Old 08-23-2018, 06:58 PM   #15
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
Red is cool. I can't argue with that.
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos!
You can also find me on Instagram, and on Facebook.
Stang70Fastback is offline   Reply With Quote
The Following User Says Thank You to Stang70Fastback For This Useful Post:
mrg666 (08-23-2018)
Old 08-23-2018, 08:04 PM   #16
wolffbite
Just the tip
wolffbite's Avatar
Drives: 2017 DGM BRZ
I thought the 2018+ MY got the 3 blink tap feature? http://www.ft86club.com/forums/showthread.php?t=121515
Might be North America only...
I have a tap-turn for my 2017 so I could get this feature. Works perfectly. I turned off the departure/arrival lighting.
wolffbite is offline   Reply With Quote
Old 08-24-2018, 01:00 AM   #17
RallySport
Drives: FRS
I have the DD version, really like it, but no arrival feature for my '13 FRS. Is it just their's that it doesn't work on?
RallySport is offline   Reply With Quote
Old 10-30-2018, 12:31 PM   #18
BOND007_LTK
Drives: 2013 brz
I have been contemplating either one. But as one member mentioned, theres not much resistance between tapping it and pushing it all the way.
I've been trying to tap without the module and having a difficult time not pushing it all the way especially with one hand. As such I feel the module will not work well.
Anyone else experience this or owner of the modules can chime in?
BOND007_LTK is offline   Reply With Quote
Old 10-30-2018, 12:36 PM   #19
Stang70Fastback
A.K.A. Starlord
I don't have this issue. The turn signal stalk in this car feels no different than in every other vehicle I've ever driven. There should be enough resistance for you to not accidentally click it into the "locked" position, because that is how you temporarily signal lane changes and things. If it snaps to the locked position immediately when you try to signal, your stalk assembly may be defective, and you should have it looked at. Unless you like needing to manually engage and then manually disengage the signal every time you change lanes and such.
Old 10-30-2018, 12:43 PM   #20
wolffbite
Just the tip
wolffbite's Avatar
While it's true there is very little resistance on the stalk it is just something I got used to. Probably less than a week and I could do it reliably without it clicking over fully, just have to get a bit of muscle memory built up. I love the feature, works nicely for merge lanes and freeway exits.
The resistance feels similar to my dad's BMW Z4 which has the 3-blink tap feature from the factory, so maybe that's why I got used to it so quickly.
Diode Dynamics: SmartTap CF18 (LM449) Flasher Relay! Add One-Touch Signaling / Strobe Diode Dynamics Exterior Parts - Lighting 73 06-30-2022 02:30 PM
Installed SmartTap Relay, LED turn bulbs / Valenti REVOs notorious9i6 Cosmetic Modification (Interior/Exterior/Lighting) 14 05-22-2017 06:58 PM
smarttap/3 blink, anyone buy these? ermagawd CANADA 5 03-02-2017 08:46 PM
