Old 06-16-2018, 10:33 AM   #43
steve99
Drives: FT86
Originally Posted by Ryan GT86 View Post
Does this mean even turbo kits marketed for stock engines could put the engine at severe risk of failure if the engine wasn't rebuilt with stronger components?
To me its counterintuitive that FI engine failures occur at lower rpms. Is there a reason why this occurs?
Torque
FI engines can produce more torque at lower rpm that upper rpm
torque is what breaks rods
part of tuning will be to limit torque (hence power) at lower rpm)
stock engine less than around 300ft lb is usually reasonably safe
http://www.epi-eng.com/piston_engine...and_torque.htm
The Following 2 Users Say Thank You to steve99 For This Useful Post:
Ryan GT86 (06-16-2018), Tcoat (06-19-2018)
Old 06-16-2018, 08:11 PM   #44
gtengr
Drives: 2017 BRZ
I think you are isolating this example to typically sized turbos. Big turbos for the engine size can barely be building boost at 4k rpms.
I think the majority of failures are detonation... This is why rods break on stock cars and not on 400hp track cars.
I'm just assuming typical parts. Why would I put an oversized turbo on a stock engine? A gtx3067 makes big torque under 4000 rpm so it's a moot point anyway.
If the majority of failures are detonation, why do E85 cars bend rods?
A big supercharger will still be putting boost down at any rpm at anytime.Centrifugal SC have a linearly rising torque curve—not a flat one
So?
gtengr is offline   Reply With Quote
Old 06-16-2018, 11:47 PM   #45
JimmyMac
JimmyMac's Avatar
Drives: 2013 FR-S, 2016 Miata Club
9~10 psi bent rod cylinder #4. I think #3 was slightly bent. #2 looked straight. #1 threw everything through the block. haha I think cause was valve float and/or tossed rocker. You can see in the intake port pic where only one valve was bent/damaged. Exhaust side was fine. Stock 2012 engine. This was awhile back but just now getting to look at the damaged engine out of curiosity. If the valve spring/rocker incident didn't happen, it would have been a matter of time before something else would have.
JimmyMac is offline   Reply With Quote
Old 06-17-2018, 03:21 AM   #46
Ryan GT86
Ryan GT86's Avatar
Drives: 2019 Toyota 86
Torque
So what would have to be reinforced in the stock engine to prepare it for FI to increase longevity and prevent failures? I'm planning on track days with a turbocharged 86 in the distant but inevitable future.
Ryan GT86 is offline   Reply With Quote
Old 06-17-2018, 11:00 PM   #47
steve99
Drives: FT86
best talk to an engine builder thats done some FA20 FI
rods are main weak point , but if your going to build an engine you likely want to do a few more changes
Old 06-19-2018, 02:52 PM   #48
majixmatrix
BRZ Wannabee
majixmatrix's Avatar
Drives: 2013 Limited BRZ
Dude.....
Originally Posted by Hags86 View Post
So the symptom of the bent rods is the air/fuel ratio changing. I had some problems with the A/F drifting over a few weeks and the ECU needed to perform a lot of fuel trims to try and compensate. We couldn't figure out why. Faulty MAP sensor or Lamba sensor? Changing the engine efficiency table an it would be sweet, and then drift away again.
Turns out the compression ratio was changing as the rods bent and lowered the CR. All 4 rods were in fact bent - the photo is just the worst two of the four.
majixmatrix is offline   Reply With Quote
Old 06-19-2018, 03:30 PM   #49
Hags86
Drives: Toyota GTS 86
Originally Posted by majixmatrix View Post
Dude.....
Tell me how you'd figure rods are slowly bending? There was no engine noise or knock - until there was...
Hags86 is offline   Reply With Quote
Old 06-19-2018, 03:57 PM   #50
So what would have to be reinforced in the stock engine to prepare it for FI to possibly increase longevity and reduce the risk of failures? I'm planning on track days with a turbocharged 86 in the distant but inevitable future.
FIFY
Old 06-20-2018, 08:38 AM   #51
Hags86
Nothing. Just have $7-$10k cash at call when you need to build the engine. There is no guaranteed way to do it safely. You might be OK for a while, maybe not.
You could just pop some forged rods as they are absolutely the weak link. But once the engine is open the slippery slope starts. Just need to deck it to get a good surface for the seal. Hone the bores and now you need +0.1mm pistons. Those valves are very slightly bent.... You get the picture.
My advice is don't do anything and run the gauntlet. Just be ready to reach for the cheque book one day. If that will break you, then don't put the turbo on in the first place.
Old 06-20-2018, 10:57 AM   #52
gtengr
Drives: 2017 BRZ
I agree. It's tempting to build in advance in order to resell/reuse a healthy stock core, but my power goals are low enough that I think I have a good chance of it staying healthy for a few years until I'm ready for a different car. If I was planning on keeping the car for 5-10 years or more on boost with E85 I'd lean towards building in advance.
Old 06-20-2018, 08:06 PM   #53
Hags86
This, in my opinion, is a perfectly sensible approach.
Old 06-24-2018, 02:04 AM   #54
Ryan GT86
Ryan GT86's Avatar
I might reinforce in advance when I can then, I'm planning on keeping the car for as long as I can.
WTB: blown engines AVOturboworld Want-To-Buy Requests 1 02-15-2016 08:37 AM
Built engines ActionJackson Forced Induction 7 05-28-2014 12:25 PM
VR6 engines... dem00n Other Vehicles & General Automotive Discussions 29 01-25-2013 02:41 AM
100 hp/l NA engines einzlr Other Vehicles & General Automotive Discussions 95 11-15-2012 08:55 PM
So you think you know engines? Ryephile Other Vehicles & General Automotive Discussions 43 02-04-2012 04:49 AM
