Old 07-12-2012, 08:08 PM   #407
Synack
Boosted
Synack's Avatar
Drives: Sideways
Originally Posted by slow_frs View Post
That defeats the no cut install for this kit.... Also why are peoPle pressed for a ram or cold air into the turbo, it's still going to be performing he same after the intercooler and as far as ram air, you can't ram air into a turbo lol
THANK YOU! Ricers...... lol jk
Synack is offline   Reply With Quote
Old 07-12-2012, 08:20 PM   #408
Coheed
Coheed's Avatar
Drives: DGM BRZ Limited
Wrong. PV=nRT. Meaning a higher intake temperature will increase the volume of the air, making it less dense prior to being compressed. The intercooler helps to increase it's density AFTER it's been compressed. The compressor's efficiency is still impacted by intake temperatures and pressures.
So the 2nd part, pressures. Ram air can work on a Turbo. Any increase in pressure before the compressor will reduce the operating pressure ratio that the compressor operates at. This reduces compressor speed, increases efficiency, and decreases delta temperatures for the same PSI.
Coheed is offline   Reply With Quote
Old 07-12-2012, 08:33 PM   #409
Don@Accelerated
Don@Accelerated's Avatar
Basically all buttoned up. I'm out of town for the weekend so testing on the dyno begins on tuesday it looks like
John from Visconti tuning will be doing the ecutek setup. All tuning for this kit will be bought via him for the ecutek items.
Don@Accelerated is offline   Reply With Quote
The Following 12 Users Say Thank You to Don@Accelerated For This Useful Post:
armythug (07-14-2012), blackfireball5 (07-13-2012), boarder1995 (07-13-2012), Chewie4299 (07-13-2012), civicdrivr (07-13-2012), cobrabyte (07-12-2012), LivingLegend (07-12-2012), MannyO (07-12-2012), os86 (07-12-2012), slaxx (07-13-2012), SVTSHC (07-18-2012), white devil (07-17-2012)
Old 07-12-2012, 08:34 PM   #410
Don@Accelerated
We've done all that stuff in the past. It takes a very large opening to cram anything in. We use that on our Drag Supra and its affects are minimal and that car is 2200hp.
The Following User Says Thank You to Don@Accelerated For This Useful Post:
slow_frs (07-12-2012)
Old 07-12-2012, 08:35 PM   #411
LivingLegend
Drives: 1994 Toyota Tercel
Can't wait to see it on the dyno!
LivingLegend is offline   Reply With Quote
Old 07-12-2012, 08:38 PM   #412
slow_frs
Drives: turbo scion tc
Where did you end up returning the oil to
slow_frs is offline   Reply With Quote
Old 07-12-2012, 08:43 PM   #413
os86
Drives: 2jz
thats amazing ! well done
os86 is offline   Reply With Quote
Old 07-12-2012, 08:46 PM   #414
helloimgil
helloimgil's Avatar
Drives: 13 Whiteout / 09 R6 [BRZ is gone!]
....anxious for the dyno
helloimgil is offline   Reply With Quote
Old 07-12-2012, 08:57 PM   #415
Visconti
Drives: 05 STi
Can't wait !
Visconti is offline   Reply With Quote
Old 07-12-2012, 08:59 PM   #416
spyke
spyke's Avatar
Drives: 2013 BRZ LTD
Incredibly impressed with this project! I just discovered this thread today and can't believe how much of my life I just spent reading 19 pages of posts. I look forward to hopefully being one of your first customers :-)
spyke is offline   Reply With Quote
Old 07-12-2012, 09:07 PM   #417
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
Well done sir! If tuning is starting tuesday, i believe we can hope for numbers by friday...i hope lol
Silverdub is offline   Reply With Quote
Old 07-12-2012, 09:07 PM   #418
GirlyScions
Drives: Mazda3
Looking great Don!!
I have this feeling your going to give us a little tease of how much boost you were running under the hood this afternoon before you share the numbers on tuesdays dyno.
GirlyScions is offline   Reply With Quote
Old 07-12-2012, 09:38 PM   #419
Don@Accelerated
Thanks for all the Warm encouraging thoughts. We'll have dyno numbers on tuesday. Either it blows up or it does something!
phillip (07-13-2012)
Old 07-12-2012, 10:12 PM   #420
Coheed
Coheed's Avatar
Strange you saw minimal gains. I saw in the neighborhood of 2psi more boost worth of power from my testing. Of course, this was datalogging off the dyno using a virtual dyno from MAF voltage increases. The gains I saw increased nearly linear as vehicle speed increased. I collected awesome data from several tests I was able to do, including elevation tests. Good stuff.
accelerated performance, brz forum, brz forums, brz turbo, brz turbo kit, fr-s turbo, fr-s turbo kit, frs turbo, frs turbo kit, scion fr-s turbo, scion fr-s turbo kit, scion fr-s turbocharger, scion frs turbo, scion frs turbo kit, scion frs turbocharger, subaru brz forum, subaru brz forums, subaru brz turbo, subaru brz turbo kit, subaru brz turbocharger
Accelerated Performance 2013 BRZ Intake Dyno Testing Video Don@Accelerated Engine, Exhaust, Transmission 109 05-17-2013 12:24 PM
Accelerated Performance 2013 BRZ Exhaust Systems Don@Accelerated Engine, Exhaust, Bolt-Ons 135 09-04-2012 12:24 AM
Accelerated Performance 2013 BRZ/FRS Exhaust Systems Don@Accelerated Engine, Exhaust, Bolt-Ons 24 07-07-2012 08:05 AM
Hello from Accelerated Performance! Don@Accelerated Announcements, Contests, Giveaways 5 07-04-2012 09:14 PM
