Old 07-08-2018, 03:30 PM   #71
displacedTexan
displacedTexan's Avatar
Drives: '13 FR-S 10 Series
Originally Posted by ermax View Post
So what they are basically saying is changing your own oil voids the warranty? What a bunch of BS. Im curious if there is a way to sufficiently prove to Toyota that you’ve changed the oil. Recipes apparently aren’t enough. Do they need a freaking time stamped video?
I even asked the Toyota Cust. Relations rep about recording maintenance. I pointed out there's nothing in the warranty or service manual describing how maintenance should be recorded. He didn't have an answer because Toyota doesn't have a recommended process for documenting maintenance outside a dealership.
From the sounds of it, they're going with 'insufficient' maintenance records and "usually this kind of failure is caused by over rev." The FTC's interpretation of the Magnuson-Moss Warranty Act requires a manufacturer to prove improper maintenance caused the specific damage for which repair is sought. Toyota should also be obligated to prove an over rev caused the damage according to the FTC's interpretation. It shouldn't be enough to say "well, usually this only happens when the engine is over revved, and you have excess clutch wear."
One of the most frustrating things is that it seems that the consumer protection law in place doesn't mean jack sh!t to Toyota. And outside of dispute settlement, the consumer has to gamble things will work out in court to actually see the law enforced.
displacedTexan is offline   Reply With Quote
Old 07-12-2018, 05:56 PM   #72
displacedTexan
I spoke to a Subaru technician earlier today. They confirmed the ECU on the '13 BRZ does record over revs. In the case of Subaru, that data is not accessible at the dealership level. Subaru dealerships have to get someone at corporate level to pull the data. I know that doesn't confirm that the FR-S ECU stores that data, but it seems promising. I called another Toyota dealership in town to ask about the ECU on the FR-S logging over revs. The technician I spoke to had no idea. I emailed the service manager at the dealership where my car is to let him know Subaru confirmed the ECU on the '13 BRZ logs over revs to see if it'd push him to get the data.
The Following User Says Thank You to displacedTexan For This Useful Post:
Ultramaroon (07-12-2018)
Old 07-16-2018, 01:08 PM   #73
displacedTexan
Updated first post. Toyota corporate had an FTS look at the car, and the FTS concluded it was not over revved. Now I need to get a fuel sample tested to see if the tank has bad gas. The FTS also thought the oil may have been low at some point. I know they can't show the oil was low, because it never was.
Feels like a small win having Toyota confirm the engine wasn't over revved, but I'm not getting my hopes up just yet. Might be more fighting to do with Toyota.
The Following 3 Users Say Thank You to displacedTexan For This Useful Post:
ermax (07-16-2018), Tcoat (07-16-2018), Ultramaroon (07-16-2018)
Old 07-16-2018, 03:42 PM   #74
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Bad gas prompting a rocker arm to fall off.
They're really clutching at straws now.
ermax (07-16-2018)
Old 07-16-2018, 04:00 PM   #75
ermax
ermax's Avatar
Bad gas. Hahaha!
Old 07-16-2018, 06:03 PM   #76
displacedTexan
It's BS. The engine has been opened up sitting in the dealership's shop for a month. At this point, who knows what was on the pistons when it was first opened up and what's collected on them since.
Old 07-19-2018, 03:15 PM   #77
displacedTexan
Finally got some good news. Toyota is going to honor the warranty. Parts were ordered this morning. Took 'em long enough.
The Following 6 Users Say Thank You to displacedTexan For This Useful Post:
Capt Spaulding (07-19-2018), DarkSunrise (08-22-2018), ermax (07-19-2018), humfrz (07-19-2018), Tcoat (07-19-2018), Ultramaroon (07-19-2018)
Old 08-22-2018, 07:16 PM   #78
displacedTexan
I picked the car up on Monday. Everything seems to be in working order. It took two months and four days to get the car back. Now I'm just paranoid about sounds I don't remember the car making. I could've forgotten the car makes this noise, but part of me won't trust it for awhile.
bcj (08-23-2018)
AC failed under 6 years. wparsons Issues | Warranty | Recalls / TSB 5 05-17-2018 12:08 AM
Failed Tom's Tail lights RevoG Cosmetic Modification (Interior/Exterior/Lighting) 42 12-21-2016 07:45 PM
Hlep. I failed. Shaisters Northwest 14 06-02-2016 11:56 PM
Nameless overpipe/downpipe welds failed and perrin endlink failed stockysnail Northwest 4 01-14-2016 07:27 PM
Failed Inspection with a tune... Shady195 Scion FR-S / Toyota 86 GT86 General Forum 19 06-10-2015 05:25 PM
