| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#15 |
Drives: Crapcan
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | Code Monkey (08-16-2018) |
#16 | |
What's your front camber set at currently with the camber bolts?
Instagram: @spike.grc
#17 |
Drives: World Rally Blue
The wheels say the offset is 35 on them, so I'm pretty sure.
| The Following User Says Thank You to Nurnburger For This Useful Post: | Code Monkey (08-16-2018) |
#18 |
Drives: Crapcan
#19 |
Drives: FR-S Turbo
That's what I'm thinking.
Pull one off and check the markings on the wheel itself. If it says +35, I would be tempted to grab a carpenter's level and measure them to verify. Did you buy them brand new? If used, it is possible they were shaved down by the prior owner - some ppl do re-machine wheels. |
| The Following User Says Thank You to Turbo For This Useful Post: | Code Monkey (08-16-2018) |
#20 |
Drives: FR-S Turbo
I just can't understand the probs you are having -again- I had 255/40R17 RS4's on a 17x9 +35 rim without any rubbing at all with a 100% stock suspension. It was close - maybe 2-3mm of room when at 27/28 psi and cold (which gave me 34/36psi hot on track) but I didn't rub.
That's 10mm more rubber than you have, so something isn't adding up. |
#21 | |
Drives: Crapcan
| The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post: | strat61caster (08-17-2018), wparsons (08-17-2018) |
#22 |
Drives: FR-S Turbo
#23 |
Drives: Whiteout FRS
^this. If you get a camber plate instead, it will move the whole strut inwards instead of the knuckle itself. The knuckle will stay in the same place. I'm pretty sure if you make the camber bolts positive, you'll gain clearance at expense of not having negative camber and looking weird.
#24 |
pessimistic skeptic
I have 17x8 +40 wheels with 245/40 tires. They have no rubbing with zero camber. But the clearance is about 10mm.
You have (25.4/2 - 5) 7.7 mm less clearance than my setup plus negative camber. If you reset to zero camber you might be able to clear without hardware change but it will still be very close. |
#25 |
I had 17x8 +45's with 225/45/17's and -2.2* of camber added at the knuckle with no rubbing. 17x9 +35 with 245's should only be about 2mm closer to the spring seat.
#26 |
Drives: 2015 FRS - FFR GTM
[QUOTE=Turbo;3122488]Nice to meet a fellow FFR'r here. I'm building an FFR roadster![/QU
It's been on the back burner for a while,,, doing a swap on the FRS.
2015 FR-S - One Day I'll Finish The Swap |
#27 |
I finally got my car aligned today, which helped shed some light on the issues. It turns out that I had -2.5 deg camber in the front! That would definitely cause it to be much closer to the strut.
I had put 3mm spacers to get it to clear on the way to the shop, but I'm thinking I'll take those out now that I have a lot more clearance. On a side note, it was mentioned to me by the shop that I shouldn't use OEM lug nuts with aftermarket wheels. Apparently "normal OEM" nuts are rounded, whereas aftermarket wheels have conical seats. My understanding is that the BRZ stock lug nuts are conical, so I should be good, but wanted to make sure. |
| The Following User Says Thank You to Nurnburger For This Useful Post: | NoHaveMSG (08-30-2018) |
#28 | |
Wheels for Brains
Not all factory lug nuts are tapered like the FRS/BRZ lugs, which is why the shop mentioned it. It still might be worth getting aftermarket lug nuts since the OE lug nuts don't have a seat/ledge on which a socket can rest. Basically, you'll be resting the socket right on the wheel risk rubbing them if you're not careful. |
| WTB: 17x9 wheels and tires, +42-46 offset | luchadorjose | Want-To-Buy Requests | 2 | 05-02-2017 04:39 PM |
| 17x9 TR Motorsports wheels with conti tires | APEXIT53 | Brakes, Suspension, Chassis | 3 | 03-27-2017 12:17 PM |
| Looking for 17x9 Autocross Track wheels and tires | paintdude258 | Want-To-Buy Requests | 2 | 03-17-2016 08:30 PM |
| Any rubbing issues with 17x9.5 +40 wheels and 255/40/17 tires? | Eazy-V | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 14 | 11-02-2014 10:42 PM |
