| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
Drives: ‘15 BRZ
Learning manual, stalled so many times
Just got a manual brz and I’m getting the hang of it, except for hills. Tried to get out of a parking structure which was underground and has a very steep hill. Stalled so many times before I got out (about 7 or 8, maybe even 10.). Should car be ok?? And how long did it take you guys before learning to go up a steep hill? At least I didn’t burn the clutch
but just worried about the car.
#2 |
How do I shift?
Drives: '13 GBS BRZ
I love my girlfriend, but man she was a horrible teacher. I was scared for the longest time when stopping just below a hill, like the traffic lights close to the base I was stationed at, but I think two weeks did it for me. She had never really explained that I could ride the clutch a second longer to make shit work, so I always let it out too soon. Man, good times.
#3 |
Even if you're comfortable, practice starting out on level ground without any gas. It's a real skill builder. I guarantee it will help you on inclines.
I remember teaching someone who, for some reason, was under the false impression that once the car started moving he had to commit to full engagement. Learn to modulate the clutch by itself to keep the car from stalling. That's the value in practicing a no-gas start. I'm sure the car is fine. The clutch will get mushy on engagement when it gets too hot. It's the same as brake fade only different.
| The Following 4 Users Say Thank You to Ultramaroon For This Useful Post: |
#4 | |
Drives: 2014 BRZ Limited
You may not have a '74 MGB with a racing engine and a convenient hill outside your front door. But I told the story to illustrate that it just takes practice. Lots and lots of it. If there's a hill nearby without much traffic where you can go practice without being under pressure from angry horns behind you, go practice. Then go practice some more. About the time you're feeling comfortable, you'll be in traffic somewhere, panic and stall out again because you'll be worried about the eyes on you from the other cars nearby. It will make you feel discouraged about your skills, but the only way to feel good about them again is to go practice again. After you've been driving for a few years, there will come a day when you'll stall it in traffic again. People who have been driving for thirty years will stall out occasionally, and they usually say, "What the fuck was THAT? What is WRONG with me?" Don't worry about the car. The clutch is designed to take the force of the engine and transmit it to the transmission and all the way to the rear wheels. It's not necessarily a gentle process. The clutch can take it. And consider this: 82% of Americans already can't do what you can do. Only 18% can drive a manual, and that includes all the ones who can just barely drive it, but not very well. There are very few people in any kind of position to sit in judgment of your skills. So take the pressure off yourself, because you're already among the elite. |
| The Following 7 Users Say Thank You to extrashaky For This Useful Post: | dhuang (09-01-2018), FRSBRZGT86FAN (09-01-2018), Ganthrithor (09-05-2018), spike021 (09-01-2018), Swabodda (09-01-2018), Tristor (09-01-2018), Ultramaroon (09-01-2018) |
#5 |
Drives: Silver 2017 Limited with PP
Not an expert, and it's flat as a pancake here, but if I'm ever on an incline I use the parking brake to keep car from rolling while I play with clutch and accelerator pedal. Don't know if that's how it's done, but it helps me. That or grow a third leg.
#6 |
Nothing wrong with that. Let the haters hate.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | gravitylover (09-01-2018) |
#7 | |
The Dictater
Drives: '13 Red Scion FRS
I find this to be the most effective solution when I need to get it up a hill. Also effective with speed humps and the like. |
#8 |
TRACKBREAD
This isn't for everyone, but I've been able to help some people with this advice:
Keep your heel on the floor when letting the clutch out. You can use the friction with the carpet to modulate the clutch much more precisely than when your foot is hovering. |
| The Following User Says Thank You to Yoshoobaroo For This Useful Post: | ermax (09-02-2018) |
#9 |
Drives: ZC6
I must say... while the BRZ's clutch is light and almost effortless, it is rather difficult to control at first until you get used to it which lead to my opinion that it is not all that great as a first manual car. This is because there is almost no feedback from the clutch pedal. Plus there is a rather ambiguous yet very fine point between engagement and stalling, like the car would only begin to slightly creep forward in a way that makes you think you can let off the clutch justtttt a bit more... then suddenly, stalled. I also know that lack of feedback is due to some spring above the clutch pedal and you can mod (remove) it out but it is ridiculous as-is for a car that is supposed to be all about the "feel" and pleasure of driving.
I've driven quite a few manuals and for almost ten years now and I stalled quite frequently initially when I first bought the car. I haven't stalled this frequently in a car since I first learned how to drive stick. Everything is all good now but once a blue moon, I'll surprisingly stall. I am still figuring out the trick on how to smoothly shift into second. Anyway, like others above are saying, learn no-gas clutch work. Build the muscle memory. Find a long flat road with little to no traffic and just get the car moving from letting off the clutch, stop, repeat. Do the same on an inclined driveway somewhere to practice hill starts. |
#10 |
Drives: 2017 brz
My 17 has hill start assist, does the 15 not have it? If it does I would use that until your more comfortable with the clutch and gas dance.
#11 |
ThisGuyLoves86's
Drives: 2013 Scion FRS
Hill start is a new feature for 2017.
2013 Scion FRS (current car)
1991 Mazda Miata MX5 (current car) 2003 Nissan Pathfinder (R50) (current car) 2018 Lexus GX460 (current car) 2023 GR86 Neptune M6 Premium (Leased) |
#12 | |
Panda Trueno
Drives: No twin now.
Also. Learn how to drive. |
#13 |
Junior Pizza Joe
Drives: 2017 BRZ Limited Manual WRB
Folk's that "don't know" talk about the stick shift a lot, but it is learning the clutch part of a manual transmission that makes driving one a challenge and a reward.
Scooby-Doo: Scooby-Dooby-Doo!
Shaggy: And like, Shaggy too. |
#14 | |
Drives: 2018 BRZ TS 244/500
| Engine Stalled While In Motion, Won't Fire Up | Borchert97 | Issues | Warranty | Recalls / TSB | 29 | 09-05-2017 08:37 PM |
| Stalled while driving | KDad2 | Issues | Warranty | Recalls / TSB | 18 | 05-23-2016 02:30 PM |
| Learning about cars. | Zoh | BRZ First-Gen (2012+) — General Topics | 66 | 01-17-2015 03:49 PM |
| POST YOUR 1/4 MILE TIMES Quarter mile times | NYCsubaruBRZ | Tracking / Autocross / HPDE / Drifting | 1 | 02-04-2014 07:59 AM |
| Forum seems to have stalled... | Dimman | Scion FR-S / Toyota 86 GT86 General Forum | 27 | 07-23-2010 06:08 AM |
