Old 07-05-2018, 01:24 PM   #3417
tony_r
tony_r's Avatar
Drives: '15 STX
I'm willing to bet you could find a used torsen, complete unit, for cheaper than anything you find on the aftermarket. And you don't have to open it up, just R&R the old one.
tony_r is offline   Reply With Quote
The Following 2 Users Say Thank You to tony_r For This Useful Post:
BE4VER (07-05-2018), strat61caster (07-05-2018)
Old 07-05-2018, 02:31 PM   #3418
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Originally Posted by CoolHandMoss View Post
But when your stock torsen goes out it will still need a rebuild when the quaife goes in. The quaife unit is just the pumpkin. So the bearings and whatever else is broken in the stock diff will run the cost up to more than a stock replacement, and well more than a rebuild of the stock unit.
Pumpkin usually refers to the case, not the differential unit itself that sits inside the case.
When I hear 'differential rebuild' I think about the thingy that does the magic of transferring the power, not the bearings and seals that keep it protected.
@tony_r is right, $500 or less gets you a lightly used differential that you can bolt right up to the rear end, just make sure you grab the right model (unless you want to cheat and end up with a gearing change out of it )
$500 on fleabay: (I bet you can find a used one from someone more reputable for $400 or less though, hey maybe an autoxer/track rat that's gone to aftermarket has a unit laying around or casually for sale)
vs. $1.2k + labor & other parts
ineedyourdiddly
BE4VER (07-05-2018)
Old 07-05-2018, 02:41 PM   #3419
BE4VER
( ͡° ͜ʖ ͡°)
BE4VER's Avatar
Drives: 14FR-S
I thought I was comparing case to case like number 9 in the exploded diagram. Wouldn't all the same stuff be needed anyway? If the case is not rebuildable then you save $350 for that one main part and the rest would be the same any way no?
“Has Anyone Really Been Far Even as Decided to Use Even Go Want to do Look More Like?”
BE4VER is offline   Reply With Quote
Old 07-05-2018, 02:45 PM   #3420
BE4VER
( ͡° ͜ʖ ͡°)
BE4VER's Avatar
Drives: 14FR-S
I know you guys are right about what you're saying with that and I am aware I'm being hypothetical AF
Old 07-05-2018, 02:54 PM   #3421
tony_r
tony_r's Avatar
Drives: '15 STX
When rebuilding a broken diff, you have no idea what is able to be saved and what isn't without cracking the case and inspecting. Metal shards have a way of traveling all through the carrier and damaging all the moving parts. You could have teeth sheered off the ring, pinion, or spider gears; and bearings that have pitting/excessive wear. Or you could have all of that.
With any replacement mechanical unit, you're paying for #9 only, basically. Some might come with #10 & #11 as well.
Old 07-07-2018, 09:46 PM   #3422
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
What do you guys think about my new alignment? I was still getting noticeable outside tire wear at -2.5 Front -2 Rear so I decided to go all out. From what I've read these specs should give even wear and maximum grip. Will check with a pyrometer at next event to see if any tweaks are needed.
smg1138 is offline   Reply With Quote
The Following User Says Thank You to smg1138 For This Useful Post:
Racecomp Engineering (07-08-2018)
Old 07-07-2018, 10:01 PM   #3423
CoolHandMoss
Drives: 2013 FRS
That's right about where mine is set. It's pretty good but I do find the outside edges getting hot on high grip surfaces.
CoolHandMoss is offline   Reply With Quote
The Following User Says Thank You to CoolHandMoss For This Useful Post:
smg1138 (07-07-2018)
Old 07-12-2018, 04:40 PM   #3424
smg1138
smg1138's Avatar
So, I really need to pull the trigger on some camber plates. I tried using camber bolts to get more camber up front, but they ended up slipping. I can get up to -2.8 with just the 14mm crash bolts in my RCE T2's, but that still isn't enough for Autox. Getting noticeable outside wear in the front tires after every event.
What are some good plates to look at? Is anyone using the GroundControl plates? Seems like those would be optimal since the design actually adds more suspension travel. Definitely don't want anything that raises ride height.
Old 07-12-2018, 04:51 PM   #3425
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
I like the Raceseng camber/caster plates. Easy to adjust and install.
justinco is offline   Reply With Quote
The Following User Says Thank You to justinco For This Useful Post:
smg1138 (07-12-2018)
Old 07-12-2018, 05:24 PM   #3426
AFRichZC6
AFRichZC6's Avatar
I have the GC camber plates. I haven't gotten close to the bumpstops in front. There's plenty of camber adjustment (at least -4.5 degrees with camber bolt adjustment at the strut). However, there's not much caster to be gained. IIRC, I only got about 0.5 degree more caster.
I also really like the Raceseng plates. They also do not take away compression travel or raise ride height compared to stock or other bottom-mounted camber plates. I believe they also provide a bit more caster than the GC plates.
I think you're still going to get more outside tire wear with -3.5 degrees of camber in front if you're on RE71R and on concrete.
AFRichZC6 is offline   Reply With Quote
The Following User Says Thank You to AFRichZC6 For This Useful Post:
Old 07-12-2018, 06:36 PM   #3427
smg1138
smg1138's Avatar
Yeah, I was wondering about how much more positive caster they offered. Is the caster adjustable or fixed on the GC plates? For whatever reason I get uneven caster left to right with the stock mounts.
Old 07-12-2018, 06:42 PM   #3428
kinghurl
Drives: BlueBurz
I've used the raceseng and a couple others. The billet aluminum hats from Ditech have been on my car for over 18 months now and in terms of fit, finish and function, are the best I've used. They are quiet, easy to adjust and easy to lock into final settings. I can get over 5 degrees camber and almost 6.5 caster. Good quality pieces. Autox/street car.
https://diftech.com/collections/susp...=8186838220904
Sent from my SM-G930V using Tapatalk
kinghurl is offline   Reply With Quote
The Following User Says Thank You to kinghurl For This Useful Post:
Old 07-12-2018, 06:43 PM   #3429
kinghurl
Drives: BlueBurz
Diftech, not ditech. Autocorrect!
Old 07-12-2018, 07:39 PM   #3430
AFRichZC6
AFRichZC6's Avatar
The GC plates have caster adjustment, but the range of adjustment isn't much.
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 03:12 PM
SCCA sway bar rules gmookher Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-01-2012 07:48 PM
Suggestion for vendor rules... Tainen Site Announcements / Questions / Issues 31 08-15-2012 02:53 PM
Rules for posting in this section Hachiroku User/Vendor/Sponsor Reviews, Feedback, Comments 0 06-25-2012 12:02 PM
