#211 |
Drives: 1949 UFO
Not sure about 32bit but there is a hack for the W10 64bit. That’s what I’m running. Search online you will find it.
#212 |
Drives: Toyota 86 2017
#213 |
Why do you need it to work on Win10-32? It's not hard to get it working in Win10-64. What cable do you have? I had a cheap Mini VCI cable and with some registry changes (moving some keys from \SOFTWARE to \SOFTWARE\WOW6432Node) it worked fine on Win10-64. Now I have a Tactrix and the installer for it's drivers put the registry entries in the correct place so you don't have to mess around to get it to work.
#214 |
Drives: cool
#215 |
#217 |
13.30.018 is the latest
| The Following User Says Thank You to ermax For This Useful Post: | Gunman (03-13-2019) |
#219 | |
https://www.tactrix.com/index.php?op...ed=1&Itemid=53 |
#220 | |
Drives: White series.blue / CWP tS
I am using this cable and it is firmware ver. 1.4.1. When I run the Xhorse firmware update tool, I get the status as "connected" https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 When you say "moving some keys from \SOFTWARE to \SOFTWARE\WOW6432Node) it worked fine on Win10-64" What exactly are you doing with this? I made sure the registry file matched the one that was in the guide I was following, added it to the desktop and "merged" it successfully. Thanks!! |
#221 |
14.00.019 is the latest now.
You can always see what the latest version is by going here: https://techinfo.toyota.com/techInfo..._features.html |
#222 |
Drives: 2013 Subaru BRZ
Any mirror links for the drivers and software? It seems dead.
#223 |
Drives: 2013 Scion frs
I have an ECU that has no VIN associated to it. I bought a tune from Delicious Tune and now I can't use it because the car has no VIN in the ECU.. Can I use Techstream to put a VIN on the ECU??
#224 |
My old Delicious tune had no vin attached to it, so I'm having this exact issue, how did you resolve it?
| TPMS Tools | developer | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 27 | 10-04-2021 02:28 PM |
| anyone with a shop or tools | Tylub | Southern California | 0 | 05-14-2013 12:03 PM |
| Tools? | Gost | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 35 | 04-03-2013 04:46 PM |
| Tools for DIY maintenance? | F1point4 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 19 | 08-08-2012 08:47 PM |
