#57 |
Drives: Late 2014 Subaru BRZ
2013 rocker spitting issue has been discussed many many times. Subaru has addressed this with revised part numbers. If i recall 2014+ got slightly longer valves and revised rockers so pins stopped popping.
Not much to discuss here or bicker about. @celek is motor god, im sure he can shed more light.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe |
#58 | |
Resident Gear Head
They also went away from 2 separate rocker part numbers between intake and exhaust
Subaru BRZ/FRS Facebook News and Tech Page
My FB Build page CLICK AND LIKE! Twitter and Instagram @misairubrz |
| The Following User Says Thank You to celek For This Useful Post: | GsxrMe (02-21-2017) |
#59 |
Drives: 2017 Toyota 86 (Base)
I know this is an old thread but id like to say i got a 2017 86 with 6k miles on it and the same thing happend while at idle, car was bone stock with no mods at all, i was almost done a cross country drive when it happend. Had a month long battle with toyota to clarify if it was under warranty because they told me it was from "engine neglect" because i had driven 4k miles in the last 5 days before it happend.
Sent from my SM-G950W using Tapatalk |
| The Following 2 Users Say Thank You to NL86 For This Useful Post: | Pat (07-26-2018), Ultramaroon (07-26-2018) |
#60 | |
Seems like Toyota finds anything they can to reject claims. So the 86 has weekly mileage quota now? Give me a break. Good luck! |
#61 | |
Thanks, its been 6 weeks and it finally got done it was a fight though
#62 |
Do you know if the pin walked out, or was it something else?
#63 |
#64 |
Funny how that works. Thanks for trying to get the info from them.
#65 |
Mentat
Drives: 2013 Scion FRS 6MT
Not many service guys really know anything about cars.
| The Following 2 Users Say Thank You to Muaddib For This Useful Post: | ermax (07-27-2018), Ultramaroon (07-27-2018) |
#66 |
Drives: 2015 FR-S
It doesn't take much knowledge to fix cars as it's mostly just take off part and put it back in, it's the diagnosing part that takes skill.
I grew tired of fixing things on my work van recently and took it to a shop to find an issue. $2500 and many parts later they finally figured it out. Of course they broke some parts on the way there that were good when I started and also lost a trans. dust cover but it's running now so I can't complain, right? |
#67 | |
| The Following User Says Thank You to ermax For This Useful Post: | Ultramaroon (07-27-2018) |
#68 | |
![]() humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | Impureclient (07-27-2018) |
| Hole in valve cover | burdickjp | Issues | Warranty | Recalls / TSB | 25 | 11-29-2016 10:37 PM |
| Here's my luck… rocker arm put a hole in the valve cover | -eXpo- | Issues | Warranty | Recalls / TSB | 10 | 09-24-2015 12:58 AM |
| WTB Frs Passenger Exhaust Hole Cover | OMGArisman | Want-To-Buy Requests | 0 | 07-20-2015 01:16 AM |
| Oil Leak from either Timing Cover or Valve Cover | BRZY | Issues | Warranty | Recalls / TSB | 5 | 04-06-2015 09:31 AM |
| Missing Key Hole Cover? | Mrpolarbear | Issues | Warranty | Recalls / TSB | 12 | 08-10-2014 07:24 PM |
