Old 08-10-2018, 07:29 PM   #1
brzultra
Drives: 2014 BRZ
have stock 2014 brz, will lighter wheels improve mpg?
I read stock 17" wheels are about 20lbs.
Kosei or others are 16lbs.
Will I get better mpg and handling converting to lighter wheels?
brzultra is offline   Reply With Quote
Old 08-10-2018, 07:39 PM   #2
DaSilva3525
Drives: 2013 Brz
Absolutely, how much though depends.. may be miniscule or noticeable depending on which wheel. At least a 3-4 lb reduction per wheel would be on the higher scale and I would say minimum needed to get a noticeable difference for 17" wheel.
16's you can find 15-17 lbs fairly easy for a fair price. I bought a pair of 16x6.5 BBS's (from the old B spec legacy) 15lbs a wheel.
Tire weight plays a roll as well. With the 16" your tires will weigh more and bringing the
balance closer once again.
DaSilva3525 is offline   Reply With Quote
Old 08-10-2018, 08:10 PM   #3
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
Yes but tire weight is more important since the weight on the outside is harder to move.
I went with 17" Konig hypergrams at 16.5lbs,
Hankook evo II's in stock size at 19lbs, stock tires are ~21lbs
Very noticeable off the line acceleration and it cruises much easier
SuperTom is offline   Reply With Quote
Old 08-10-2018, 08:56 PM   #4
swarb
Yes, but whatever you gain from lighter wheels, you will lose from not running low rolling resistance tires, which the stock tires are.
Old 08-10-2018, 09:10 PM   #5
DaSilva3525
Drives: 2013 Brz
Old 08-10-2018, 09:44 PM   #6
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
who says he can't run lrr tires that are lighter? Heck he could even run the stock tires, because they really are not as bad as people on here make out.
why? is offline   Reply With Quote
The Following 4 Users Say Thank You to why? For This Useful Post:
Adam_L (08-13-2018), Busybee (08-11-2018), rcm47 (08-10-2018), ~el~jefe~ (08-02-2019)
Old 08-10-2018, 11:25 PM   #7
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
All depends how much of a lead foot you have.
Also depends how long of a reset your in dash mpg calculator has been active.
Also depends how clean your mass air flow sensor/air filter is.
Also depends on driving conditions/up hills, down hills.
The Following User Says Thank You to Mr.ac For This Useful Post:
Adam_L (08-13-2018)
Old 08-10-2018, 11:59 PM   #8
SuperTom
SuperTom's Avatar
good point the stock tires are meant to be "green" from a prius. So keeping stock tires with light wheels would be best for economy. For performance and still good economy you can get lighter grippier tires (hankook evo II)
Old 08-11-2018, 12:25 AM   #9
extrashaky
Drives: 2014 BRZ Limited
I installed RPF1s and went from 31 MPG to 25 MPG.
BUT they were 18" x 9.5", and I wrapped them in Pilot Super Sports. So the moral of the story is that the width and stickiness of the tires is going to have a lot more effect on fuel economy than the weight of the rims.
The Following User Says Thank You to extrashaky For This Useful Post:
Yardjass (08-11-2018)
Old 08-11-2018, 01:29 AM   #10
conehead
Drives: RS 2.0
Technically yes, practically no. Definitely not any measurable amount. IF you are getting new wheels anyway, you might as well lean toward the lighter ones. They will help acceleration, braking, handling, ride, and efficiency to a very tiny degree.
conehead is offline   Reply With Quote
Old 08-11-2018, 02:46 AM   #11
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Yes.
Depending on material and manufacturing.
May break a few on potholes or speed bumps.
How much $ you have to throw around?
Old 08-11-2018, 08:20 AM   #12
JSube
JSube's Avatar
Drives: 2017 ISM PP BRZ
Lighter Wheels
Stay with 17s, a bit wider if you like won't matter much, and maybe your mpg will improve! Who cares! (I see this your first post, please don't take this as being flamed.)
Any weight savings on a car will result in improved mileage, because math, but it won't be significant. The benefits when you save 6 lbs or so of unsprung weight per wheel is a noticeable (to me) improvement in sharper handling and spinning up the rear tires. It's a net gain in fun.
And don't worry about breaking most lighter wheels on potholes, you're usually paying more $$ for the lightness and manufacturing processes are superior. Enkei RPF1s, Kosei, 949 Racing, Apex, O.Z. etc. use low pressure casting and some version of flow forming and are very durable. You're much more likely to break a Chinese 25 lb. gravity cast POS wheel in daily use.
Raceseng Circuit Sphere 100 shifter arm, Radium catch can and master cylinder brace, Perrin oil cooler, Vorshlag front camber plates, ACE A350 header & overpipe, Berk catted front pipe, CSGxMXP exhaust, Delicious NA Stage II tune & Flex Fuel
JSube is offline   Reply With Quote
Old 08-11-2018, 09:34 AM   #13
Ernest72
I lost 3lbs per wheel and have not seen any noticeable change in mpg.
Old 08-11-2018, 11:32 AM   #14
GrantedTaken
Stop.
Just stop.
GrantedTaken is offline   Reply With Quote
The Following User Says Thank You to GrantedTaken For This Useful Post:
FRSBRZGT86FAN (08-11-2018)
Need advice to improve stock setup maregt Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 02-12-2018 07:11 AM
How much benefit are lighter wheels rotational mass wise Sportsguy83 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 01-05-2015 09:34 AM
Should I dyno tests after installing lighter wheels? makesdrivingfunagain Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 25 06-10-2014 05:17 PM
Increased whp by having lighter wheels mechaghost Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 26 07-03-2012 01:46 AM
What return from going with lighter wheels? bazguitarman Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 30 06-01-2012 10:35 AM
