go_a_way1
Old 08-25-2018, 04:02 AM   #4635
Flow
Drives: DGMBRZ
Hi. I've got a 2013 BRZ, with 80k mostly highway miles, and just two track days. I really want more power. I have the Phantom SC, and like it when it works, but I don't have the time or skill to keep it that way, so I'm considering the JRSC. I bought this car with the plan to keep it for a long time, and am wondering about the wisdom of adding this SC with this many miles. Any thoughts or things to consider? Would I just be buying trouble at this point in the car's life?
Flow is offline   Reply With Quote
Old 08-26-2018, 12:08 AM   #4636
CSG Mike
CSG Mike's Avatar
If you've maintained the car well, the JRSC should be just fine for your car. There are many 100k+ mile JRSC cars running around.
Old 08-26-2018, 12:29 AM   #4637
Anderzz
Anderzz's Avatar
Drives: 2013 Subaru BRZ Premium
Put in my C38 at 68k. Do your supporting mods properly and you'll have no issues. At 75k now and the only issues I've had were a boost leak and my Throw out bearing committing ritual suicide today XD
Sent from my XT1650 using Tapatalk
Anderzz is offline   Reply With Quote
The Following User Says Thank You to Anderzz For This Useful Post:
Flow (08-31-2018)
Old 08-26-2018, 04:23 PM   #4638
Jasten
Weird noise. Help?
Hello everyone, when the noise first started I initially thought it was the blower, and I knew I was also due for an oil change on the supercharger unit, so I went ahead and did that. Now I'm unsure whether or not the sound is coming from the supercharger or the engine itself. I have also checked all the bolts on the pulleys and they seem to be intact. Can anyone help?
Jasten is offline   Reply With Quote
Old 08-26-2018, 09:17 PM   #4639
AndreC
Drives: Fast track beast
Almost sounds like loose pulley, but very hard to figure out sounds off a video.
Sent from my SM-G965W using Tapatalk
AndreC is offline   Reply With Quote
Old 08-26-2018, 09:39 PM   #4640
AndreC
Overheating, who has experienced this with their engine on a JRSC?
How common is a head gasket leak on these setups?
Details:
- started overheating only on track about 6 weeks ago
- JRSC installed this time last year with zero issues concerning heat
- only coolant is overheating, no issues with oil temps at all
- drives and holds temps fine on street driving
- on track, temps will rise by about 5-8 degrees per lap, until they reach 230F
- coolant pressure test done, found a leaky heater hose, retightened and no difference
- leakdown test done, was tight and no bubbles from coolant
- HC coolant test ("engine block tester") came out negative
- rad changed (twice), water pump, and thermostat, zero difference
- replaced all hose clamps
- bypassed heater core with no changes
- no coolant in oil
- no oil in coolant
- no white smoke (running water and wetter)
- no power loss
- loses a very small amount of coolant during street driving, loosing lots on track but no visible leaks anywhere
- heater core now always blows warmer (even on cold air setting)
- AC stopped working
Sounds like we've finally exhausted the coolong system.
That leaves head gasket, or possibly cracks in the head or block (less likely).
Thoughts?
Real experience with similar issue?
Old 08-26-2018, 09:40 PM   #4641
idkwhatimdoing
idkwhatimdoing's Avatar
Drives: 2015 Scion FR-S 1968 Camaro BB402
Jackson Racing Supercharger Owners Thread
Sounds like a snapped turbine shaft, sorry bro
EDIT:
Sorry, didn’t read the no power loss part...
No clue which sound I’m supposed to be listening for
________
~refer to username~
idkwhatimdoing is offline   Reply With Quote
Old 08-26-2018, 10:22 PM   #4642
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Sounds like supercharger bearing failure. Hope you are still under jackson, rotrex warranty.
Jasten (08-26-2018)
Old 08-26-2018, 10:41 PM   #4643
Jasten
I am. Just wanted your guys' input before I go ahead and take it off, send it in, and be without my car for a couple of weeks
Old 08-26-2018, 10:50 PM   #4644
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Mine took almost 5 weeks. You send to Jackson, then they send to Rotrex, then 10+ business days for them to examine, then ship back.
If you are still under warranty why would you be changing rotrex oil? That stuff lasts a ton of miles?
Old 08-26-2018, 11:06 PM   #4645
Jasten
I have almost 30k miles on the supercharger, but it has been 2 years. Probably a waste to change it before finding out that it actually is the blower, but I guess i just had to try and rule out the things that I can actually change.
Old 08-27-2018, 04:24 AM   #4646
milanojess
milanojess's Avatar
Drives: 2013 FRS
May want to use a mechanic’s stethoscope or a long screwdriver and stick handle to ear and pin point noise source
2013 FRS - JRSC CARB
"Use all of the track" they say
milanojess is offline   Reply With Quote
The Following 2 Users Say Thank You to milanojess For This Useful Post:
CSG Mike (08-27-2018), Jasten (08-27-2018)
Old 08-27-2018, 01:53 PM   #4647
Brz866
Brz866's Avatar
Drives: Series Blue WRB JRSC C38 HBP Flex
Hi everyone so I need advice on which aftermarket diverter to go with. Been running the C38 JRSC for a while now and it's going strong. Honestly, I have no reason to replace the Bosch valve other than to have a metal valve and hopefully louder bypass noise. Not looking for a total VTA Btw. I've looked into forge, tial, and Amazon valves. What bypass valve are being ran on everyone's cars? What spring is best as well? Softest? Anyone try a tial valve with their 2 psi spring?
Also does anyone have one of those 50/50 valves? Those seem pretty interesting if even for the sound alone providing they don't mess with supercharger efficiency.
Thanks everyone!
Brz866 is offline   Reply With Quote
Old 08-31-2018, 01:11 PM   #4648
Flow
Drives: DGMBRZ
So, from a longevity perspective, in your opinion, what would be proper mods? I've looked at your (extensive) modding - nice. Which would you suggest for longevity? (I'm in California, so do not think I'll be doing any other exhaust mods cause of CARB restrictions.) Do you think new engine mounts, or other bushings? Any of these, for that purpose.
Jackson Racing Track Oil Cooler
Forge Motorsports Recirculation Valve
Radium PCV Catch Can
Delicious Tuning eTune
Fluidampr Dampening Pulley
P.S. I am going through the related JRSC threads and trying to glean what I can, but its slow going to find useful bits. Tks for responding to my questions.
The Following User Says Thank You to Flow For This Useful Post:
Tristor (08-31-2018)
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 05:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 10:04 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 04:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 05:14 PM
