#19209 |
Site Moderator
Drives: ichi 86 Project
If you have access to CNC, might be worth it... but keep in mind that when you do shave off the spacer, you do need to shave off few mm of bolts. Bolts that come out of firewall are bout 1, thats why all the pedal spacers are 1 thick. Its a bit awkward angle you gotta be to grind it off, but I did it without an issue.
#19210 |
Sittin' Sideways
Drives: 2016 Toyota FR-S
That would've made the drive even more fun.
But really, 459.2 miles from 11.637 gallons.....39.46 mpg. Interesting for me, the station I found to fill up only had 92 as their highest octane. Never encountered a station with a 92 before. No real witchcraft involved, just the benefit of having the automatic spinning everything at lower rpms at the same speeds....even then, I was not expecting to be knocking on 40mpg's door in this car. That's the same personal best I got from my old 03 Corolla. Oh, and I did the posted speed limit pretty much the whole time (55-70 depending on state), no sandbagging. Just sat in the right lane and let everybody else go by. Even encountered an older twin in Hot Lava somewhere in North/South Carolina.
-O/D
2016 FR-S, Hot Lava |
| The Following User Says Thank You to Overdrive For This Useful Post: | humfrz (07-03-2018) |
#19211 | |
I thought maybe you had filled up in Denver and coasted to Wichita .. ![]() humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | Overdrive (07-06-2018) |
#19212 | |
#19213 |
Drives: FR-S 10 Series
Got the FR-S back, cause of leak was a creased crush washer. Dealer replaced the washer and topped off the oil. Second oil change since Saturday, does this count as a flush?
#19214 | |
![]() Yep, you got "flushed' fer sure. humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | dnieves (07-04-2018) |
#19215 |
Drives: '16 FR-S RS2 MT, '06 xA Polar MT
Or maybe a dealer dusching
Math is like Love, simple idea at first that quickly gets complicated
| The Following User Says Thank You to Adam_L For This Useful Post: | dnieves (07-04-2018) |
#19216 |
Finished installing the Wide body kit
Cut the rear fenders and welded them as well as sealed them with silicone. Car is coming along nicely. Insta: @BreakTraction. Youtube/ Documenting the Build: Break Traction https://www.youtube.com/breaktraction Last edited by BreakTraction; 07-04-2018 at 11:36 AM. |
#19217 | |
I reckon a little extra armor never hurt anything. "jest ah messen wich ya" - pay old humfrz no nevermind .. ![]() Seriously, it looks like you did a nice job .. humfrz |
#19218 |
Washed, clay bar and waxed. Worth it despite the potential of heat stroke.
BTW Old timers are right, Liquid Glass is pretty good. FYI Coke Cola doesn't remove synthetic oil stains from pavers. Pretty much nothing from Home Depot does either. |
| The Following User Says Thank You to dnieves For This Useful Post: | humfrz (07-05-2018) |
#19219 | |
From the Farmers Almanac .. "Liquid dish soap or laundry detergent will remove most oil stains on pavers. Directly apply the soap to the stain and allow to sit for 20-30 minutes. Then scrub with a nylon bristle brush and rinse with hot water. Repeat this step as needed". humfrz |
#19220 |
Drives: '15 Halo Scion FRS, 1999 Saturn SC2
After 3 years, 3 months, and 12 days ....
2015 Halo Scion FR-S 6MT new w/TRD exhaust, cold air intake, quick shifter, sway bars, lowering springs, & brake pads. Since then, TRD door braces, strut tower bar, & battery tie-down, Motul fluids in trans/diff & brakes, GrimmSpeed master cylinder brace, Stoptech stainless brakelines, OpenFlash Header 3 w/overpipe, OpenFlash Tablet on E85
#19221 |
Drives: red 2014 FR-S
#19222 |
How do I shift?
Drives: '13 GBS BRZ
He didn't want to die while taking a picture while driving.
| Tags |
| :popcorn:, :popcorn: funny tags, nsfc, rice rice baby |
| Saw My First FR-S Today | Marrk | Scion FR-S / Toyota 86 GT86 General Forum | 26 | 05-15-2013 12:40 PM |
| Got My Car Today!!!!! First 86!! #81 | Juanito08 | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 05-22-2012 04:54 PM |
| If my FRS was here already, today I would... | bestwheelbase | Scion FR-S / Toyota 86 GT86 General Forum | 101 | 05-12-2012 06:20 PM |
| Sat in a FRS today!! | Ladnerd | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 04-30-2012 01:48 PM |
| Got my VIN today... | Enemies | BRZ First-Gen (2012+) General Topics | 63 | 04-12-2012 10:19 PM |
