Old 07-16-2018, 10:05 PM   #15
86TOYO2k17
Drives: 2017 toyota 86
The other option if FI isn’t an option or even if it is. Weight reduction can quickly increase power to weight and you could easily NA get the same ratio as stock weight to 250bhp with some weight reduction. 250bhp to 2774 = 11.1bhp/lbs. 174lbs weight reduction with 235bhp = 11.06bhp/lbs
The Following User Says Thank You to 86TOYO2k17 For This Useful Post:
SuperTom (07-16-2018)
Old 07-16-2018, 10:11 PM   #16
FRS Justin
Drives: 2013 Asphalt FRS
Originally Posted by weederr33 View Post
Aftermarket pulleys will get you there no problem.
SMH nice.....
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
The Following User Says Thank You to FRS Justin For This Useful Post:
weederr33 (07-16-2018)
Old 07-16-2018, 10:51 PM   #17
bfrank1972
Drives: 2013 FR-S Argento
Most stock cars (200 crank) on a dynojet come in around 165-170whp. A top tier catless header and good custom tune, will get you around 200whp, maybe more. Ptunings header made well over 200. That's on 93. 200/165*200= about 242 crank horsepower based on stock being 200 at the crank. But more than that, it will feel much livelier across the rev band. Power blocks, with correct tune, will fatten up your upper mid range, and only sacrifice a couple hp north of 7000 rpm. Add to that the final drive mod and your car will feel quite perky. Past that, like the other poster mentioned, it gets expensive - better to bite the bullet and go FI, where you can get bigger power (and potentially bigger headaches, or at least more fiddling).
Sent from my SM-N920V using Tapatalk
Old 07-16-2018, 11:09 PM   #18
CSG Mike
CSG Mike's Avatar
Ace header, Race gas, and tune, will get you most of the way there.
Pat (07-17-2018)
Old 07-17-2018, 11:50 AM   #19
opposer
Drives: GT86 MT aero stock
are there any videos in the Net with a race between headers+tune BRZ vs stock? I hadn't found any. I want to compare the income
opposer is offline   Reply With Quote
Old 07-17-2018, 11:53 AM   #20
opposer
why do the people keep saying that turbo or supercharged BRZ has lower reliability than stock one? I had STI 2005 ej207 st1, didn't have any problems at all.
Old 07-17-2018, 12:23 PM   #21
Soloside
-Phil's BIGGEST FAN BOI
Drives: 2014 Greddy Turbo BRZ
we have very garbage motors for reliability and power output.
2014 Subaru BRZ
Don't follow your dreams, follow my instagram www.instagram.com/soloside
Soloside is offline   Reply With Quote
Old 07-17-2018, 12:31 PM   #22
Joesurf79
Joesurf79's Avatar
Drives: 2016 White Pearl BRZ Premium
If one shaves weight and adds more power and a 4.56 final drive. Well it's the BRZ version of taking the red pill
Joesurf79 is offline   Reply With Quote
The Following 3 Users Say Thank You to Joesurf79 For This Useful Post:
Spuds (07-17-2018), SuperTom (07-17-2018), weederr33 (07-17-2018)
Old 07-17-2018, 12:41 PM   #23
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Nah.. pulleys won't be enough. He might need additionally the red STI start button and maybe the red belts..
The Following User Says Thank You to nikitopo For This Useful Post:
Old 07-17-2018, 12:52 PM   #24
bfrank1972
1) FA20 is not engineered for stresses of forced induction, STI motors are.
2) Factory FI systems are typically better engineered than aftermarket add-on solutions.
3) Installer error can have expensive repercussions, vs. a car that rolls off the factory floor with FI.
4) People tend to cut costs and not employ fail-safe measures when installing aftermarket FI.
Risk vs. reward. If you go FI, just make sure you have the funding to rebuild a blown motor. If you don't, and you're satisfied with an incremental bump in power, go the NA route. You can really change how the car feels with just a few simple non-FI mods.
The Following User Says Thank You to bfrank1972 For This Useful Post:
SkyeHack (07-17-2018)
Old 07-17-2018, 01:21 PM   #25
tyler_win_photo
tyler_win_photo's Avatar
Drives: 2014 Scion FRS (Asphalt)
Header + tune + 4.56 or 4.8 FD will really wake the car up.
tyler_win_photo is offline   Reply With Quote
Old 07-17-2018, 01:28 PM   #26
opposer
are there any videos with race between aforementioned and stock?
Old 07-17-2018, 04:16 PM   #27
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Don't hate on my awesome red STI start button
MS, CSCS, TSAC-F, CPT
The Following User Says Thank You to weederr33 For This Useful Post:
nikitopo (07-17-2018)
Old 07-17-2018, 05:06 PM   #28
mrg666
pessimistic skeptic
mrg666's Avatar
250 bhp slightly crosses into the FI territory. 200 whp (230 bhp?) is possible with high-end NA mods. You can do ACE header + tune to reach the high end NA level and continue with weight reduction. But weight reduction is not cheap either. I think supercharger will be the easiest way to reach your goal. You will probably get more than 250 bhp that way. But I am sure you wouldn't complain about it.
The Following 2 Users Say Thank You to mrg666 For This Useful Post:
Dadhawk (07-18-2018), weederr33 (07-17-2018)
