#43 | |
https://demos.starbase7.net/t3Portal...44588675128151 They are saying this engine consumes oil at 1US QT every 2000 miles. This info should be in the owner's manual that comes with the car. Not the shop manual that the average person will never see. This tidbit in itself is class actionable IMO. 1qt every 2000 miles is what most manufacturers would consider excessive.. not normal. How many modern cars require at least 2 top offs between oil change intervals... hell how many cars require any top offs at all between changes? I got my car used, changed the oil on day one and only put about 4000 miles on it before spinning a bearing. during that 4000 miles I did top it off a few times (1/4qt each time) which I just attributed to the age of my car until I read that crap in the service manual. We are car guys so we are the type that will check our oil all the time. Your average person will not check their oil level regularly. They will just change the oil at the recommended interval and call it a day. I always thought it was odd that the change interval was so short on this car considering it requires synthetic. Most modern cars with synthetic have a 10k+ interval. For example BMW says 15K. They knew this car drank oil so they gave it a short interval. I'm surprised these cars don't blow purple smoke with this level of consumption. Long story short I wouldn't be surprised if the majority of the failures are do to the consumption problem. I got my car used and I'm just going to cross my fingers that mine spun due to neglect from the previous owner. I hope that when I finish rebuilding mine that it will be okay in the long run because I check my level regularly. But I still think Subaru/Toyota needs to be more upfront about the consumption being so high. If they were more upfront they wouldn't be able to sell the cars though. 1qt/2000mi is a joke. |
#44 | |
Drives: 14' Raven M/T - 02' is300
2014 6k intervals 0w30
| The Following User Says Thank You to max20s14 For This Useful Post: | ermax (06-29-2018) |
#45 |
#46 | |
Drives: '13 FRS - STX
PDF here: https://www.toyota.com/owners/resour...uals/fr-s/2013 So to answer your question, Subaru, Subaru may require two oil top offs between intervals, technically they're ok with you having to add a quart 10x per interval. ![]() I generally add about half a quart that's leftover from the previous change at 6k miles just to bring it up from near the low mark. That probably wouldn't be necessary if I filled it to the tippy-top though, unless filling it makes it burn faster
#47 | |
You need many instances to have a class action. There just are not enough. Sure as hell can't have one on a condition written in the manual that nobody has ever even reported seeing happen. There is no reported "consumption problem" and even if there was if people check their oil it should never be low enough to cause failure. Some early cars had oil delivery issues and fail it is as simple as that. They seem to have corrected the problem since 14s and up have an insignificant number of failures if not messed with.
#48 | |
#49 |
Drives: FRS 2013
When I saw the manual say consumption of up to 1L of oil every 1000km is considered within spec I was definitely concerned.
However, for my engine it seems to burn 'excess' oil until it reaches 3/4 full between max and min on the dipstick and stops burning oil completely. When I drain the oil after 10k km it's usually 5.4L +/- 100mL (I use old windshield washer fluid jugs with measurements on the side to check) 2013 build date 07/13, 135 000 km now. Use OEM filter and Toyota 0W20 |
| The Following User Says Thank You to highway7 For This Useful Post: | strat61caster (06-29-2018) |
#50 |
Drives: Crapcan
Everytime I see a thread like this I cringe since I have a 13' as well. Good luck OP. I have a spare motor for a reason.
Has anyone actually seen oil consumption of those levels? I am at about 66k miles, I have tracked my car 4 times since the last oil change. Level has not moved at all. My RL is also set at 7650. Makes me question the need for catch cans on this car. |
#51 |
#52 | |
1. Yes you understood what he said correctly "3/4 full between max and min on the dipstick" 2. While the high mark is labeled as 'full' please re-read the manual, you are supposed to maintain oil between the two marks, you are not instructed to maintain the oil level at the higher mark. "If the oil level is below or near the low level mark, add engine oil of the same type as already in the engine." That's it, there's no 'fill to top line' or 'maintain above 50% between the marks' it is very specifically 'keep the level above the low mark' Also: "Avoid overfilling, or the engine could be damaged." |
| The Following User Says Thank You to strat61caster For This Useful Post: | Tcoat (06-29-2018) |
#53 |
Traditionally the top dot is full and the lower dot is 1qt low. Anything between is considered safe, anything above or below is unsafe. It's the same deal with all cars.
#54 | |
You hammer on the car and it uses more oil. Strange how that happens. Engine oil consumption ●The amount of engine oil consumed depends on the oil viscosity, the quality of the oil and the way the vehicle is driven. ●More oil is consumed under driving conditions such as high speeds and frequent acceleration and deceleration. ●A new engine consumes more oil. ●When judging the amount of oil consumption, keep in mind that the oil may have become diluted, making it difficult to judge the true level accurately.
#55 | |
#56 | ||
Proud of BOXER
Drives: Subaru Boxer
This is why it's so important to regularly check your oil levels with this car. I believe a lot of people don't realize how much oil they consume.
I check mine regularly and add a half quart if the oil level is at or below the mid way/50% point on the dipstick. Quote:
| The Following 2 Users Say Thank You to Clipdat For This Useful Post: | ermax (06-29-2018), thomasmryan (07-06-2018) |
| AC failed under 6 years. | wparsons | Issues | Warranty | Recalls / TSB | 5 | 05-17-2018 12:08 AM |
| Failed Tom's Tail lights | RevoG | Cosmetic Modification (Interior/Exterior/Lighting) | 42 | 12-21-2016 07:45 PM |
| Hlep. I failed. | Shaisters | Northwest | 14 | 06-02-2016 11:56 PM |
| Nameless overpipe/downpipe welds failed and perrin endlink failed | stockysnail | Northwest | 4 | 01-14-2016 07:27 PM |
| Failed Inspection with a tune... | Shady195 | Scion FR-S / Toyota 86 GT86 General Forum | 19 | 06-10-2015 05:25 PM |
