Old 06-21-2012, 01:04 AM   #1
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
Wheel Directory: Kosei K4R 17x8.0 +36
Had 215/45-17 Kumho XS installed on 17x8, +36mm offset Kosei K4R's this past Tuesday. I originally planned to go with Hankook RS-3's (as I've run them before) but decided to try the Kumho's as they are noted as being just about as good but weigh less and cost less. Before I installed the wheels I weighed them with my bathroom scale and they showed 15.6 lbs difference between just me and me+wheel. Wheel and tire combo should be under 37lbs. This will primarily be my track setup (which I'm going tomorrow, 21st), will use the stock wheels normally (until I can find a deal on some Enkei RP03's...)
I will say I like the fit of the Kosei/Kumho combo and man what a difference in feel when driving the FR-S... with traction control all off I cannot break traction with them daily driving and the car is much more neutral. Steering is as quick as ever and the car just points and goes without any noise. Should be really great on track!
On to the Pictures!
Vracer111 is offline   Reply With Quote
The Following 18 Users Say Thank You to Vracer111 For This Useful Post:
Bimble Bamble (03-05-2015), cyde01 (06-21-2012), Dr.Science (11-12-2012), DylanFRS (11-26-2013), Exhaust (07-08-2012), Fly Guy (06-21-2012), g0lden (09-26-2013), Guff (06-21-2012), karbon (07-30-2012), karma003 (04-03-2013), Laika (06-23-2012), lokvo (07-22-2012), LostSalad (03-26-2015), Nasty Sausage (06-02-2014), normancw (07-08-2012), red_comet (01-18-2014), TheLaughingMan (01-12-2014), ultra (07-08-2012)
Old 06-21-2012, 02:19 AM   #2
Vracer111
Vracer111's Avatar
Originally Posted by cyde01 View Post
looks real nice! are you happy you went with 215 as opposed to a wider tire?
Yes, I wanted to try the stock size stretched to its maximum recommended wheel width application and because this is about as light a wheel/tire combo as you can get. May go up in tire size when time for new tires, but it will be at degradation of responsiveness in comparison to this setup and a 3-4lb weight inrease per tire. Tire compound and weight is more important than width...
Old 07-09-2012, 09:07 PM   #3
Vracer111
Vracer111's Avatar
Originally Posted by Enigmus View Post
How was the track event with the new tires?
See the thread I made about it: http://www.ft86club.com/forums/showthread.php?t=9579
Originally Posted by evil_1998
Nice lightweight wheels...Any rubbing issues with this setup?
None whatsoever with the 215/45-17 Kumho XS tires....
Originally Posted by mpicher
215's on a 17x8? Did you mean 17x7?
No, they are 17x8 wheels with +36mm offset... as schtebie said 215/45-17 are designed for 7-8" wheel fitment. 215/45-17 Kumho XS's are wider than the stock Michelins; the tread is 7.9" wide - which is just about perfect for a 8" wheel.
Originally Posted by ultra
Where'd you buy them? Tire rack?
Yes, I purchased them from Tire Rack.
Originally Posted by dwx
Good to see something as low offset as +36 fits in the front. I would still have gone with a 225 or 235 tire on the 17x8 rims. I don't think you would have lost any responsiveness really.
What exhaust is that? It looks custom made or like the stock exhaust with no tips...
I was wanting to get the "limited budget" lowest weight setup and wanted as light a weight tire as possible so 215/45-17 it was. As for the exhaust, yes it's stock with the rediculous US tips taken off...it will be like this until I get a catback system for it, which will be the SRT catback setup once it's released.
Originally Posted by Apex Chase
I like that a lot. Time for some lowering springs.
I would like to get the RCE suspension kit (20mm drop), but honestly the stock suspension is soo good I can hold off on that for a while. I'm ok with the stock height look for now. Catback exhaust is probably the most important upgrade for me and will be the first priority....
