Release 10 Series
Drives: 2013 10 Series FR-S #1874
Gas Gauge
Forgive me if this has been covered in another thread in the past. As a new member, I did a search but found nothing like what I am experiencing.
I purchased a 2013 FR-S a week ago. Yesterday, I had about 3/4 of a tank of gas and I was going to top it off to full. After filling up, I got back in the car and noticed that gas gauge had not moved from the 3/4 mark to full. Has anyone else had this happen or know what might be the cause? I am going to drive the car for a while longer to see if the gauge drops. If it does, I will then fill it up again and see if the needle points to full or not. |
#2 |
22R
Drives: 2012 Camry SE 2017 Toyota 86
Happened to my 17 86 once. From what I read it is normal as it is a compensation thing so that the fuel gauge stays pretty steady so a small change it won't register. Mine never did it since but I usually always fill it at least below 3/4 tank.
22R |
| The Following User Says Thank You to 22R For This Useful Post: | Ultramaroon (08-20-2018) |
#3 |
Release 10 Series
Thanks 22R. Hopefully the gauge will drop as I continue to drive it, and then I will fill up the tank and see where the needle points at that point, being there will be a greater distance to move at that time.
#4 |
Normal for this car. Just don't fill until below a half tank.
#5 | |
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
#7 |
Drives: 2013 Scion FR-S Firestorm MT
I've noticed this as well on my car, it is a 2013. I've just waited until the gauge drops to 1/2 tank and you won't see the issue. Not sure why this happens on our cars
Parts List: Perrin CAI + Borla UEL Header + Perrin Overpipe + Invidia Front Pipe w/ High-Flow Catalytic Converter + FT-86 SpeedFactory V1 Exhaust + 10k HID's + Eibach Sportsline Springs + TRD Spoiler + Rear Diffuser + Rear Spats + OFT Stage 2 Tune +18" Enkei Black Raijin Wheels (18x8 +45 up front 18x9.5 +45 in rear) Tire Specs: 235/40R18 in the front, 265/35R18 in the rear
#8 | |
Release 10 Series
#9 |
Drives: 2014 BRZ Limited
Because these cars are built for violent lateral maneuvers that slosh the gas around in the tank and would make your fuel gauge bob up and down like a cheerleader's head on prom night if it wasn't designed to dampen out small changes in level.
| The Following 2 Users Say Thank You to extrashaky For This Useful Post: | g e (08-21-2018), metalmoses (08-22-2018) |
#10 |
Car N00B
Drives: Honda Accord (2002)
While on the topic of the gas gauge... How much is typically left in the tank when the gas light comes on?
#11 | |
Mine comes on pretty much weekly. Have driven as many as 30 miles after it comes on and have never run out.
#12 | |
Car N00B
#13 | |
Where are you going in Canada? You realize we have gas stations all over just like you do right?
#14 |
Car N00B
Haha of course, I was just pulling your leg. I've been numerous times before - just never drove the distance in the FR-S.
| AEM Oil temperature gauge and pressure gauge with pods. | mtsound | Engine, Exhaust, Bolt-Ons | 2 | 08-24-2017 01:55 PM |
| Fs: Gauge Pod and Autometer Boost Gauge | Juanito08 | Interior Parts (Incl. Lighting) | 1 | 06-29-2017 05:36 PM |
| Gauge cluster with Oil Temp Gauge | Jetbill | Interior Parts (Incl. Lighting) | 1 | 10-06-2015 02:41 PM |
| Defi Oil Pressure Gauge and Cravenspeed Flexpod Gauge Mount Install and Review | Tye300 | Cosmetic Modification (Interior/Exterior/Lighting) | 10 | 05-22-2015 01:48 PM |
| Temperature Gauge a dummy gauge? | bambbrose | BRZ First-Gen (2012+) — General Topics | 40 | 08-19-2012 05:29 PM |
