Old 07-12-2012, 04:33 PM   #3949
Snoopyalien24
Mr. Sarcasm
Snoopyalien24's Avatar
Break a leg!
Hmm what do you think? Imagine it black glossy
Jaguar Inspired
Not bad for 30 minutes
Snoopyalien24 is offline
The Following User Says Thank You to Snoopyalien24 For This Useful Post:
Giccin (07-12-2012)
Old 07-12-2012, 04:39 PM   #3950
SVTSHC
(ノಥ益ಥ)ノ
SVTSHC's Avatar
Drives: 2015 Series Blue BRZ
Originally Posted by Want.FR-S View Post
Just chime in on opening the vent idea. If you cut through the sheetmetal, how are you going to solve the issue that the water/rain/snow may be getting into the engine bay area? It seems that you need some water/weather proofing pipe first to solve this issue, or maybe this is a non-issue.
Just curious.
Like Guff said water gets in the engine bay all the time, it doesn't cause any problems unless you've got exposed things that aren't supposed to be exposed. I've taken a hose to my engine bay numerous times with and without the car running.
"Sweet Subaru, sweet Subaru, send your BRZ unto me, for the roads of the unworthy must be baptized in speed and glory." ~Zaku
SVTSHC is offline
Old 07-12-2012, 04:40 PM   #3951
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Jaguar Inspired
tweak it a bit more. Make that black line follow end to end and follow top of the door line to flow smoother. Also the vent follow the piece & A pillar
Sorry, I'm a perfectionist
But other than that, I think you're in right direction
ichitaka05 is offline
Snoopyalien24 (07-12-2012)
Old 07-12-2012, 04:43 PM   #3952
Snoopyalien24
Mr. Sarcasm
Thanks I will do
ichitaka05 (07-12-2012)
Old 07-12-2012, 05:06 PM   #3953
Snoopyalien24
Mr. Sarcasm
Hmm different attempt, tho I know it still needs a bit more tweaking
Old 07-12-2012, 05:10 PM   #3954
M-17
Ninja Cat Mod
M-17's Avatar
If you take the whole Fender Vent piece off, do you access to the bay? Or is it sheet metal?
If we have to cut sheet metal, then it might be a bit too much work for something as simple as a vent... Although, I really want it to be semi-functional too...
Maybe I'll run a intake breather tube from it for when I drive in rivers....
Haha, yeah but you see what I'm getting at.
Or wanna do like BMW style?
Sort of. I just think why should the BRZ just get some oridinary vent and not have its own signature vent like the FRS. So yeah I'd like to go down this path and make that change, whether its BRZ related or my own signature piece.
Hmm you all have inspired me to go and draw out a fender vent..
BRB going to try it out
:happy0180:
I wanna say that its a Non-issue because water does often get in under the hood, and there shouldn't be much that it can mess up... But it would def. have to be covered properly like any other vent (Think STi Hood scoop, it has a mesh, I believe). And we also need to determine what purpose it would serve other than to save the embarrassment of being called out on your fake vent...
you get this
It would take some cutting but it certainly looks doable....
Yeah, so there could be a functional vent there and a non functional for those whom are afraid of clutter or water getting into the engine bay, but want something different. So as you said this is can be done.
Jaguar Inspired
Thanks for taking time out of your day and putting something together. It came out nice and that's one idea I have in the back of my head. I would however make a few adjustments to it though.
I should get some lessons on PS from you.
M-17 is offline
Old 07-12-2012, 05:13 PM   #3955
Snoopyalien24
Mr. Sarcasm
:happy0180:
Thanks and np. Try checking out my second attempt, maybe you'll like that one better
I'm using a mouse w/ no drawing skills on my plate so I dont think it came out too bad
Old 07-12-2012, 05:13 PM   #3956
Want.FR-S
Want.FR-S's Avatar
Drives: 4 Wheels Auto
What do you mean? Sheetmetal? Are we talking bout same thing?
What I'm talking bout is this... which btw is plastic
you get this
I think we are talking about the same thing. Yes, the top cover piece is plastic but in order to create a real vent, you need some holes to go from the sheetmetal on the fender to the plastic piece. That is why I said we need to cut through the sheet metal. Currently there are only the holes to clip on the piece.
The STI hood scoop is designed with an angle and slope down. Furthermore, there seems to be a little cover on top of the hole so if the car is standing still soaking in rain, the water will not go up into the engine bay. During driving in the rain, there might be water coming into the engine bay. Since I have no experience with STI I do not know if there is any down side with this, or if there is a water catch mechanism or something to prevent water go directly into the bay.
Especially since this is at the side with a degree upward, if you simply drill holes and covers with mesh, there could be water condensation or damage to the sheetmetal in that area.
Originally Posted by Winding Road FR-S review
What is astonishing about the FR-S is that it combines the cruising comportment and function of the 128i with the dynamics of the Cayman, or Boxster, or S2000.
Want.FR-S is offline
Old 07-12-2012, 05:18 PM   #3957
M-17
Ninja Cat Mod
M-17's Avatar
I thought the suggestion Ichi had made was good one, but I'm not feeling that change now that I've seen it. I prefer the first one still. At some point when I can put some actual focus into designing a vent then I'll post my idea(s).
M-17 is offline
Old 07-12-2012, 05:22 PM   #3958
jedibow
post whore extraordinaire
Drives: 2013 Asphalt Grey FR-S 2003 Evo 8
I'm sooooooooooooooo bored!!!!!!!!!!!!!!!!!!!!!!!!
I wonder it the bags under my eyes from lack of sleep, and all the bruises all over my body make me more attractive?
G
Originally Posted by ImAwesome
Great info in here. arghx7 what do you do?
He's obviously a very knowledgable landscaper.
jedibow is offline
Old 07-12-2012, 05:24 PM   #3959
Snoopyalien24
Mr. Sarcasm
Yeah sure go ahead!
And thanks for critizism (in a good way) which helps improve.
Just don't let WoW submit anything, cuz then we automatically lose
Old 07-12-2012, 05:24 PM   #3960
M-17
Ninja Cat Mod
M-17's Avatar
That is something to take note of.
So like I said before there could be a functional and a non functional piece that can be made. In this case what would choose?
Yeah sure go ahead!
Well when i do post a design, I'd like to see it as a render on the BRZ to see if it also goes with the flow. Not sure if it will be more time consuming or a pain in the ass to also make a BRZ in solid works too.
And I guess for criticism, on the first render, I'd change the font mostly, but keep the black following through.
M-17 is offline
Old 07-12-2012, 05:59 PM   #3961
Guff
Now w/ over 400 womprats!
Guff's Avatar
Drives: BRZ LZR
Uh oh... This is in America!
- The Ancient BRZ Sacrament
by Zaku
Guff is offline
Old 07-12-2012, 06:31 PM   #3962
Snoopyalien24
Mr. Sarcasm
NOOOOOOOOO
Well that didn't look like it was his fault
But anyways
How's this guys? I want this
Guff (07-12-2012)
h6 swapouts? any thoughts or advice? f1ver BRZ First-Gen (2012+) — General Topics 53 11-22-2014 12:46 AM
Aspera's thoughts on AWD/RWD... aspera Scion FR-S / Toyota 86 GT86 General Forum 89 11-16-2013 03:55 PM
random casual discussion on dynamic brakes serialk11r Other Vehicles & General Automotive Discussions 4 07-16-2012 10:34 PM
The "if you wanna kiss the backside of white musicians make a thread about it" Thread aliphian Off-Topic Lounge [WARNING: NO POLITICS] 8 12-19-2011 08:59 PM
