Old 05-14-2018, 08:41 PM   #3585
gutbuster
Drives: 13 FR-S
Bilstein B6 with Raceseng CasCam top plate
If I use B6 struts with RCE Yellows and Raceseng CasCam top plates with the thrust bearing upper spring perch, will the "stack height" be different than the OEM top mount, resulting in something other than the nominal 20mm ride height reduction at the front?
Former rides: 78 Scirocco, 80 Corolla, 79 Celica, 91 CRX, 90 CRX-Si,02 GTI, 87 944s, 86 911 3.2 Carrera, 03 MR2 Spyder
gutbuster is offline   Reply With Quote
Old 05-26-2018, 09:23 AM   #3586
DeaconRoc
Drives: GT86
I am running Moton Clubsport suspension. I recently fitted a set of Voodoo 13 LCA's which effectively lower the rear of the car 18mm as I was lowered around 40mm and wanted to regain 18mm of bump travel. However, now I've fitted the Voodoo arms I seem to have lost most of my droop travel as I've had to raise the rear dampers spring platforms right up to try to return to the around 40mm lowering I had before I fitted the arms.
I'm not entirely happy with this setup as the limited droop travel means I fear I will now top out rather than bottom out the damper.
I presume the issue is that the Moton dampers must be shorter than OEM and so already lower the car meaning the addition of the Voodoo arms has now lowered the rear too much. Am I right or am I totally on the wrong track? I'm presuming a return to the oem arms may be my best option?
I've added a picture below showing how the arms are sat currently with the car lowered around 45mm.
Any help would be much appreciated
Sent from my ONEPLUS A3003 using Tapatalk
DeaconRoc is offline   Reply With Quote
Old 06-12-2018, 12:01 PM   #3587
vtekdis
Drives: 2013 BRZ Premium
Hi guys need some advice on how to properly tune my shocks (rebound/compression) with current setup for autox. Alignement changes, different sway bars etc. recommendations are also welcome.
Current alignment
-2.5F -1.5R camber
slight toe out F
slight toe in R
caster within OEM range
KW V3 4k/5k F/R
1.2in drop F/R
stock swaybars
17x9 +35
245/40/17 RE71R
Rear LCA Whiteline
Raceseng Camber Plates
vtekdis is offline   Reply With Quote
Old 06-26-2018, 10:41 AM   #3588
Calum
That Guy
Drives: 2013 asphalt FRS MT
I've got about 15k kms on my T0s now, all street driving. I'm wondering how often I should have them re-corner balanced? Or if that's only an adjustment that I would make if I notice an issue?
Old 06-26-2018, 11:39 AM   #3589
redhalo
Drives: MY20 Hakone Toyota 86
I've got Tein Flex Z's that make clunking sounds in the front when slowely driving forward or reverse. I'm lowered at about 2" and have read that the clunking may just be the nature of some coilovers or that the end links could be binding due to being that low. Any advice on end links that may resolve the sound? I'm not tracking the car, just spirited street driving, so I don't think I need anything too high end.
redhalo is offline   Reply With Quote
Old 06-26-2018, 12:11 PM   #3590
Pat
Pat's Avatar
Drives: 2023 BRZ
It could be a few things. You may just want to bring it to a trusted mechanic.
Old 06-26-2018, 07:31 PM   #3591
redhalo
I have.
Old 06-26-2018, 09:14 PM   #3592
cjopant
cjopant's Avatar
Drives: 2015 Subaru BRZ
I'd love to understand how to reduce how much my ride height sags with weight fluctuations. If I have a full tank of gas and a trunk full of jerry cans, the ride height in the rear will be noticeably lower. Is this a result of soft springs?
Here's my setup in part:
  • KW V3 Coils - (Not 100% on the spring rate, but they're from 2017 so I think they're 230/285)
  • -2.5 camber all around on Verus plates
  • 18x9.5 +38 wheels w/ 255/35R18 MPSS
  • Verus rear control arms
  • Verus rear toe arms
  • Pretty low - less than a finger gap all around
  • Pretty stiff - I recently had the rear compression stiffened in an attempt to stop the sag (and subsequent rubbing), but it's not really working and the ride is now a little too harsh for the street.
Here's a pic of how it's currently sitting. I'll likely raise it up a bit, and go back to my previous compression settings but I've had this problem (and rubbing) at higher ride heights too.
Are my springs too soft?
Am I feeling the 2mm difference between my +38 setup and the +40 that most other folks seem to run?
Am I too low? (probably?)
Any guidance would be greatly appreciated!
cjopant is offline   Reply With Quote
Old 08-04-2018, 12:06 PM   #3593
Trueweltall
Trueweltall's Avatar
Drives: 2016 Subaru BRZ
Is it possible to get 0 toe with -1.0 camber in the rear with just SPC LCA's without having to install the toe bushings? Car has a 15mm drop. Pretty sure alignment guy at Firestone is a moron.
Trueweltall is offline   Reply With Quote
Old 08-04-2018, 02:12 PM   #3594
Racecomp Engineering
You can check to see if your ride heights are the same as they were 15k kms ago but you should be okay.
- Andrew
Calum (10-12-2018), wparsons (01-08-2019)
Old 08-04-2018, 02:13 PM   #3595
The change in ride height due to changing weight is a function of spring rate.
Changing compression settings will not affect this in any way, so don't do it for that reason.
Your car looks a little low IMO.
- Andrew
Old 08-04-2018, 02:14 PM   #3596
You might want more than -1.0 rear camber.
- Andrew
Old 08-04-2018, 02:36 PM   #3597
Trueweltall
I have -1.6 right now but the toe is 0.18, is this acceptable? Fronts all fucked up with FL -1.1 and FR -0.5 and a toe that has the steering wheel crooked to go straight.
Old 08-06-2018, 11:06 AM   #3598
-1.6 camber is acceptable, that toe is not.
- Andrew
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 04:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 06:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 09:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 07:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 11:13 AM