Originally Posted by chulooz
I think the rims would look mint if finished with center caps, but the tires are too stretched for my taste/goals.
Looks better without the caps to me, the Kosei caps are too Blingy.... Tires are hardly stretched that much being the tread is nearly 8" in width.
Originally Posted by jeebus
nice to see someone that knows how NOT to ruin the balance of this car. You shaved a few pounds off each corner from stock, got a bit more footprint and track. Good work!
That was the goal...to make it easier on the suspension and improve handling for track duty. It's one of the few lightweight wheels that has a decent offset (45-48mm is just not enough for a 8" wide wheel) and I wanted a sticky and wider 215/45-17 tire that had around an 8" tread width. Instead of changing tire size I'll just up the compound to DOT-R tires if I need to go faster (will also be lighter as well....)
The Following 3 Users Say Thank You to Vracer111 For This Useful Post:
aqua8701 (05-04-2013), Laika (07-09-2012), SuperTom (01-21-2020)
Old 07-09-2012, 09:42 PM   #4
Metallic BRZ
Metallic BRZ's Avatar
Drives: 1992 Corvette Z07
I just ordered my set Though it would have been smart to wait until I had the car
1992 Z07 Corvette
2008 Odyssey
2013 BRZ
Metallic BRZ is offline   Reply With Quote
Old 07-09-2012, 09:55 PM   #5
Smudgeous
Smudgeous's Avatar
Drives: 2013 WRB 6MT BRZ Ltd.
Quite interesting how similar your goals are to my own. I've been eyeing the same wheels, just ordered that exhaust, and waiting for the same springs (via the kit) to be orderable.
Smudgeous is offline   Reply With Quote
Old 07-09-2012, 09:57 PM   #6
ft86Fan
ft86Fan's Avatar
Drives: FR-S, Exige S, Miata
This is interesting. TireRack only had the 17X7 +50mm before and that only weighs 14 lbs. Now they added the 17X8 +36mm that weighs 15.8 lbs. Which one to get?
For the OP, wouldn't the 17X7 be a better choice if you are sticking with the 215s? Also, do you think there will be rubbing with wider tires on the 17X8 with the more aggressive offset? What about TPMS? Did you mount them on the new wheels?
I'm thinking getting the 17X7 with 215s for the street and 17X8 with wider tires for the track.
'13 Scion FR-S (Whiteout)
'07 Lotus Exige S (Aspen White) Touring, Traction, Starshield
'95 Miata (Montego Blue)
ft86Fan is offline   Reply With Quote
Old 07-09-2012, 11:03 PM   #7
Vracer111
Vracer111's Avatar
I was actually looking at wheels before I got my FR-S...but Tire Rack didn't have their wheel viewer working then and there wasn't much selection. I just wish the K4R's came in silver...would look a lot better on a darker car. On a lighter color those the K4R's would definitely look sweeter!
Yeah, with the suspension as good as it is stock, priority one is getting a proper exhaust on the car... because that's the worst thing about the FR-S...I'll be prototyping a custom intake myself.
Depends on tire...I like Kumho and Hankook tires, which have 'softer' sidewalls. If you put them on the max width tire they are designed for the ride quality really comes out in them along with the handling. 225 or 235 width tires should fit fine with this offset...personally I don't think I'd ever go beyond 225 width for the FR-S. Did not mount TPMS to the Kosei's - no reason for track wheels to have TPMS valves...
I'm actually looking at lighter weight 16x7.5" wheels with 205/55-16 tires for possible dailies - even lighter than the track setup; imagine a 34lb wheel/tire combo...
The Following User Says Thank You to Vracer111 For This Useful Post:
lucchesi423 (09-15-2012)
Old 07-11-2012, 07:04 PM   #8
ft86Fan
ft86Fan's Avatar
Thanks OP. Just picked up my Whiteout FR-S today so its almost that time to buy wheels
Yeah, I won't put TPMS on my aftermarket wheels even if they are for the street but did you encounter any issues without them besides the dash light coming on? I've heard people say that on some cars without TPMS, the ECU will prevent traction/stability control to be turned off.
