| View Poll Results: Do you have chirping (cricket) noise during idle once the car is warmed up? | |||
| Yes (Please only vote after you have 300 miles or more on the odometer) |
3,101 | 85.22% |
| No (Please only vote after you have 300 miles or more on the odometer) |
538 | 14.78% |
| Voters: 3639. You may not vote on this poll | |||
#309 | |
Drives: Skoda Yeti DSG diesel 4x4
Thought I said that before? It certainly seems that ethanol could be the culprit. The problem should then be worse in damp humid conditions than in dry desert areas. What was it that you add to fuel to keep water dispersed and held in suspension? Just looked it up, acetone. Do you think that might solve any ethanol hygroscopic problems or would it still come out of suspension under pressure? |
#310 | |
Drives: 2008 STi
No, the oil gets a positive bond on the ethanol and surrounds it which would prevent any moisture even under higher pressures. Basically the oil prevents the H2O from puddling and not collecting. |
#311 |
It would seem that the refineries are at fault for not adding fuel stabiliser along with the ethanol to combat the inherent problems it has.
If you had an 86 would you add stabiliser or 2T to your car. Would you leave it alone and let it self destruct under warranty? Will Toyota/Subaru not honour warranty claims, instead referring claims to the fuel companies? |
#312 |
Drives: N/A
I'm surprised that the 2-stroke is helping. Can we get this thread stickied?
#313 | |
Drives: 2008 STi
The downside to ethanol is that is attracts H2O and isn't very energy efficient. |
#314 |
#315 | |
Drives: Mazdaspeed 3
| The Following User Says Thank You to Fenrir For This Useful Post: | Sportsguy83 (07-13-2012) |
#316 | |
Any noise caused by a lack of lubrication means high friction and the breaking down of the surfaces that are in contact. That means material will be lost, clearances will increase and the lost material will pollute the pump and the fuel. Toyota/Subaru says it's not a problem because that suits them currently. It clearly is a problem and the consequences could be extensive. |
#317 | |
Drives: N/A
Somebody said sulfur was the missing lubricant. Everyone knows that sulfuric acid is highly corrosive stuff so I'd bet it was something else bonded to sulfur and not necessarily sulfur that provided lubrication. exactly since I'm not a chemist. I searched for sulfur as a lubricant and I came up with a few diesel related rumors/myths what have you.And it's energy density not energy efficiency, very big difference. For example MPG != energy efficiency. That would be fuel economy. |
#318 |
Drives: 2013 SWP Limited BRZ, MT
Just my luck I'm at the dealership and I can't replicate the chirp. It rained last night and is too cool for the noise to get Loud.
#319 | |
I don't mean any offense, but aircraft engines != car engines. |
#320 | |
If they don't have the chirping in Japan but the same cars in the US make the noise surely that means there's something wrong? I worked[retired now] on both piston and gas turbine[jet] engines and the fuel systems were far more complex than a car. Now the car fuel systems with much higher pressures are also getting more complicated. The differences are less than you might imagine. I've also worked on cars, my own, as an employee and lastly in my own company. My posts here are purely based on my interest in the 86 since I have one on order, to enjoy while I can still get a buzz from driving something that's fun instead of practical and boring. |
#321 | |
Spaceman
Drives: 2013 Firestorm Scion FR-S
#322 | |
| Is this idle noise normal? | robo_robb | Engine, Exhaust, Transmission | 288 | 01-25-2022 10:40 AM |
| Squeak noise from engine. | Fish | Scion FR-S / Toyota 86 GT86 General Forum | 52 | 05-08-2014 02:06 PM |
| Video of chirping at idle | Julio86 | Engine, Exhaust, Transmission | 15 | 02-01-2013 11:37 AM |
| Starting to get worried - Engine noise | Laika | BRZ First-Gen (2012+) — General Topics | 49 | 07-02-2012 04:45 PM |
| Idle issue poll/role call | Hawaiian | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 06-13-2012 01:00 PM |
