Old 10-13-2016, 02:37 AM   #15
@Art_Mighty
uosɹǝdʎɐl ʇɹǝdxǝ
@Art_Mighty's Avatar
Drives: Asphalt AVO FR-S w/a Slushbox! :P
Originally Posted by Figo View Post
thank you for your thread!
Do you have any suggestion if I only need to swap seat to base FRS but do not need the heating funciton?
Iv heard that the BRZ limited seats are not direct fit. There will be sensor issue?
At least when I did mine they were...
...because some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn
@Art_Mighty is offline   Reply With Quote
The Following User Says Thank You to @Art_Mighty For This Useful Post:
Figo (10-13-2016)
Old 10-13-2016, 12:23 PM   #16
Figo
Figo's Avatar
Drives: Vortech Supercharged FR-S
Hah, that's why I pmed you.
You are probably the only one in the forum who install the BRZ limited seats without any issue. Everyone else has the issue. So I am wondering that did you do anything special? haha.
I'd rather lose by a mile because I built my own car,
than win by an inch because someone else built it for me.
Your car is your story, so don't let someone else write the book.
( White Tiger ) - FiGo's 車誌.
Figo is offline   Reply With Quote
Old 07-22-2018, 07:19 PM   #17
3ndagor
Drives: 15' FRS
I did the swap of seats too ... ( as of all interior as well for fact ) but anyways
got the pressure sensor going off and on ( like it works when someone is seated but I get the code when I'm alone in the car )
any way to clear that code?
thanks for the DYI... I'm heading on to doing this before the winter
3ndagor is offline   Reply With Quote
Old 03-28-2019, 08:13 PM   #18
Twitchy313
Twitchy313's Avatar
Drives: 2014 Scion FR-S
Originally Posted by RojerLockless View Post
*opens the thread* Oh sweet I'd love heated seats! *sees all the pictures of wires* Well.. screw that lol
Twitchy313 is offline   Reply With Quote
Old 08-05-2020, 04:43 PM   #19
Ghostcloak
Drives: 2019 86 TRD SE
Originally Posted by lbroskee View Post
@@Art_Mighty what do you recommend if i can't get the connectors? or would you know the part numbers for them? I'm looking into this but since won't b able to source easily i need to improvise
So. Just in case anyone is trying to find this information still.
The blue male connector attached to the heated seat is a 4 position (090 type) TS series with OEM Toyota part number 90980-11765. The wire harness female white connector side is OEM Toyota part number 90980-11766. It is discontinued. I haven't confirmed with my own experience yet, however I believe the correct female terminal is going to be a 2.3 II (series 090 II) female terminal.
There is also a strong similarity with the Sumutomo TS series part number Conn-100800 and housing Conn-100325. Yazaki 7116-4026 looks to be the same female terminal.
There is a . PDF here that gives some technical info on the two connectors: toyota-tech.eu/wire_harness_rm/RM06H0E.pdf
Ghostcloak is offline   Reply With Quote
Old 09-09-2020, 06:21 PM   #20
Ghostcloak
Parts worked! Confirmed that the heated seats are the same as the rear tail light 4pin connector.
Use:
The Following User Says Thank You to Ghostcloak For This Useful Post:
T-Steve (12-30-2020)
Old 10-28-2020, 10:54 PM   #21
Cridland
Cridland's Avatar
Drives: 2013 Whiteout FRS
Sorry to revive this thread, long time member lol and got some BRZ seats for my tacoma and installing those here shortly and using this wiring schematic. Thanks a ton!!
Quick question, you are not using a relay are you? Just 12v from the fuse panel to the switch, and then from the switch to either the hi or lo heater wire. You are letting all 10A (max) run through the switch eh?
Cridland is offline   Reply With Quote
Old 11-25-2020, 11:42 AM   #22
Ghostcloak
That is correct Cridland. I am using the oem switches, so they are rated for this current load. If you are using an aftermarket switch, I recommend getting a 15amp rated single pole double throw switch (safety factor) or going to relay route.
Old 12-30-2020, 06:38 AM   #23
Twitchy313
Twitchy313's Avatar
Super late to the party, but awesome job!
heated seats debs0712 Cosmetic Modification (Interior/Exterior/Lighting) 47 04-08-2018 10:06 PM
brz limited heated seats abutterman Issues | Warranty | Recalls / TSB 15 04-15-2013 12:18 PM
heated seats installation abutterman Electronics | Audio | NAV | Infotainment 10 02-15-2013 05:19 PM
Heated seats: Switches backlit? Augora Issues | Warranty | Recalls / TSB 3 01-15-2013 03:51 AM
Retrofit heated seats to Premium? blalor BRZ First-Gen (2012+) — General Topics 4 05-31-2012 08:50 AM