So you think 17X8 +36mm should be ok with 225/45-17? The only problem is that it is 0.4" larger in diameter. 235/40-17 is only 0.2" smaller in diameter but not sure how well they will fit with that offset.
Old 07-11-2012, 09:18 PM   #9
Vracer111
Vracer111's Avatar
No issues with TPMS light being on at all... It was run on track like that and handled brilliantly (as long as all aids were turned off - forgot to turn off the traction/stability systems before starting my last track run session and man was it annoying (ABS pulsing for no good reason and power cutting out a few times....) Make sure everything is off when running on track!
I'm sure 235/40-17 would work without any issue - Racecomp Engineering is running 245/35-18 tires on 18x8 wheels with +38 offset with no issues, plus they are lowered 20mm. I just don't want to add the extra weight of the wider tires...
Old 07-12-2012, 10:13 PM   #10
Vracer111
Vracer111's Avatar
Originally Posted by ft86Fan View Post
Wow, the lights didn't even come on without TPMS on the new wheels. Thats great. Thanks.
No, the light was on (comes on after about 21 miles in a single trip), but there was no issues with it being on - everything functioned as normal. I guess I didn't say it clearly in the original post and you mistook that for the light didn't come on...
Cheddar...here's the wheels on Tirerack:
K4R
ft86Fan (07-13-2012)
Old 07-15-2012, 10:38 AM   #11
Trettiosjuan
Drives: GT86
Originally Posted by mike2100 View Post
Those are perfect; well done! Who says you can't have form and function? Now I wonder what they'd look like on a silver car...
+1! I'll have exactly these on a Silver GT86, should look good IMHO
One question: does the added track width affect the steering feel? Less pure but more feedback?
Trettiosjuan is offline   Reply With Quote
Old 07-15-2012, 08:15 PM   #12
Vracer111
Vracer111's Avatar
Steering feel is much the same to me, though it's definitely a little sharper/quicker than stock because you have 215/45-17 tires stretched on 8" width wheels.
Old 08-26-2013, 12:34 AM   #13
jiffyjhn
Drives: White FR-S kosei k4r 17x8
Hi
I'm new to the forum. Just got my K4R 17x8 +36mm with 225/45/17 Michelin Super Sport installed. Was going to get 17x8 RPF1s but I liked the look of this better and same weight.
Here is some picutures on stock heights. Getting carbon center caps soon.
jiffyjhn is offline   Reply With Quote
The Following 9 Users Say Thank You to jiffyjhn For This Useful Post:
Bimble Bamble (03-18-2015), Fly Guy (10-24-2013), GTHachiRoku (09-05-2013), Pseud0logik (05-24-2014), red_comet (01-18-2014), ShoShin (08-26-2013), SuperTom (01-21-2020), TheLaughingMan (01-12-2014), Vracer111 (09-12-2015)
Old 03-08-2014, 05:24 PM   #14
UMB FR-S
UMB FR-S's Avatar
Drives: Ultramarine Blue FR-S
kosei k4r in 17x8 with +36 offset
245 tires on them
-- Kenny
"I don't always use heel/toe, but when I do it's because racecar."
UMB FR-S is offline   Reply With Quote
Wheel Directory: XXR 527 17x8.25 +35 MF_DEUCE Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 41 12-25-2019 07:37 PM
Wheel Directory: XXR 535 17x8.25 +35 PineappleFriedRice Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 32 10-24-2014 09:27 PM
Wheel Directory: OEM VW Corrado (BBS RSM) 17x8.0 +35 koevasi Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 01-02-2014 02:08 AM
Wheel Directory: Advan TC II 17x8.5 +45 driver01 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 01-08-2013 03:45 PM
Wheel Directory: XXR 522 17x8.0 +48 STEVEOSTI Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 12-13-2012 01:39 AM
