Old 07-02-2018, 01:55 PM   #57
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
So the million dollar question is, should I just go down the weight loss list of crank pulley, flywheel, drive shaft? Or should I just go FI instead and call it a day?
lawlz
MS, CSCS, TSAC-F, CPT
Old 07-02-2018, 02:37 PM   #58
churchx
churchx's Avatar
Drives: 2014 GT86
FI. But not call it a day, also grippier tires, uprated clutch. If tracked, also better brakes & oil cooler.
NA power gains are expensive. Lightening may mean compromising/loosing lot of daily comfort/usability/features.
Old 07-02-2018, 02:42 PM   #59
weederr33
weederr33's Avatar
It's sarcasm. There's always a compromise no matter which way you go about it.
The Following User Says Thank You to weederr33 For This Useful Post:
nikitopo (07-02-2018)
Old 07-02-2018, 02:49 PM   #60
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
YEP
FI = Tires,Clutch,Brakes, possibly suspension for the heavier weight on the NOSE. Worse weight distribution. Engine braking or wearing down quicker
Lightness you can decide how far you want to go or compromise but you increase all areas of performance. Acceleration, Braking, Cornering, MPG, Less wear & tear on engine.
Both are going to cost $$$$
SuperTom is offline   Reply With Quote
Old 07-02-2018, 03:00 PM   #61
churchx
churchx's Avatar
Drives: 2014 GT86
SuperTom: not the area of comfort/daily usability features/NVH. I don't want to have lighter car without A/C when stuck in traffic jam during hot summer day. I don't want naked interior and lack of even stock noise dampening especially if paired with very light .. muffler-less track pipe when cruising long distances. I don't want to be stranded with flat tire w/o at least skinny spacesaver donut in boot. I don't want to switch batteries for winter. Car for me is dual use, hence i consider all possible mods in way to not hurt other use for sake of specializing.
FI is simplest way to change weight/power ratio. And if going for light gains kits, one can get by without too big of spendings in way of forged engine internals/better gearbox and other bits in transmission and alikes. NA has it's niche, but gains in it are expensive, made relatively affordable only due rather low max gains limit.
Old 07-02-2018, 03:19 PM   #62
SuperTom
SuperTom's Avatar
Obviously this thread isn't for you
The Following 3 Users Say Thank You to SuperTom For This Useful Post:
funwheeldrive (07-02-2018), nikitopo (07-02-2018), PuslarBrrrz (07-02-2018)
Old 07-02-2018, 04:51 PM   #63
bfrank1972
Drives: 2013 FR-S Argento
The answer is, buy a lightweight pulley... and install it on your Exige.
Old 07-02-2018, 05:06 PM   #64
lawlz
Oh, I'd suggest you just go for an engine swap …..
Old 07-02-2018, 05:20 PM   #65
Reminds me of back-in-the-day, I went into partnership with two other kids and we bought a 1937 Chevrolet pickup truck. Yep, we paid $75 for it and it ran (after we put tires and a battery on/in it).
My partners lived in town and I lived on a farm. One weekend "they" decided to cut the bed off the truck, so it would be lighter and faster in a 1/4 mile drag. Which it did do that.
HOWEVER, I was the one who lived on a farm … and now the damn truck couldn't haul anything ..
Old 07-02-2018, 06:44 PM   #66
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Engine swap? Better buy another car.
Old 07-02-2018, 08:51 PM   #67
86TOYO2k17
Drives: 2017 toyota 86
Originally Posted by SuperTom View Post
well that is one of the largest shorai batteries I am using. I have no problems taking short trips at all in a heat wave. It may be good for the winter but I felt better with a stock battery in the winter. I didn't want to risk not making it to work one cold snowy morning but I'm not saying it won't work.
I also keep a cellphone sized jumper in my glovebox which is less than 2lbs
https://www.amazon.com/Portable-Ultr...ds=mini+jumper
I think stock battery was like 390cca and 90AH, this batter is like 520cca and 34AH, so i think it should be fine in the winter.
However i have read things about the battery deforming and or catching fire bcs of overcharging? do you know what rate the stock alternator charges at?
really interested in this weight reduction mod, but not if its potentially dangerous or a pain to maintain the batter.
Old 07-02-2018, 09:01 PM   #68
weederr33
weederr33's Avatar
Nope. Engine swap is fair game
Old 07-02-2018, 10:06 PM   #69
SuperTom
SuperTom's Avatar
hmm haven't heard of issues in a car itself. I think those issue are when you use and outside car charger that pushes a lot of amps. That's why most recommend the shorai charger for it.
Me I'm cheap and use this harborfrieght tender that only pushes .5 amps
https://www.harborfreight.com/automa...ger-69955.html
Kept mine happy all winter!!
I still don't understand why people are stressing out about changing the battery for the winter. You literally unbolt the + and - terminal, then loosen the tie down, lift battery out. Damn some people are lazy
Old 07-02-2018, 10:24 PM   #70
86TOYO2k17
OK, i was thinking of underdriving the alt to slow down the charge if it was an issue, may still do it anyways to squeeze out that extra 1/2hp
Yes i am really lazy, but you are right i shouldn't let my laziness get the best of me. def on my list of mods to do.
Going to probably copy your battery setup exactly.
Understanding Fuel Trims ShadowReaper Software Tuning 13 04-01-2018 01:34 PM
Understanding Compressor Maps arthur93 Forced Induction 31 05-25-2017 10:49 AM
Understanding Oil tofurun Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 13 06-10-2016 04:06 PM
BUDDY CLUB Lightweight Racing Wheels - JDM, lightweight, low pricetag | 18x8.5" GuerillaRacing Wheels and Tires 116 01-20-2015 07:32 PM
Understanding/clarifying vendor qualifications mav1178 Site Announcements / Questions / Issues 21 03-18-2014 03:25 PM
