Old 09-12-2018, 11:47 AM   #1
Feargt86
F3AR86
Feargt86's Avatar
Drives: 2016 Scion FRS
Pbm, stance, or Megan racing LCA’s
Hey guys, so I just put some new wheels on my car but the rear is slightly a little higher than the front and I’m maxed out in the rear, I have about a third of an inch to drop on the front but I do not wanna go any lower on the front. I can barely get out of those Costco speed bumps, do you guys think pbm, Megan, or stance Lower control arms can perhaps drop the car a little bit on the back. Which of these brands can get the job done including camber flexibility wise, I know that pbm is less expensive than the other two. Thoughts?
Feargt86 is offline   Reply With Quote
Old 09-12-2018, 12:48 PM   #2
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
So you didn't have this problem with your previous set of wheels? I don't see how just swapping wheels would create that much difference in front/rear ride height.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 09-12-2018, 02:14 PM   #3
Feargt86
F3AR86
Feargt86's Avatar
I had my stock 17inch wheels on then once I put on my 18x9.5 wheels I notice a gap in the rear, roughly 1.6 inches, the front is flush with the fender all my coil overs were ride height matched, damping etc. my buddy told me the rear is usually higher for some reason, so I’m trying to remedy that with some lower control arms but not sure what brand to go with or what will do the job
Old 09-12-2018, 03:26 PM   #4
FirstWinter
Drives: Car
SPL rear lower control arms are great.
FirstWinter is offline   Reply With Quote
Old 09-12-2018, 03:29 PM   #5
VIP BRZ
VIP BRZ's Avatar
Drives: 2014 Subaru BRZ
I have the PBM LCA's. They have been great, and they have two mounting holes so you can get them really low. You wont have run max low on your coils.
VIP BRZ is offline   Reply With Quote
The Following 2 Users Say Thank You to VIP BRZ For This Useful Post:
DavidBob (09-14-2018), Leonardo (09-12-2018)
Old 09-13-2018, 04:36 PM   #6
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
PBM or Stance, avoid Meg.
Old 09-13-2018, 04:48 PM   #7
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
What's wrong with SPC LCAs?
N1rve
Old 09-13-2018, 06:14 PM   #8
x808drifter
LMGTFY
He wants ones that lower the mounting point I believe.
Old 09-14-2018, 12:18 AM   #9
tyler_win_photo
tyler_win_photo's Avatar
Drives: 2014 Scion FRS (Asphalt)
If you can barely make it over a speed bump.. shouldn't you be raising the car? But yes, all of the LCAs you mentioned will drop the rear down. My brand preference would be pbm or stance.
tyler_win_photo is offline   Reply With Quote
Old 09-14-2018, 01:57 AM   #10
I am with 8. Changing wheels should not impact height. Even if they did it should not be different front to rear.Any change should be the same.
Old 09-14-2018, 10:18 AM   #11
DavidBob
DavidBob's Avatar
Drives: 2013 WRB BRZ
I've had Stance LCA's and now I made the switch over to PBM. PBM is the only one that can actually lower your car more because of the two coilover mounting spots (one higher one lower). The rest of the LCA's out there just help with adjusting camber.
Instagram - @David_bobb
Build Thread - http://www.ft86club.com/forums/showthread.php?t=124218
DavidBob is offline   Reply With Quote
Old 09-14-2018, 10:57 AM   #12
asdf
Loading...████████] 99%
asdf's Avatar
Drives: #0517
RSR is another option
R1 3 5
. 2 4 6
asdf is offline   Reply With Quote
Old 09-14-2018, 04:38 PM   #13
x808drifter
LMGTFY
The stances also lower the rear, while they don't have 2 separate mounting points, they do by design make the mounting point lower than compared to other straight RLCA's.
The Following User Says Thank You to x808drifter For This Useful Post:
Leonardo (09-14-2018)
Old 09-17-2018, 02:12 PM   #14
DavidBob
DavidBob's Avatar
Very true, they are kinked in the middle to be lower compared to others buuuuut compare them to pbm. I feel like stance LCA's are still straighter than pbm plus on top of being like curved they also have a hole where you could mount even lower. I'm not here as a pbm rep trying to sell them lol just passing on what I experienced. Going from the same coilover height there's a significant difference on pbm.
*** Feal Suspension, Megan Racing, BC Racing, KSport, ISIS Coilovers - ON SALE!!! *** Sonic Motor Brakes, Suspension, Chassis 489 07-29-2016 02:15 PM
Megan track series coilovers, Megan trailing arms, Megan sway bar, some other goodies nickmerronesucks Brakes, Suspension, Chassis 5 06-27-2016 01:07 PM
Megan racing oe-rs catback fcdrifter20 Engine, Exhaust, Bolt-Ons 11 12-30-2015 12:44 AM
