Old 07-06-2018, 01:04 PM   #1
ImADuck
ImADuck's Avatar
Drives: 2017 Series.Yellow BRZ
Tell me about your short shifter
Been thinking about getting a short shifter, but not really sure which one I should get. If you could leave some feedback about yours that'd be great, thanks!
I've done some searches on the short shifter kits out there, but most posts seem relatively old. From what I've been reading, there typically is some sort of "issue" with each of them be it rattling (IRP) or getting locked out of 1st/2nd (TRD). Maybe, those issues have been fixed in the recent years? Also, there doesn't seem to be much if any info on the new 2017+ STI Short Shifter. Is there any consensus on whether or not it's worth it? I'm already leaning towards that one because it most likely would allow me to keep my factory warranty.
ImADuck is offline   Reply With Quote
Old 07-06-2018, 01:24 PM   #2
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
The US TRD short shifter is an awful product.
The JDM TRD short shifter I believe is the same as the STI short shifter. I have it and like it. I have had no issues.
Teseo (07-06-2023), Ultramaroon (07-06-2018)
Old 07-06-2018, 01:28 PM   #3
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
I love my US TRD short shift kit. Install wasn't the most fun thing, but it was worth it.
BigTuna is offline   Reply With Quote
Old 07-06-2018, 01:44 PM   #4
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
I had bad experiences in the past with short shifters so I have a centimeter to two drop in height, MTEC shift springs, Perrin shift bushing and Whiteline trans bushing, along with an aftermarket knob and reverse lockout. The stock throw is pretty short as is. If I was going racecar then I would get the IRP short shifter and never look back. Too tall for daily driving IMO.
Old 07-06-2018, 04:32 PM   #5
ImADuck
ImADuck's Avatar
That's the thing, I've read both bad and good things about the US TRD shifter. It's the cheapest option, but some say you have to use loctite or majorly risk getting locked out of 1st and 2nd.
Thanks for the input on the STI shifter! It's the most tempting due to not having any issues (tho no one has talked about it much) and being a Subaru part so ok for warranty. BUT it seems to be the most expensive...
Ah I see. If you don't mind me asking, what does each part affect? Also what shift knob do you have? I'm on the fence about getting a weighted one, but am not sure what shape I want...
I'm mainly looking for a way to remove some of the play from my 3rd gear. The play is causing me to occasionally grind my 3rd gear . Having shorter throws would be a nice side effect as well.
Old 07-06-2018, 05:11 PM   #6
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Well the ladies seem to like my short shifter
oh wait...
MS, CSCS, TSAC-F, CPT
Old 07-06-2018, 05:20 PM   #7
+1
It takes balls to sell a kit that requires thread locker because the parts don't fit.
Sapphireho (07-06-2018), Teseo (02-07-2023), weederr33 (07-06-2018)
Old 07-06-2018, 06:10 PM   #8
Sapphireho
Famous Potatoes
Sapphireho's Avatar
+1
I used loctite, then more loctite. Bolt stretched.
When is trying to add an inch to the end of a lever ever a good idea?
Old 07-06-2018, 06:34 PM   #9
Dr. BRZ
Dr. BRZ's Avatar
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
Irp v3, best one.
Dr. BRZ is offline   Reply With Quote
The Following 2 Users Say Thank You to Dr. BRZ For This Useful Post:
Captain Snooze (07-08-2018), Joveen (01-30-2019)
Old 07-06-2018, 07:51 PM   #10
Irace86.2.0
The transmission bushing makes the transmission twist less during times off and on throttle. The Perrin shifter bushing removes slop in the gate pattern. The MTEC springs give more force to the shifter to make it return to neutral, which gives the effect of making the throws feel quicker and with some spring. Throws from 2 to 3rd and others that go from the lateral to the medial positions will feel the most dramatic. A heavier knob will aid in smoothness, as will some quality gear oil like Motul, Redline, AMSOIL.
I have a knob n lockout from Aliexpress. Anodized aluminum which feels great in the hand.
The Following 2 Users Say Thank You to Irace86.2.0 For This Useful Post:
ImADuck (07-06-2018), SkyeHack (07-06-2018)
Old 07-06-2018, 08:05 PM   #11
lantsalot
Derp
lantsalot's Avatar
I have the Kartboy with the rear shifter bushing and I really like it. At first it was noticeably more notchier/difficult to shift--but after getting a weighted shift knob it got significantly better. There is very little movement, it all feels super snug when shifting.
I later added the mtec shift springs, and kinda wish I would have done that all at once. It takes a bit more force to push the shifter out of a gear but is guided much more easily into gear.
I've had no issues so far with being locked out of any gears...have had the short shifter for close to a year I think.
lantsalot is offline   Reply With Quote
The Following User Says Thank You to lantsalot For This Useful Post:
Old 07-06-2018, 08:13 PM   #12
ImADuck
ImADuck's Avatar
That sounds exactly like what I want to fix on my shifter. Hmm... How hard was it to install all that?
Also do you still have the link for that shift knob and lockout? It looks dope af!
Old 07-06-2018, 08:34 PM   #13
Irace86.2.0
Not hard if you have basic mechanic skills and a collection of tools.
I bought it 3 years ago so I’m not sure. Last time I looked, which was two years ago, the store on Aliexpress closed.
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
Old 07-07-2018, 01:31 AM   #14
NRXRaptor
Originally Posted by Dr. BRZ View Post
Irp v3, best one.
I wanted to get that to celebrate getting accepted into school, but then the tuition deposit was $500 so I didn't
NRXRaptor is offline   Reply With Quote
FS: Stock Short-Throw Shifter, Springs, and Rear Shifter Bushing bergy Transmission and Driveline 8 10-20-2016 10:57 PM
cae ultra shifter vs short shifter jdmblood Engine, Exhaust, Transmission 22 01-14-2016 12:19 AM
kartboy short shifter and rear shifter bushing install and review. FR-S UMB FR-S DIY (Do-It-Yourself) Guides 21 10-18-2014 02:41 AM
TRD Short Shifter Quick Shifter Scion FRS hirollaz Transmission and Driveline 3 04-15-2014 02:24 AM
BPS Short Shifter Alabang 86 Transmission and Driveline 8 09-02-2013 01:58 AM
