. It has a quicker turn in when hitting a curve. At first I had a tendency to over steer. But after getting used to it, it makes the car feel even lighter.
I also fixed a small fuel leak that I just discovered. Back when I upgraded the fuel pump, the sleeve gasket that wraps around the fuel basket must have gotten folded and I didn't realize it. When I tightened the fuel pump ring, it pinched the gasket and eventually put a small tear in it. I smelled gas one day after filling up the tank and noticed a few drops on the ground. Ordered a new gasket and a fuel tank spanner wrench to make the job easier. They recommend about 62 ft/lb of torque on the fuel pump ring and it's impossible to get it right by using a hammer and chisel like most people recommend. Found an adjustable spanner wrench for $20 and it worked and allowed me to get the torque right. So with the ever so slight tear in my fuel pump gasket and the previous problem I had with my brake hose slipping off, I think I have fixed the EVAP leaks on this car. I don't smell gas in the slightest now and I filled up yesterday to be sure I still wasn't leaking. Still no problems out of the supercharger. Feels better than OEM. No rev hang when shifting, idles completely smooth when the A/C is off. The idle still surges a little when the A/C cycles but that's probably to be expected with a 2.0L engine. Thanks @Matt@Cosworth for helping me sort through the EVAP problems. You put together an amazing kit. Now I find myself in a conundrum. Do I drive it and enjoy it or do I put it up in a garage, knowing how rare a Cosworth BRZ is going to be? Last edited by sly; 10-14-2018 at 01:31 PM. |
| Jackson Racing Supercharger Owners Thread | enivid | Forced Induction | 6036 | 11-12-2025 11:42 PM |
| Kraftwerks Supercharger Owners Thread | projek_01 | Forced Induction | 4310 | 04-07-2025 02:12 PM |
| HKS Supercharger owners thread | wbradley | Forced Induction | 1054 | 10-26-2024 02:18 PM |
| Phantom FTS Electric Supercharger Owners Thread | TM | Forced Induction | 1206 | 12-15-2019 03:33 PM |
| Supercharger Kits! Vortech/Cosworth | RallySport Direct | Forced Induction | 61 | 06-29-2015 12:26 PM |
