Old 09-03-2018, 08:00 PM   #197
Originally Posted by Dr. BRZ View Post
@SuperTom and @86TOYO2k17 by Saturday, my 13 brz limited will weigh less than both your cars, i should be at 2400lbs even. I will know the final count on Saturday. Yah buddy! Lol
I haven't seen a picture of your car - but, I'll betcha it would have a ways to go before I would be impressed -
Old 09-03-2018, 09:23 PM   #198
Dr. BRZ
Dr. BRZ's Avatar
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
The picture specs for the forum are dumb, it wont let me upload any pics
Dr. BRZ is offline   Reply With Quote
Old 09-03-2018, 10:14 PM   #199
That's OK, I think I see it, or what's left of it -
Old 09-03-2018, 10:26 PM   #200
Dr. BRZ
Dr. BRZ's Avatar
Not yet but it will be there! 😘
The Following User Says Thank You to Dr. BRZ For This Useful Post:
humfrz (09-03-2018)
Old 09-03-2018, 10:42 PM   #201
86TOYO2k17
Drives: 2017 toyota 86
Nice! I saw you said you where at 205whp as well at 2400lbs not a bad ratio. Car probably feels pretty fast now.
Got any dynos or done any 0-60 1/4mile 60-120 testing?
Got a build thread?
Old 09-04-2018, 03:16 PM   #202
Joesurf79
Joesurf79's Avatar
Drives: 2016 White Pearl BRZ Premium
Originally Posted by SuperTom View Post
1lb .5 oz , plus I just realized I had that stock mount on it too! I think I'm going back and redesigning this with spacecraft unobtanium just to beat you!
Here's my Braile 9 lb battery tied down with a strip of 1" wide 1/16" thick aluminum strap. Anchored to two rivnuts drilled into the battery pan. Lightest battery tie down system I've seen
Joesurf79 is offline   Reply With Quote
The Following User Says Thank You to Joesurf79 For This Useful Post:
SuperTom (02-10-2020)
Old 09-04-2018, 05:45 PM   #203
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
Damn that's FKing awesome! Im at 2465 but I have vacation in 2 weeks I will be hitting the treadmill again.
Are you stripped out? Do you have a build thread to see your path?
Again my goal is to still stay stockish looking meaning no stripped interior.
SuperTom is offline   Reply With Quote
Old 09-04-2018, 05:47 PM   #204
SuperTom
SuperTom's Avatar
Can you get a better closeup of your setup looks good from here. Im just going to redo my design in aluminum instead of steel should get me down to 1/2 LB at most!
Old 09-04-2018, 06:45 PM   #205
Joesurf79
Joesurf79's Avatar
Yeah, I'll snap pics tonight when I get home. That was an engine bay shot I had on my phone
Old 09-04-2018, 06:48 PM   #206
churchx
churchx's Avatar
Drives: 2014 GT86
SuperTom: some strong synthetic material flexible ribbon shouldn't be even lighter?
Old 09-04-2018, 09:07 PM   #207
86TOYO2k17
I’m just going to use a AAA battery and a piece of gum to hold it down and beat you all.
The Following 2 Users Say Thank You to 86TOYO2k17 For This Useful Post:
endless_pain (05-26-2020), Ultramaroon (09-21-2018)
Old 09-04-2018, 09:12 PM   #208
churchx
churchx's Avatar
Drives: 2014 GT86
Hand-crank starter, especially left out after engine is started, will result in even more weight savings! no battery (and no starter motor) = lightest battery!
Old 09-04-2018, 09:14 PM   #209
SuperTom
SuperTom's Avatar
well not sure if you know but my design is super crazy sturdy so its worth the 1lb weight it adds. Its a cradle for battery to sit inside. Then I use the stock tie bar which is light to hold it down. It will not move in any horizontal or vertical direction. Pushing or pulling on it just moves the car instead. Had a nasty situation about 10 years ago where my pc680 came loose and shorted out bad on the firewall sparking and shutting everything down.
Anyway just want to remake the design with aluminum instead of steel with stuff I can grab at home depot.
This was how it looked before I cut the sides down
Old 09-10-2018, 11:43 PM   #210
86TOYO2k17
Finally got around to getting my underdriven fensport water/alt pulley and fluidampr pulley on. As well as my cf dss driveshaft, and jdm underpanels. Got lazy/ran out of time for the velox trans tunnel panels.
Car is pulling hard now. Puts you into the seat.
Although to be fair I did reflash to my revision 7 from 6, since now that it’s cooling down again hoping my 1IAM won’t keep dropping. Either way car is feeling good.
Understanding Fuel Trims ShadowReaper Software Tuning 13 04-01-2018 01:34 PM
Understanding Compressor Maps arthur93 Forced Induction 31 05-25-2017 10:49 AM
Understanding Oil tofurun Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 13 06-10-2016 04:06 PM
BUDDY CLUB Lightweight Racing Wheels - JDM, lightweight, low pricetag | 18x8.5" GuerillaRacing Wheels and Tires 116 01-20-2015 07:32 PM
Understanding/clarifying vendor qualifications mav1178 Site Announcements / Questions / Issues 21 03-18-2014 03:25 PM
